Old 10-24-2013, 12:29 PM   #1876
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i need bigger injectors
Bariga is offline   Reply With Quote
Old 10-24-2013, 12:48 PM   #1877
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
ID1300's!
Old 10-25-2013, 01:48 PM   #1878
KingPest
Member#: 194894
2013 BRZ
2005 STi
How do you have your Vipec set up for knock detection? Are you using the OEM knock sensor, or do you have it set up with multiple knock sensors and the standalone knock unit?
Very curious on the Vipec, looks very nice.
KingPest is offline   Reply With Quote
Old 10-25-2013, 02:53 PM   #1879
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
vipec has knock control build in, that's why it cost little more than link.
im using Bosch sensor from old VW, mounted in same location under cyl 4
My high engine noise is from 250-300, and detonation is at about 500 and real knock around 800-1000.
Old 10-26-2013, 01:53 PM   #1880
KingPest
Member#: 194894
2013 BRZ
2005 STi
Thanks for the info. Been playing with the ViPEC software but it is a little bit difficult to decipher what it is capable of without connecting to an ECU.
Old 11-25-2013, 04:44 PM   #1881
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I have been testing single port Turbosmart IWG actuator that Geoff from Full-Race sent me, and I am very impressed with design, it comes with very beefy springs and can use combination of 3 springs!
Some what the design reminded me of EWG, as when you assemble the unit you have to press it together with wise due to stiff springs!
I am running 26 psi spring combo which is max on the unit. With 0 WG it gets me to 22 psi, and with 50% duty in linear slope mode to get 25-26 psi. Boost is flat to Redline, no lame tapper.
Here is picture of fitment, fits very good! I only had to modify the rod for easy removal.
Here is WG Duty map for 22 psi
And this one for 25 psi with meth
My guess is with 100% duty i could probably get 30 psi out of it
Big thanks to Geoff and Raffi from full-race!
Old 11-25-2013, 07:47 PM   #1882
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
is the threaded part suppose to be bent up like that?
Old 11-25-2013, 08:15 PM   #1883
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I bent it like that so it moves more freely.
Old 11-25-2013, 11:07 PM   #1884
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
How much preload did you put on that actuator?
Old 11-26-2013, 03:55 PM   #1885
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
very limited preload almost nothing, because when you assemble the unit is super preloaded.
Old 12-10-2013, 10:44 PM   #1886
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
hows things going with this turbosmart actuator, still good result? i am heading to PRI tomorrow, will see the turbosmart crew and planned to share this result.
i wish you had a shaft speed sensor in there and log to vipec to see how fast you are spinning the turbo and exactly where on the compressor map your setup is operating
Full-Race Geoff is offline   Reply With Quote
Old 12-10-2013, 11:06 PM   #1887
kellygnsd
Member#: 32669
LINK G4 hybrid STi
The speed sensor won't clear our heads on a subarus if he has the compressor clocked like I do. I actually had the speed sensor but had to send it back to you guys.
Old 12-13-2013, 03:08 AM   #1888
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ exactly what i thought when i was installing it.
I beat i'm so off the compressor map! But i like the instant spool to 5+ psi at 3000 rpm on the street. The turbosmart works great, i really liked the build quality vs Forge or Perrin (prototype).
Old 02-02-2014, 06:05 PM   #1889
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
looks like everything coming apart again, great.....
Pushing coolant with just 22 psi, about 7000 on the motor "remember its Benson block with cosworth gaskets and map h11 studs"
Old 02-02-2014, 06:11 PM   #1890
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
looks like everything coming apart again, great..... Pushing coolant with just 22 psi, about 7000 on the motor "remember its Benson block with cosworth gaskets and map h11 studs"
Not surprising... At least it's only coolant and not a spun bearing.
Junior2JZ is offline   Reply With Quote
Old 02-02-2014, 06:17 PM   #1891
Paul
Member#: 56203
00 RSTI Coupe
damn that sucks....and you've never ran over 30psi right?
Old 02-03-2014, 02:08 AM   #1892
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Wondering if the JE gaskets are any better.
alcoolaid is offline   Reply With Quote
Old 02-03-2014, 10:21 AM   #1893
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
25-26 psi was max i ran, that made about ~500 whp.
Old 02-03-2014, 12:32 PM   #1894
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
What do you mean by that junior?
Old 02-03-2014, 02:09 PM   #1895
calebtharrell
Member#: 242113
2004 STi, 2008 STi
How long ago did you buy the MAP Studs?
There was a set on the last block in my car which caused the heads to lift at 28psi.
I think Fuji K posted a thread about how they were incorrectly produced, the problem has been fixed now. But, maybe you have one of the bad sets?
calebtharrell is offline   Reply With Quote
Old 02-03-2014, 02:40 PM   #1896
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Im sure he is referring to the fact that, its just a weak headstud/head gasket problem and not metal particles throughout the whole motor, which would have done a number on many of your parts.
Yeah I seen that thread about the Map studs. They made them shorter than stock studs on accident . Check your studs.
TDagen is offline   Reply With Quote
Old 02-06-2014, 04:17 PM   #1897
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Will be shipping the block back to benson.
Old 02-06-2014, 07:01 PM   #1898
alcoolaid
Member#: 134949
'07 SWP STi
When I bought the block and when I swapped the head gaskets mine was like that too. MPS told me that part will push down easily when you clamp the head on....
What did Mr. Benson himself have to say about it?
Old 02-06-2014, 07:48 PM   #1899
Maxwell Power
Member#: 190729
the vertical measurement in his video is worthless because of the ligament warping.
It's the horizontal that shows room in the center between the cylinders that concerns me.
the new designed sleeves don't remove as much material and leave the ligament intact.
Maxwell Power is offline   Reply With Quote
Old 02-20-2014, 01:55 PM   #1900
Wolfie_OBXT
Member#: 364484
2006 OBXT
Any word from Dan?
Wolfie_OBXT is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 624 Yesterday 09:26 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
