Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 08-19-2010, 10:10 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default NF Performance: Fuji's BUILT EJ22T w/ TD06SL2 20G 8cm E85; 11.75@116mph
SAME DAY DYNO
75* at DynoJet
80* at Mustang Dyno
Event: dyno pull
Ambient Temp: 75*
Elevation: 800'
Weather: cool / Minnesota
Tires: Nitto NT01 235/40/17
Car: '99 Impreza L Sport Wagon STi
Tuner: Nuke Toonz
Dyno Info: DynoJet@MAPerformance / Mustang Dyno@RS Motors
Transmission: JDM 6spd stock gearset
Gear: 4th
DynoJet
Peak HP at RPM: 377.64whp@somewhere 5500-6500 (SAE corrected is 388ish)
Peak Torque at RPM: 374@4400 (SAE corrected is 385tqr)
Mustang
Peak HP at RPM: 336.1whp@6166 (SAE corrected is 358ish)
Peak Torque at RPM: 333.7@4628 (SAE corrected is 361trq)
Baseline hp/tq DynoJet / Mustang Dyno: stg2 STi 300whp / 275
Target Boost: 25peak tapering 21.5psi@8000
Target AFR: 11.5afr
Fuel: E85 ethanol
Engine/Power Modifications: '06 WRX TR engine swap&immobilized, EJ22T block, double cross drilled EJ205 crank, Eagle Rods, Cosworth main/rod bearings, Custom CP Pistons (9.0:1CR), 12mm oil pump, balanced internals, STOCK '07 WRX Heads, stock cams, Crower valve springs/retainers, stock valves, custom FobiaWRX 3" straight MAF pipe&cone filter, TGV-less, STOCK Turbo INLET, eBay TMIC, Forge BPV, Kinugawa TD06SL2 20G 8cm, 38mm Tial vBand Ver2 EWG@1.2bar spring, custom Fuji internal wastegate bracket, MBC, fobiaWRX SPECIAL headers, 3" DP & Invidia race catback, modded dark blue WRX 900cc injectors, custom in-tank Bosch 044 fuel pump,
Other Modifications: Nuke Tuned, Fuji driven, Fuji engine build, Fuji funds
Major Dyno Sponsors:
Alan, Be, Cha, Julius, Michael, Nhia, Nuke, Pao, Pheng, Vandde,
#43 - no I didn't steal Block's number... haha
CORRECTED DynoJet
CORRECTED Mustang Dyno
oohhhhHHHH!!!!! How about AirBoy??
AirBoy Road Dyno as reference
DynoJet vs AirBoy
Mustang Dyno vs AirBoy
FuJi K is offline   Reply With Quote
Old 08-19-2010, 10:39 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Looks good! Keep it up guys!! That's almost a 4500rpm powerband!
TDagen is offline   Reply With Quote
Old 08-19-2010, 11:29 PM   #3
Moleness
Member#: 151183
Nice work!!!
Great tune + great driver + light car = FUUUUUUUNZZZZZ!
Moleness is offline   Reply With Quote
Old 08-19-2010, 11:53 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
my friend lives in MN and was telling me about your car, looks good glad to see it up and running and making great power
seanathanq83 is offline   Reply With Quote
Old 08-20-2010, 12:40 AM   #5
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Interesting, I was expecting higher numbers
No, Airboy Fuji?
The car looks great, how much does the car weight? Did you guys adjusted the weight setting on the dyno? Or you guys used the number from the list of cars that came with the dyno?
Congrats
Old 08-20-2010, 12:55 AM   #6
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Sweet, now paint that ****er 1 color, Lol.
wrxwhat is offline   Reply With Quote
Old 08-20-2010, 01:04 AM   #7
Lowrider
Member#: 222032
04 STi..Reloaded!!
^^ Its purposely meant to be a skittlez wagonz.
Lowrider is offline   Reply With Quote
Old 08-20-2010, 01:36 AM   #8
Nuke209
Member#: 108089
2003 WRX
NF Performance
No, Airboy Fuji?
Congrats
Got 3 logs today, 1 full road log, one dynojet log, and one mustang log.
I'll post the airboy when I quit feeling lazy
Nuke209 is offline   Reply With Quote
Old 08-20-2010, 08:34 AM   #9
CatfaceType-R
Member#: 81102
needs fmic fuji!
CatfaceType-R is offline   Reply With Quote
Old 08-20-2010, 09:49 AM   #10
vangstaboi86
Member#: 119945
2004 sti
java black pearl
good numbers guys!
vangstaboi86 is offline   Reply With Quote
Old 08-20-2010, 05:05 PM   #11
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
Looks like it spools like my S366.
Dipp is offline   Reply With Quote
Old 08-20-2010, 08:14 PM   #12
Nuke209
Member#: 108089
2003 WRX
NF Performance
at least your spools...
Old 08-21-2010, 01:44 PM   #13
dmross
Member#: 2818
2000 2.5RS
Nice! Throw a bigger set of cams in there and you're set!
dmross is offline   Reply With Quote
Old 08-21-2010, 03:45 PM   #14
Adrenalin Rush
Member#: 76729
2004 WRB WRX 2.7L
S400SX3, PPG, AEM, 701whp
Congrats Fuj, it was nice seeing your machine go! Always a pleasure! I love the dyno tag teaming!
Adrenalin Rush is offline   Reply With Quote
Old 08-21-2010, 10:00 PM   #15
WizardGandoff
Member#: 36667
04 DrgSmugrXps
Blackwiththablingblingold
must be fun to drive
WizardGandoff is offline   Reply With Quote
Old 08-22-2010, 09:34 PM   #16
4drcivicmaster
Member#: 211113
2004 STI
good job guys!
4drcivicmaster is offline   Reply With Quote
Old 08-22-2010, 11:42 PM   #17
olegrad
Member#: 192066
2007 WRX STI SWP
NF Performance
I hope so...'cause it was scary sitting passenger. Lol.
olegrad is offline   Reply With Quote
Old 08-23-2010, 02:06 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You should add another pipe to the intake and make it a cold air, put a bigger filter on it and put a mounting flange on it too.
Im sure all 3 of those things are contributing to that wavy AFR.
Also, how you liking the forge bpv?
Old 08-23-2010, 03:10 PM   #19
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Originally Posted by FuJi K View Post
SAME DAY DYNO
75* at DynoJet
80* at Mustang Dyno
So much win right there, lol.
..... Nice set up and comparison.
godforbid67 is offline   Reply With Quote
Old 08-23-2010, 03:28 PM   #20
Nuke209
Member#: 108089
2003 WRX
NF Performance
Forge BPV is doing it's job
Got something better for the hot air intake, and it's working.
Old 08-24-2010, 05:30 PM   #21
2barsti
Member#: 210644
Sell me the turbo?
2barsti is offline   Reply With Quote
Old 08-24-2010, 11:42 PM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by 2barsti View Post
Sell me the turbo?
ohhh realy?
the car is quite fun. Have to wait on spool up but anytime you're 4000+, boost come in pretty quick. Takes around 500rpms from vacuum to peak boost.
The CORRECTED DynoJet sheet wasn't sent to me, but I do have the screen shot from my Cell phone. So that's up there. The power curve is very good and similar between the two dynos. We'll get the airboy comparisons up.
The car weighs 2960 without me in it. That's with the whole engine swap and 6spd, axles, spindles/knuckles/Brembos.
The engine now has about 7400miles and still going!
Old 08-25-2010, 08:28 PM   #23
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
awesome! congrats!
Old 08-26-2010, 08:52 PM   #24
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
ok.... a better graph of the DynoJet up there.
Old 08-27-2010, 09:48 AM   #25
crashtke
Member#: 120912
Congrats Fuji! Now time for a turbo that can hold power all the way to redline. 9k is a ways out yet and it is already falling off pretty hard. I got just the thing for ya
crashtke is offline   Reply With Quote
