Old 08-20-2010, 01:06 AM   #1
Halls
Member#: 241214
2002 wrx
wrb
Default Long Term Review: Hybrid Users Post Here
I find that it would be usefull to have a thread dedicated to users of hybrid motors, instead of having to have multiple threads bookmarked to find the information you want (with the exception to stikys) Also any other things that did occur in the future, like tuning issues or oil consumption (I know there are a few threads on consumption).
Mileage since installed:
Type Engine and Internals: *State if you have low-compression pistons. If you don't know--shame on you.
Valve-train: *State machine work
Head Gasket Choice:
Current Status:
Follow this format so it is clear to read.
*Please forgive me if there is already a thread covering this.
Halls is offline   Reply With Quote
Old 08-20-2010, 08:30 PM   #2
sube-trex
Member#: 97577
2001 IS 300
Huh, nobody has any input... seems strange since these builds have been going on for quite some time now +7 years.. and not to mention a local shop here does ~3-5/month...
sube-trex is offline   Reply With Quote
Old 08-21-2010, 01:54 AM   #3
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
Mileage since installed: 8X,XXX but is down due to me putting in bad gas and getting insane knock and blowing ringland! Other then that was a solid motor with great power!
Type Engine and Internals: Stock 05 ej257 with 03 wrx heads
Valve-train: Stock 03 WRX
Head Gasket Choice: Stock STI
Tuner: Tim Bailey
TRDRacer is offline   Reply With Quote
Old 08-21-2010, 09:07 AM   #4
Ryan314
Member#: 82989
Hybrid VF22
Mileage since installed: 3500
Type Engine and Internals: Brand new '10 STI short block
Valve-train: Stock 2.0L heads
Head Gasket Choice: STI
Tune: Tuned with no problems. 250whp/300tq (TD04)
Current status: Blown ringland at 3500 miles. Subaru pistons SUCK! Unbelievable that it blew a ringland with my setup
Ryan314 is offline   Reply With Quote
Old 08-21-2010, 10:28 AM   #5
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
subaru pistons do suck but with your set up. your tune is what sucked.
ownnij is offline   Reply With Quote
Old 08-21-2010, 10:37 AM   #6
Ryan314
Member#: 82989
Hybrid VF22
It was tuned by Bren Tuning (www.brentuning.com), who is highly regarded up in my area. Doubtful it was the tune. It tuned fine with no issues found in the tuning process whatsoever.
Old 08-21-2010, 11:06 AM   #7
crashtke
Member#: 120912
Lol, same thing I said. Other option is some kind of mechanical failure.
crashtke is offline   Reply With Quote
Old 08-21-2010, 12:42 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Is my EJ22T block a hybrid?
FuJi K is offline   Reply With Quote
Old 08-21-2010, 12:48 PM   #9
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
That is unbelievable that you blew a ring land. Are you certain of this? I would say that, that's a pretty safe power level for a stock STi block. Even with stock pistons.
PSolbergfan is offline   Reply With Quote
Old 08-21-2010, 03:53 PM   #10
Ryan314
Member#: 82989
Hybrid VF22
Tell me about... I'm pretty sure smoke pouring out of the filler cap when revved and consuming quarts of oil is a sure sign of a blown ringland.
There was a reason I didn't switch to stronger pistons during the build-- I didn't think I would NEED them with a TD04 making 250/300 power!
It was NOT the tune. Guaranteed.
I wonder if Subaru will do anything for me about this... doubtful.
Old 08-21-2010, 10:12 PM   #11
crashtke
Member#: 120912
Subaru will do nothing for you. Aftermarket tune, raised boost pressure=no warranty. Unless you had it installed at the dealer and were running stock levels of boost I doubt they would even think about warrantying it. But some how you detonated. For whatever reason you want to think. But at 250 hp on a TD04, it was pushing it pretty darn close to the edge/limit of what that turbo could do.
Old 08-21-2010, 10:18 PM   #12
Ryan314
Member#: 82989
Hybrid VF22
250whp out of a TD04 set to 17psi with all the supporting mods is no way pushing the limit. Plus, the car was a daily driver, and it definitely wasn't beat on. My setup is almost identical to a stock 06-07 WRX (EJ25 block, TD04).
Old 08-22-2010, 09:48 AM   #13
crashtke
Member#: 120912
17 psi at peak, 17 psi at redline on a TD04? They could be two completely different things. The TD04 is maxed out at 250 hp. Go do the math 17 psi with 30 degrees of timing at peak torque? 17 psi at redline with 40 degrees of timing? You see my point at all?
I have tuned quite a few hybrids, some almost double that hp with stock pistons and no issues. And yes, some on 08+ short blocks. It takes detonation or a mechanical failure to break those pistons. Psi will not break pistons. Detonation will.
Old 08-22-2010, 10:27 AM   #14
Ryan314
Member#: 82989
Hybrid VF22
17psi peak.
Old 08-22-2010, 10:31 AM   #15
crashtke
Member#: 120912
Tapering to what and with what amount of timing?
You do know that above a certain range, the knock sensor becomes effectively useless right? It is specifically calibrated to a certain window.
Old 08-22-2010, 10:33 AM   #16
Ryan314
Member#: 82989
Hybrid VF22
I'd have to check with my tuner. He honestly never found any knock tuning this motor, and through out all of the logs I've sent him since the tune...
Old 08-22-2010, 12:25 PM   #17
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
do you have any logs?
Old 08-22-2010, 01:34 PM   #18
Ryan314
Member#: 82989
Hybrid VF22
Most recent learning view-
Old 08-22-2010, 03:02 PM   #19
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
Guys please don't turn this to a trouble shooting post! It is made to post only setups that people have used! I for one am glad to see this posted but I would not want to be someone who will have to look through pages of someones problem and others trying to figure it out! Post another thread about this, which I think you already have, so no more figuring out the problem guys, please keep it a clean post with setups only!!!!
Old 08-22-2010, 09:53 PM   #20
twonb1
Member#: 129163
2011 evo x
Phantom Black
Mileage since installed: Beats Me
Type Engine and Internals: Ej257 w/ 100mm mahle 4032
Valve-train: Bc 272, cams springs, valves and retainers
Head Gasket Choice: Stock Sti
428hp 376tq@ 22lbs
Current status: Blown Ringland
twonb1 is offline   Reply With Quote
Old 08-23-2010, 02:27 AM   #21
Halls
Member#: 241214
2002 wrx
wrb
What's up with all these blown ring lands? I know the OEM pistons suck.. but c'mon. Any preventative actions for this other than forged pistons?
Old 08-23-2010, 05:56 PM   #22
crashtke
Member#: 120912
Good tune?
Old 08-23-2010, 06:23 PM   #23
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Mileage since installed: 52,000(i think)
Valve-train: OEM, springs, valves and retainers, STI Cams
320hp 305tq@ 19lbs
Current status: Blown Ringland #2 Cylinder -
This was the tune...Anybody the says otherwise is kidding themselves. The false knock was tuned out but occasionally I would get real knock when outside temps were fierce. I'm going tobe lowering the compression with combusiton chamber work and putting in forged JEPistons.
paintbing is offline   Reply With Quote
Old 08-23-2010, 07:22 PM   #24
Maxwell Power
Member#: 190729
Tuner: Tim Bailey
current status?
I think the current status is important for everyone's post.
IMHO that is based off many of these engines, a Hybrid without proper chamber work (regardless of who tuned it) is a ticking time bomb. Many people talk about how great the extra quench is, but I think it has a very very negative effect as it places a lot of material in the way of the escaping exhaust gases creating large hot spots.
Maxwell Power is offline   Reply With Quote
Old 08-23-2010, 07:43 PM   #25
Maxwell Power
Member#: 190729
here is what I'm trying to explain in a really crappy MS Paint drawn picture.
Point A is the large quench pad that is created by placing a 2.5L bore on a 2L head. Point A on the non enlarged head has a greater quantity of exhaust gas passing that point in addition to a relatively stagnant pocket (B) just below it. When the piston moves to the top, that pocket is cleared out and the hot gasses are pushed up and around the corner at Point A. This causes the heat to be deposited into the head at that point which creates a hot spot that will cause detonation the next time the cylinder is filled and compressed. Also, filling that void around the corner takes more time and energy which can rob power. Someone might argue that the cool charge coming into the cylinder the next time around will cool off that hot spot. That is what I believe happens to a degree under light loads and when the intercooler is cooling the intake charge off significantly. Under high boost and heat soak conditions the spot will not be cooled sufficiently by the intake charge and that point will only get hotter and hotter.
In the cylinder on the left, the point A only has a small amount of gases flowing past it and the very small pocket (B) doesn't retain a lot of heat or stagnant gasses.
This is why Hybrids are so unreliable. You can have a 9:1 compression hybrid with a larger chamber and it would be leagues above a 9:1 compression hybrid with no chamber work in both power and reliability.
OFFICIAL: LG-VX9100 users, post here! psychoskip Off-Topic 3 06-17-2010 11:46 AM
Samsung Instinct users post here sube-trex Off-Topic 8 06-17-2010 07:45 AM
VF34 Users Post here! Assassin4457 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-27-2006 11:44 PM
Any long term users of Torco RTF? edmundu Transmission (AT/MT) & Driveline 8 08-15-2005 12:53 AM
Long term users of FMIC's Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-10-2003 05:49 PM
