Old 08-25-2010, 05:58 PM   #1
Wussman24
Member#: 157283
2003 2.5RS
Rattl'd white
Default Group N Mounts???
Alright, had the local dealership replace my headgaskets. I had given them the mounts to install while the engine was out. Went back to get my car and everything was fine except they didn't install the mounts. They said the mounts would not work because of my cross-member (2003 rs).
I was under the impression that they would work. Thought I did enough research, I guess not. Maybe I just need to get under there myself?
Any feedback would be appreciated.
Thanks,
Wussman
Wussman24 is offline   Reply With Quote
Old 08-25-2010, 10:40 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Can't say I've ever heard of such a thing. AFAIK the Group N mounts will work on pretty much anything from the 1st gen Imprezas to the current gen.
Patrick Olsen is online now   Reply With Quote
Old 08-26-2010, 02:14 AM   #3
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
they work on every ej with every crossmember. However, some cars have liquid filled mounts (LGT and 06 sti for example) and you have to buy the mounting plates as well. They probably just forgot and then made that up when you asked.
AQ Motorsports is offline   Reply With Quote
Old 08-26-2010, 07:58 AM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
I installed Group N engine and transaxle mounts on my former SVX. The trans one went without a hitch; the engine mounts needed to retain the original plates with a little bit of cutting and some washers for spacing to keep the engine at its original height.
CN: If they fit the SVX, they sure oughta fit your car.
LetItSnow is offline   Reply With Quote
Old 08-26-2010, 09:36 AM   #5
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
i had the same problem in my 03 OBS. they said the mounting plates would not align correctly. they were able to install them on the old plates...not sure if that has made a diff. in the overall rigidity of the setup.
doubledribble is offline   Reply With Quote
Old 08-26-2010, 12:13 PM   #6
renob123
Member#: 41986
'06 STI/'85 Brat
If they fit my '85 Brat with an EJ25D block, they sure oughta fit your car.
Jacob
renob123 is offline   Reply With Quote
Old 08-26-2010, 12:17 PM   #7
LetItSnow
Member#: 38222
'10 &'12 Foresters
Well, now we just need a guy with a 360 to chime in!
Old 08-26-2010, 10:24 PM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Jacob
Now come on, I know for a fact that you had to slot your mounting holes in the crossmember.....
~Josh~
ballitch is offline   Reply With Quote
Old 08-26-2010, 10:51 PM   #9
renob123
Member#: 41986
'06 STI/'85 Brat
~Josh~
Heh, yeah But any EJ mounts would need that.
Jacob
Stock strut mounts or Group N mounts? hsu_baru Brakes, Steering & Suspension 1 10-24-2006 12:48 PM
cusco engine/tranny mounts vs. sti group-n mounts ImprezaJDM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-28-2005 12:49 PM
brandnew STI group n mounts for WRX bgbyztoy Private 'For Sale' Classifieds 5 08-26-2004 08:32 AM
FS: STI group n mounts for WRX bgbyztoy Private 'For Sale' Classifieds 2 12-11-2003 09:01 PM
STi group N mounts look inside subaruxtra.com Vendor 'For Sale' Classifieds 8 07-31-2003 10:29 AM
