Old 04-04-2011, 09:12 AM   #201
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
NICE wrap job. I cannot believe how many people go the easy way and wrap everything at once.
aboothman is offline   Reply With Quote
Old 04-04-2011, 11:34 AM   #202
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^^ You really think wrapping both pipes together and having 1" air gap in the middle of the wrap is that detrimental?
.....enough to justify an extra 5 hrs and 40 minutes of wrapping?
Old 04-04-2011, 11:59 AM   #203
Maxwell Power
Member#: 190729
detrimental or not, I don't want to try and get to the middle bolt of that flange with a bunch of wrap in the way.
Maxwell Power is offline   Reply With Quote
Old 04-04-2011, 12:12 PM   #204
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah that does suck.....but messing with a bolt for 10 minutes is still 5 hrs and 30 minutes less
Old 04-04-2011, 12:21 PM   #205
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I have a little bit of OCD so I tend to go for the individual runner wrapping. It looks less like a half-assed job that way IMHO. Were you able to wrap the TS uppipe too with that 100 feet of wrap?
Old 04-04-2011, 12:30 PM   #206
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ lol, for my previews setup i was able to use 100 feet for everything using their standard wrap, this wrap is a lot harder to work with and its way more sensitive!
Bariga is offline   Reply With Quote
Old 04-04-2011, 02:21 PM   #207
MartinSTi05
Member#: 145145
2006 wrx STi
I would argue that the 1" air gap in the middle would be better than individually wrapped runners. Why do mittens work better than gloves?
MartinSTi05 is offline   Reply With Quote
Old 04-04-2011, 04:24 PM   #208
Maxwell Power
Member#: 190729
that is why the wrap has so many layers for it's thickness. There are many woven strands that create little gaps and air boundaries. The more boundaries you have, the less heat is transferred.
I prefer each tube to be wrapped, or none at all. Uneven contact will result in differences in temperature across the pipe.
Old 04-04-2011, 04:40 PM   #209
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Nice job on the wrap! Did you ceramic coat them first then wrap? I didn't think people were wrapping these days with all the new coatings out there...
waynoSTI is offline   Reply With Quote
Old 04-04-2011, 06:35 PM   #210
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
**** the coatings, its waste of money. been there done that....
This wrap is different technology and wont catch of fire if oil spilled.
Old 04-04-2011, 06:57 PM   #211
faeflora
Member#: 169935
04 FXT, TurboMiata
Black, Green
The wrap may not burn but the oil sure will.
faeflora is offline   Reply With Quote
Old 04-04-2011, 07:50 PM   #212
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
What wrap did you use? Also how did your up-pipe come out? It doesn't seem like you'll be able to individually wrap the up-pipe since at one point the tubes are almost touching.
BTW great job on that wrap. I need to wrap mine soon. Dom should have my engine done around the same time as you. Also how come no DEI wrap coating? Keeps water and oil out of the wrap as well as adds another layer of thermal barriers. I actually got my headers+uppipe coated, gonna wrap both and finish it off with DEI wrap coating. Three layers of thermal barrier
EtoS is offline   Reply With Quote
Old 04-04-2011, 08:32 PM   #213
faeflora
Member#: 169935
04 FXT, TurboMiata
Black, Green
That is DEI "titanium lava rock" wrap.
Here:
http://www.designengineering.com/cat...-lr-technology
I used it on my downpipe and I also have the DEI turbo blankie too. It looks great and it definetly helps control temps. I can touch my downpipe after a run.
BTW make sure to keep braided SS lines from touching the wrap. It's a bit fragile and the SS line will abrade it and fu it up.
Old 04-04-2011, 09:22 PM   #214
MartinSTi05
Member#: 145145
2006 wrx STi
I like the lava wrap. I have used the fiberglass stuff many a time. It makes you itch and doesn't hold up too well on a daily driver; or anything that sees rain for that matter. I have wrapped two exhausts now in the DEI wrap. On both cars I haven't seen any deterioration and one of them is a DD with over 6 months use.
Old 04-04-2011, 10:14 PM   #215
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Bariga, how much did the lava wrap cost you and where did you get it? You bought 100 ft? I like the APS preformed wrap or maybe do this and custom form some SS thin sheet metal fastening them with metal straps. Can't get APS anymore and it may nor fit.
methaddict is offline   Reply With Quote
Old 04-05-2011, 12:38 AM   #216
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Took me about an hour to fully wrap my Perrin headers in the same manner as bariga did his FR headers. I never said anything about an air gap, but I believe the same thing as Dom regarding uneven temps. Wrapping both runners at once just looks like ****... maybe you like to half-ass things on your car, but a lot of us do things right the first time. Why would you NOT want them wrapped individually? Isn't the point of doing this to keep heat in the headers?
Old 04-05-2011, 01:24 AM   #217
reid-o
Member#: 103631
2004 STI
The aps shields are just acl heat shielding
They come in raw sheets that you can cut and form
They're hard to get though in the states for cheap
reid-o is offline   Reply With Quote
Old 04-05-2011, 12:52 PM   #218
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
the wrap was like 46 bucks each roll "from Import racing", took so long to wrap because i was high as hell maybe that's why Ill post up a pic of up pipe when i get more wrap....
Old 04-05-2011, 12:57 PM   #219
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 04-05-2011, 10:41 PM   #220
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
No wrap for me it make's to good of and oil sponge when thing go array, then likes to ignite. I have seen it happen more then once.
02WRX2.5 is offline   Reply With Quote
Old 04-06-2011, 12:25 AM   #221
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
lol dont spill oil on it......
+ if you spill oil on your coated headers they will catch on fire as well
Old 04-07-2011, 01:25 AM   #222
methaddict
Member#: 159738
2004 WRB STi
I have feeling i will have to wait for long time to get the EFR, ETA was last month......
I had the same feeling. I hope they're on target as Geoff says. I still need to get a couple things though.
Old 04-07-2011, 01:43 AM   #223
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I forgot, are you doing heads and cams in your build?
Old 04-09-2011, 10:55 PM   #224
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Dom, Craig thanks again for the build and hookups
Full-race system fits great with killerB
Old 04-10-2011, 11:23 AM   #225
Maxwell Power
Member#: 190729
Very nice.
You're welcome of course.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 618 05-13-2016 09:44 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
