Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2015
Old 09-11-2011, 08:53 PM   #76
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
Bump for a check.
Originally Posted by WRrexu View Post
what did it end up being ! im still waiting to get my car up on a lift to start the diagnoses !
Nice to see you updated
That said, 50K+, same clutch, same tranny, still stage one (with a much better RCE/Bilstein suspension and some 335 star specs) no problems at all. While I am mostly reasonable I often get to the 4-9 over the posted speed limit quite quickly (numbers recommended by my brother in law a traffic cop around here). But never racing others, I just like to check my but dyno.
etothen is offline   Reply With Quote
Old 11-07-2011, 12:39 PM   #77
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
And another bump to look around.
Old 01-07-2012, 03:51 PM   #78
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
another bump for info...
drewvdw is offline   Reply With Quote
Old 01-07-2012, 06:41 PM   #79
08WhiteRex
Member#: 187453
2012 Mulletmobile
Well, i'm making 370whp/390lb-ft now with an ACT heavy duty clutch. Been changing the gear oil every two months with Redline 75w90NS with a quart of lightweight shockproof. Last few times i've been getting the normal shavings and some worryingly large chunks of metal. Pretty sure it's not brass so i'm guessing the gears are on their way out.
08WhiteRex is offline   Reply With Quote
Old 02-11-2012, 08:07 PM   #80
JTraction
Member#: 206864
'11 E90 M3
'10 WRX (sold!)
22,xxx miles and clutch was starting to slip in 3rd and 4th, running with 334wtq (mustang dyno) since 6k miles. I had burned it once or twice so it was expected. I just replaced with an ACT HDSS clutch so now I'll really see how the tranny is built. I previously had the Group N transmission mount, full KB shifter bushings and short shifter. With the new clutch I added a KB pitch stop. Everything feels goooood now.
I finally feel confident I have a clutch that can tolerate a launch, so I'll probably do a few of them. Hopefully these newer 5 spds really are stronger. FYI, pitch stopper added some noise with accel/decel but overall I think it sounds raw and wicked.
JTraction is offline   Reply With Quote
Old 02-12-2012, 12:50 AM   #81
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
08 wrx
vf52 swap
stage 3 22 psi tune
stock clutch,41k miles to date
no problems ever
424wrx is offline   Reply With Quote
Old 02-12-2012, 10:10 PM   #82
ecb12
Member#: 214708
09 WRX
Stage 2
DP, Intake, Exhaust, Tune
22k miles
Stock clutch went from perfect to gone in one day
Never raced, launched, tracked etc
ecb12 is offline   Reply With Quote
Old 02-13-2012, 10:28 AM   #83
farmin
Member#: 310114
i have an 08 impreza wrx in the shop right now trying to put a new clutch in. trying to get the tranny out right now how do i go about getting the front axles out of the tranny? thanks. sorry for hijacking thread just need to know now and dont have permission to post new threads yet! TIA
farmin is offline   Reply With Quote
Old 02-13-2012, 06:22 PM   #84
Jdeere7710
Member#: 309643
There is a pin in the axel close to tranny punch it out
Jdeere7710 is offline   Reply With Quote
Old 02-19-2012, 03:05 AM   #85
xHairyBuffalo
Member#: 239576
2010 463WHP
Stock 5-speed
First of all, there is a reason this post says 08-10 WRX transmissions. So for all of you '99rs or 05 WRX guys, you have a different transmisison so your "contribution" to this thread is pointless. With that being said, here is my story:
10 WRX, 350whp/400torque with e85, tuned on Cobb's mustang dyno. I currently have 30k miles on the car, about 10k of which have been stg 2 and another 10k on e85. I also have around 10 passes on the 1/4 mile dragstrip, with a pretty conservative launch (slipping the clutch at 4k or so resulting in 60ft times between 2 and 2.2 seconds, which is pretty slow). So far the only issue I have had is some slight clutch slipping if i punch it in 5th gear while under 3k RPMs. Other than that, it still flies through 1st, 2nd, 3rd, and 4th and runs a 12.6 1/4 mile at the track.
xHairyBuffalo is offline   Reply With Quote
Old 02-19-2012, 03:41 AM   #86
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
Are the 2011's much better? will the 2008-2011 gear box fit in the 06 tranny?
SoCal_Scooby is offline   Reply With Quote
Old 03-15-2012, 09:39 AM   #87
wayward167
Member#: 253998
13 BRZ
36k miles
Cleverley tuned stg 2
Spt short throw
Kartboy bushings
Noisy and crude but still working
Friend had a completely stock 11 hatch trans replaced at 3k miles
wayward167 is offline   Reply With Quote
Old 03-15-2012, 12:12 PM   #88
cbs160
Member#: 246460
2010 WRX
SSM Stage 2+ 300/340
had a main shaft bearing go on me driving home from work one day at around 21,000 miles. claimed to be a bad part from the factory. repairs covered under warranty by a tech who was supposedly "the best in the state"
fast forward 7000 miles and 4th gear now grinds occasionally. i'm nursing it the best i can as a tranny rebuild now will surely be out of pocket.
cars not beat on, but driven like its meant to be. some people get lucky, some people don't. seems like i'm the latter
cbs160 is offline   Reply With Quote
Old 03-15-2012, 12:17 PM   #89
Black_Sheep
Member#: 305431
2010 WRX 4 Doors
Dark Grey
2010wrx 20K miles
all stock besides exhaust
no problem!
Black_Sheep is offline   Reply With Quote
Old 03-15-2012, 01:58 PM   #90
fury211
Member#: 233750
2008 wrx
08. Put in ACT HDSS because the stock slipped at 10k miles.
HDSS throwout bearing crapped out at 35k miles.
Replaced with stage 4 competition clutch sprung 1620 set.
pressure plate is rubbing against a rib in the transmission.
replaced again.
rubbing again.
tearing it apart AGAIN.
fury211 is offline   Reply With Quote
Old 03-15-2012, 04:19 PM   #91
9900rpm
Member#: 103733
2015 STI
ISM
Saw a 4 door 2011 WRX transmission blow apart at Evo vs STi at Raceway Park this past Sunday. From the numbers it was running, it was probably a S2 car.
So yeah, they do still break.
9900rpm is offline   Reply With Quote
Old 03-15-2012, 08:16 PM   #92
danbolsom
Member#: 256898
2011 WRX Limited 6MT
World Rally Blue
That was me ='( im doing an sti swap =)
Im stage 2 with a fmic ewg and fuel pump tuned by john@TheShop
danbolsom is offline   Reply With Quote
Old 03-18-2012, 09:40 AM   #93
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
There was a handfull of 2010's that had an issue with the circlip from the center diff breaking and getting ground up. The factory has fixed the problem with a newer part number and and better designed clip.
04stigeorge is offline   Reply With Quote
Old 03-18-2012, 11:01 AM   #94
arkangyl
Member#: 253095
2008 STI
10 WRX @ 42k miles
stage 1 since 28k miles
a few 4k launches, some hard shifting, not really babied or abused... I did learn stick on this car so the first 3k were pretty traumatic :-)
no issues...
arkangyl is offline   Reply With Quote
Old 04-04-2012, 04:03 PM   #95
NoUse66
Member#: 279475
2009 WRX Hatchback
My 09 has about 58K and no problems yet.
All stock except for the kartboy shifter + bushings.
NoUse66 is offline   Reply With Quote
Old 04-05-2012, 09:47 PM   #96
dave07
Member#: 291349
2013 Mustang GT
09 with 57K miles. No problems with clutch or tranny at all. Stage 1 + SF intake
dave07 is offline   Reply With Quote
Old 04-06-2012, 02:49 PM   #97
Faraz
What?...
Do they speak English in What?
Member#: 1459
2008 WRX 5door MT
WR Blue
08 wrx 72k. 10k stage II and synth trans fluid. Clutch died last week, re-surfaced oem flywheel and exedy stage 1 clutch installed today. Wow the engage point is very different, but not that much stiffer pedal feel. I can't wait to see how she feels after the break in.
Faraz is offline   Reply With Quote
Old 04-07-2012, 11:16 PM   #98
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
Can these flywheels be resurfaced? I had an issue with an older track car (porsche 944S2). there were no "spec's" to be found on minimum thicknesses, so I had it turned down about 0.010", just to get the ridges out. Installed my new clutch and it would slip in almost everygear about 3k rpm. forced me to upgrade to a Spec aluminum flywheel (nice piece) as it was about 1/2 price of the original replacement. Just curious....and a possible word of caution
P_tothe_G is offline   Reply With Quote
Old 04-20-2012, 04:17 AM   #99
cablegorilla
Member#: 288942
2011 wrx premium sed
2011 wrx stage 2 14k still kickin! noisey and sloppy but works just fine
cablegorilla is offline   Reply With Quote
Old 04-20-2012, 05:16 PM   #100
csdilligaf
Member#: 317548
I'll be buying one of the newer 5sp for a 914 conversion. Are there any around FWD only so that I do not have to do the conversion kit to make 2wd only?
csdilligaf is offline   Reply With Quote
Black center counsel cover impreza 08-09-10 Dereksti Interior/Dressup/Audio & Security 31 01-25-2010 07:18 PM
FS:(Irvine) Invidia Catted Downpipe 08/09/10 WRX/STI's and 05-09 Legecy GT's ntbass SCIC Private Classifieds 0 11-05-2009 01:40 PM
08 09 10 WRX: Cusco Zero 2e blackmist27 Suspension/Brakes/Handling 7 10-15-2009 12:26 PM
08 09 10 STi stock handling characteristics chimchimm5 Brakes, Steering & Suspension 7 09-27-2009 09:30 AM
FS: 08/09/10 WRX (LGT and 09+FXT) Perrin Recirc (BOV) Black, $100 shipped method Engine/Power/Exhaust 4 09-18-2009 10:50 AM
