Old 08-19-2010, 08:29 PM   #1
scoarer
Member#: 229320
Talking Bugeye Headlight Protector removal
Came with the car when i bought it and its oxidized so i want to take it off. What is the best method to do so w/o scratching the actual headlight.
scoarer is offline   Reply With Quote
Old 08-21-2010, 08:57 PM   #2
uproot
Member#: 250100
2002 Impreza WRX
Midnight Black Pearl
are you talking about the lens over the headlight assembly? You can shine them back up with some rubbing compound. works wonders.
uproot is offline   Reply With Quote
Old 10-05-2010, 02:52 PM   #3
scoarer
Member#: 229320
yea the aftermarket lenses, one is already off so I want to take off the other side, just not sure how
Old 10-05-2010, 03:07 PM   #4
scoarer
Member#: 229320
[IMG][url=http://www.flickr.com/photos[/IMG][IMG][url=http://www.flickr.com/photos[/IMG]
Old 10-05-2010, 11:48 PM   #5
subaru3169
Member#: 55252
* pullup bar *
whoa.. nice lights
i suggest a headlight restoring kit.. i used 3m, very decent
subaru3169 is offline   Reply With Quote
Old 10-05-2010, 11:53 PM   #6
xveganxcowboyx
Member#: 232418
2002 WRX Wagon
You might try a DIY car wash place. I have successfully taken off very stuck vinyl with the high pressure soap. You have to come at the sticker from a steep angle, preferably with a small bit already peeled.
xveganxcowboyx is offline   Reply With Quote
Old 10-06-2010, 12:00 AM   #7
El Guapo
Member#: 234937
2004 STi
20G'd Blue
maybe go over it with a hair dryer or heat gun to warm up the vinyl and peel it
El Guapo is offline   Reply With Quote
Old 10-06-2010, 12:08 AM   #8
02boxer
Member#: 139853
2002 wrx....its tsxy
if you are meaning you want to remove the film....I had good success with slowly and lightly heating, with a hair drier, the surface little by little and slowly pulling the film off. Heat just enough to make it pliable. There was a good bit of adhesive left, but I was able to roll it off with my thumb, and then I cleaned the lens with some 3m wax, tar, adhesive remover. Came out clear as can be.
With respect to the car wash, you should never, for the sake of your paint surface integrity, spray close or with too much force. Generally, think of the paint as your skin. Too close and it can do damage.
chris
02boxer is offline   Reply With Quote
Old 10-06-2010, 12:17 AM   #9
xveganxcowboyx
Member#: 232418
2002 WRX Wagon
So does that mean it's a bad thing when I use the high pressure soap close up to take grease off my hands?
Old 10-06-2010, 01:43 AM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I suggest this first. The residue will be the problem. Cleaning it may remove the uv coating and cause the headlight to turn yellow over time. Might want to read more before getting started.
Old 10-06-2010, 01:44 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Also realize that usdm and jdm have the same lens.
Old 10-06-2010, 02:47 AM   #12
scoarer
Member#: 229320
Not sure if you guys can make it out in the pic, but its not a film/ sticker, its an actual hard lense over the headlight. I'm gonna try the heat gun but not sure on what tool to use that won't scratch the headlight, razor blade, flathead, or crowbar cuz its on there pretty good
Old 10-07-2010, 12:38 PM   #13
Pohenegamook
Member#: 134262
2021 Жи&
Then This VVVV
Pohenegamook is offline   Reply With Quote
oem bugeye headlight painting and amber removal cmarin21 South West Impreza Club Forum -- SWIC 12 06-25-2010 03:34 PM
Bugeye Headlight Removal, Help!! chodyWRX Interior & Exterior Modification 7 04-17-2006 01:53 AM
Differential Protector removed. -=Ph/\t WRX=- Texas Impreza Club Forum -- TXIC 9 09-11-2001 12:21 AM
OE Rear Diff Protector Removal kaminari Normally Aspirated Powertrain 10 03-09-2001 01:23 AM
Headlight Protectors? mikesoob7 General Forum Archive 6 01-01-2001 01:03 AM
