Old 08-19-2010, 04:04 PM   #1
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Default Changed head gaskets, engine spins like it has no compression.
I pulled the engine out of the SVX and changed the head gaskets. Dropped it back in, tried to start, and the engine spins like it's got no plugs in it. Checked the timing, pulled the valve cover off to make sure the cams are in timing, the valves are moving freely... Lots of fuel, good spark... Yes the plugs are tight.
Thoughts? I'd rather not pull the engine back out.
Crazy_pilot is offline   Reply With Quote
Old 08-19-2010, 07:31 PM   #2
GrundleJuice
Member#: 165749
are the valves closing completely? Not firmiliar with the SVX drivetrain, but if there is a lash adj. chk that.
Old 08-19-2010, 08:15 PM   #3
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
The lash adjusters in the SVX are hydraulic. We popped one valve cover and checked them out, they look to be moving freely with the lobes.
The valvetrain on the EG33 is a bit odd. It's a quad-cam engine, but only the exhausts are driven by the timing belt. There are scissor gears inside the valve covers that drive the intakes off the exhaust cams. Tomorrow will likely involve pulling both valve covers to make sure the valves are synced properly with the pistons.
Old 08-20-2010, 11:44 AM   #4
vwbugpilot
Member#: 254120
2004 sti
black
go back and check the cam timing
vwbugpilot is offline   Reply With Quote
car feels like it has an extra 500 punds in it? wrxkid950 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-15-2010 05:55 PM
No head gasket engine, anyone interested for the 2.5L engine? berdugo Built Motor Discussion 4 06-11-2009 06:07 PM
changed head gasket, had slight problem, now car chokes to death 1995LegWag Normally Aspirated Powertrain 5 03-24-2006 12:06 AM
Changing head gasket scoobyimprza Normally Aspirated Powertrain 6 01-18-2006 11:23 PM
How to put heatshields on downpipe so it looks like it has cats? 04WRX2NV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-02-2004 08:44 PM
