Vancouver Impreza Club
Old 08-19-2010, 07:18 PM   #1
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Default OT: Shifting gears on motorcycle
Hi to all the fellow VIC riders.
While riding around I figured out it is way more effective, and easy to stay on the throttle while shifting gears. Basically don't roll off the throttle, clutch in, shift gears, clutch out while throttle is all this time applied.
This is of course different from rolling off throttle, shift gears, then rev match etc.
Actually found this by accident, as I had to emergency move out of a stupid truck's blind merge.
Is this in any way ruining the clutch? I have a Z1000 and I don't think it has a "slipper clutch"
Cheers!
notjustforshow is offline   Reply With Quote
Old 08-19-2010, 08:02 PM   #2
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
I dunno about bikes...but thats how i've always shifted in my car when im in a hurry.....
sounds like you're going to kill yourself on a bike doing that ahhaha
Jeff54 is offline   Reply With Quote
Old 08-19-2010, 08:25 PM   #3
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Well knock on wood I don't speed on my bike but that was the first time I had to out of need. I of course used the clutch just stayed on contant throttle. Very smooth and I was out of there in no time
Old 08-19-2010, 08:40 PM   #4
geebutbut
Member#: 118451
Unless you're slipping the clutch excessively, I don't think it's a big deal. It will just result in a bit more clutch wear.
I'm not sure a slipper clutch would make much, if any, difference in this case. They're typically used to reduce the effect of engine braking, which wouldn't be the case here.
geebutbut is offline   Reply With Quote
Old 08-19-2010, 08:54 PM   #5
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
^ thanks!
Old 08-19-2010, 09:19 PM   #6
Yannerd
Member#: 111637
When you upshift don't even bother with the clutch. Just preload the shifter, get off the gas a bit and upshift then back on the gas. As for downshift, what you described works pretty well. I've been doing it for a few years now. I've also learned the use the slipper clutch which has made me a bit sloppy on my downshifts.
Yannerd is offline   Reply With Quote
Old 08-19-2010, 09:23 PM   #7
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
I've tried both methods and while not being an expert, seems a lot faster. Just worried about the wear and tear but the benefits might make it worth it... Thanks!
Old 08-19-2010, 09:33 PM   #8
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
I shift like you've described for "spirited riding" or quick shifts. Bike clutches are meant to be slipped, this is why they use a multi-plate wet clutch. You may wear the clutch a bit faster, but they are easy and relatively inexpensive to change anyways.
bcWRX-02 is offline   Reply With Quote
Old 08-20-2010, 12:31 AM   #9
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
ummm clutch to shift??? WTF
Chp_Stix is offline   Reply With Quote
Old 08-20-2010, 02:08 AM   #10
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
I've practiced what Yan mentioned, but not in the city as much...not quite pro yet but I can see how it is better
Old 08-20-2010, 03:27 PM   #11
bocaks
Member#: 171855
02 WRX
+1^
most bikes have sequential trans. they work a little different than your cars 5 speed, more like a racing dog box. they are always in a gear and can jump up or down without clutching, ajust throtle to reduce load on the gears and shift. you only need the clutch to start and stop. and as long as your close to min load no damage to the bike will occure
I'm on my 5th bike and never replace a clutch or gears on any.
bocaks is offline   Reply With Quote
Old 08-20-2010, 03:32 PM   #12
ducmaan748
Member#: 86518
2004 WRX STi
Stage 2
Man, I wish I still had my bike to try this... I always used the clutch to shift...Would this make a difference on a dry clutch or can the same "no clutching" be applied as well?
ducmaan748 is offline   Reply With Quote
Old 08-20-2010, 09:37 PM   #13
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
With my bike I have an upgraded race clutch system where I can pre-load and shift up and down clutchless, can be done on most bike just mine is a bit smoother and not as hard on the clutch, up shifting is smooth on most bikes where down shifting is quite abrupt and causes slip on stock clutches. My shift pattern is also switched over 1 up 5 down for race and track shifting it quite different to drive LOL
OT: School me on motorcycles Prod Off-Topic 57 06-09-2008 10:38 PM
rumbling noise when shifting gears on 06 jollib Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-01-2005 03:24 PM
OT: Top Gear on BBCW(shaw digi) Predwolf Vancouver Impreza Club Forum -- VIC 15 11-23-2004 11:52 PM
OT: 5th Gear on Speed Channel NOW!!!!!! SubaruBen Vancouver Impreza Club Forum -- VIC 1 07-13-2004 03:23 AM
OT: Need advice on motorcycle training Necromancer Bay Area Impreza Club Forum -- BAIC 10 09-05-2000 01:37 PM
