Old 08-20-2010, 10:36 AM   #1
Ryan314
Member#: 82989
Hybrid EJ257
Default Prosport oil pressure gauge reads 25psi higher
So ever since installing my Prosport oil pressure gauge, I always wondered why it said my oil pressure was so high. Rarely do you hear about high oil pressure issues. My Prosport gauge would read 58psi at warm idle, and always pegged at 120psi at anything above 2000 RPM. To make sure the gauge was reading correct/incorrect, I picked up a mechanical oil pressure gauge that screwed right into my sandwich adapter. Sure enough, at warm idle, the mechanical gauge is reading 35psi at warm idle, while my Prosport gauge is reading 58-60psi. That's 25psi difference.
I'm glad that rules out my thoughts of a high oil pressure problem...
Thoughts?
Ryan314 is offline   Reply With Quote
Old 08-20-2010, 10:53 AM   #2
traction_is
Member#: 254175
05 WRX
CGM
I am guessing it is either the calibration of the gauge or a faulty pressure sender. Do you have the performance series sender or the premium? In my previous car I went through 3 performance senders, but they were all for reading too low.
You should contact prosport and ask them about it. I've always had great service from them and they quickly replaced what I needed.
traction_is is offline   Reply With Quote
Old 08-20-2010, 11:21 AM   #3
Ryan314
Member#: 82989
Hybrid EJ257
Performance series. Gauge and sender bought brand new.
Old 08-21-2010, 11:43 AM   #4
jskeezy5
Member#: 195521
1999 Impreza 2.5rs
I just had a problem with my oil pressure gauge, mine was reading low or no oil pressure when I knew there was nothing wrong. I called talked to prosport and they sent me a new sensor and it fixed my problem. Maybe you could try the same?
jskeezy5 is offline   Reply With Quote
Oil Sandwich Adaptor for Prosport Oil Pressure Gauge? SubyTR07 Interior & Exterior Modification 10 02-01-2008 05:58 PM
FS MA: ATI pod, Lotek pod, Prosport oil pressure gauge Ziggyrama Interior/Dressup/Audio & Security 12 04-19-2007 01:44 PM
Prosport Oil Pressure Gauge boostheadwrx04 Electrical & Lighting 0 11-11-2006 04:47 PM
FS: Prosport oil pressure gauge (matches STi perfectly), and custom AL dead pedal! sticrazy Interior/Dressup/Audio & Security 12 10-18-2006 11:38 PM
Prosport oil pressure gauge, Clarion MP3 deck, and custom dead pedal all on Ebay!!!!! sticrazy Interior/Dressup/Audio & Security 11 10-04-2006 10:01 PM
