#1 |
Member#: 56
PRSIC
Vehicle:1999 RS-T (Stage V) 2005 LGT LTD |
Need info on the wiring instructions of a HKS Turbo Timer (99RS-T). Already searched!!! NO LUCK
please Mariano ![]()
#2 |
Member#: 1234
Vehicle:2000 |
Which model timer do you have?
#3 |
Member#: 1903
Vehicle:2000 2.5 RS-T coupe T3/04 Link'd 2 10 PSI |
yeah, and no harness?
#4 |
Member#: 56
PRSIC
No harness. The model (not really sure) I'll check this afternoon when I get home. The unit was bought in early 99'; black compact box with HKS in green... I'll check the model number later on today.
thanks in advance. Mariano ![]() |
#5 |
Member#: 1994
Get a harness for a Japanese or European Impreza WRX, try a Ver 4, but DO NOT GET THE HARNESS FOR THE CURRENT WRX (unless that's what you have)!
Remove the lower dash, the stock harness is back there, I think the plugs are blue. Un plug it, and plug the new harness inbetween it, (you'll see what I mean). Next, connect the black wire from the TT to a good ground. Then connect the Grey wire to the E-brake wire. You can get to it by removing the center section around the e-brake. There's one wire that connects to it, un hook it before you splice into it. Don't cut the wire, just connect the grey to it. Put the car back together, fire it up, and make sure the TT works. BTW, it's an HKS TT, that's what they call it. |
| Thread Tools | |
| Display Modes | |
| HKS Turbo Timer Type 1 operating instructions? | youthanasia | Electrical & Lighting | 1 | 06-18-2004 11:59 PM |
| URGENT: Need help with wires on the HKS turbo timer type 1 | 1WRX2NV | Bay Area Impreza Club Forum -- BAIC | 4 | 10-10-2002 11:03 PM |
| HKS Turbo Timer & Factory Alarm - wires cut but.... | wy_wrx | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 10-21-2001 06:47 PM |
| HKS Turbo timer Wiring Harness | wrxwing | Car Part Reviews | 3 | 09-08-2001 08:56 AM |
| HKS Turbo Timer V Type 0, Type 1 and WRX wiring harness | White US WRX | Factory 2.0L Turbo Powertrain | 6 | 04-19-2001 05:09 AM |
