Old 08-20-2010, 11:49 AM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default how to check air/fuel ratio
I fell my 1999 OBS is running a little rich. How can I be sure? If so, what can I do?
alejo is offline   Reply With Quote
Old 08-20-2010, 12:05 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
In the days before fancy A/F gauges, we would go out and make a hard pull then clutch in and pull to a stop ASAP. Pull the plugs and read them for color, deposits, etc.....
Nowadays, you can tap the O2 sensor wire with a digital voltmeter and read the voltages when under load. When you know what the readings are, you can look around for corresponding A/F values for a given voltage. If memory serves, you should see something around 0.80vdc. The narrowband sensors are only accurate right near 14.7:1.....they tend to act more like a low-good-high switch.
Another, more accurate way would be to buy a wideband sensor kit and install it separately from the OEM sensors. It will serve as a real-time monitor for the A/F ratio.
Jay
Old 08-20-2010, 01:56 PM   #3
alejo
Member#: 170081
2004 2.5RS
blue
thanx. do you know of any link to buy the kit online?
Old 08-20-2010, 03:52 PM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
Another option is one of these:
OBDKey OBD2+SSM Bluetooth Module
Plus, a Java and Bluetooth Capable Cell Phone.
And the software ECUTracker
(I'm the author of ECUTracker by the way)
Resulting in
That combination above will give you mobile ability to monitor the Subaru SSM protocol, which includes the OEM Wideband sensor. Granted, the accuracy of sensor can't be confirmed with this setup, but if it's indeed correct, you can at least see what it's reading.
Skidd is offline   Reply With Quote
Old 08-21-2010, 02:13 PM   #5
alejo
Member#: 170081
2004 2.5RS
blue
Resulting in
where can I buy it?
Old 08-23-2010, 02:35 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Buy Which? The OBDKey?
http://www.obdkey.com/
It's not cheap, but it's the ONLY Bluetooth OBD module I'm aware of that can also do the SSM protocol.
ECUTracker is totally free though.
how to air\fuel ratio gauge boxer54 General Community 3 12-31-2004 10:35 AM
How to hook up air\fuel ratio gauge boxer54 Electrical & Lighting 2 12-31-2004 09:21 AM
How and where to hook up my air/fuel ratio gauge PumpsGOTAWD Electrical & Lighting 2 02-24-2003 08:33 PM
('93-'01) How and where to hook my air/fuel ratio gauge PumpsGOTAWD Impreza Forum 2 02-24-2003 12:38 PM
Dyno, Measuring Air Fuel Ratio? how? ciper Newbies & FAQs 1 07-19-2002 09:01 PM
