Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-24-2012, 11:05 PM   #101
fc3sna
Member#: 186592
2008 Subaru WRX
Pearl White
I have a 08 WRX with 72k miles
Still rocking the stock clutch(knock on wood)
Car has been perrin stage 1 since it was broke in at roughly 6k miles
then was switched to TP Stage 2 at about 40k
Clutch feels as good as the day I bought it and I dont baby the car, but I also dont abuse it either...... I just dive it like it should be drove,
Kudos
fc3sna is offline   Reply With Quote
Old 04-27-2012, 09:59 PM   #102
live2ridetahoe
Member#: 31386
2008 WRX Avant
08 WRX
VF 52 swap with supporting mods
69000 miles
275/275 whp/tq on 91octane
I let a friend drive it last weekend and he said there was a "pop" in the clutch. The clutch now has a strange feel to it. It is difficult to get into gear, but once it does, it shifts, well, not great but ok. I am guessing it is the TOB.
What is the "fork" I have heard people talking about in their transmission?
My tuner recently replaced an ACT HD in an 09 WRX. The owner had some problems. He put in a South Bend Stage 3 clutch. The customer, who is running E85 and putting down about 340 torque, says that he as 20K miles on it and no probs.
My transmission is fine, just the clutch issue.
JG
live2ridetahoe is offline   Reply With Quote
Old 04-29-2012, 01:39 AM   #103
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
2009 WRX 75k miles
at least 30k at stage 1 and 5k at stage 2. Zero problems.
moonrider_99 is offline   Reply With Quote
Old 04-29-2012, 11:28 PM   #104
wrxstage2
Member#: 149806
Vf48 , sti intercooler, cobb catless dp, cobb catback, sf intake, walboro 255
Efi tuning pro tune, 110,000 on 1st tranny mostly stage 2 wrx tr 2006
Rebuilt tranny holding well if u kno how to druve 300whp is no problem with the transmission
284whp/334tq
wrxstage2 is offline   Reply With Quote
Old 04-29-2012, 11:46 PM   #105
08WhiteRex
Member#: 187453
2012 Mulletmobile
The 5 speed clutch fork has been known to fail, and it locks you out of gear and will cause all types of issues.
Here's what they look like when they've been reinforced.
Having said that, i have an ACT HD and have had zero issues over the 15k miles i've put on it (370/390). And it seems like it's luck-of-the-draw with the clutch fork failures, but i will say that the heavier clutches seem to eat them up faster. Your main resolution will be buy a new clutch for and have the back welded up by someone who knows what they're doing and where to reinforce it.
08WhiteRex is offline   Reply With Quote
Old 05-13-2012, 02:44 AM   #106
Dezrador33
Member#: 295378
2011 Impreza 2.5i
Camellia Red Pearl
2011 Impreza 2.5i 5 M/T 12k on it.. all stock except for a Megan Racing midpipe and muffler delete and rims. Running strong, no problems, no slips, though it does have the humming/whining on decel in second gear but it has done that since the day I drove it off the lot so its just common as others have said.. Though I am wanting to 6 speed swap it if anyone can direct me to a place to help with that..?
Dezrador33 is offline   Reply With Quote
Old 05-15-2012, 09:07 AM   #107
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
5dr 2010 purchased in late 2009. I have 31000 miles and aside from killing that pesky deer in AZ the car purrs like a kitten. I get the clutch shudder on cold mornings (this isn't news) but other than that it's great.
MODS:
K&N drop in
SPT cat back exhaust
DMrally tuned early next month (fingers crossed)
SparkSilver10NM is offline   Reply With Quote
Old 05-15-2012, 09:56 AM   #108
amp0412
Member#: 179330
05 LGT Wgn
400whp PriceRocket
Broken. Mines a legacy trans but its all the same gears.
0-60k probably 300-350whp I didn't own it then, but from what I know after owning and working on the car now it had a fmic, bigger turbo, injectors, map sensor, broken ringland.
60-80k stg2 stock clutch 250whp 300wtq airboy
80-105k htagreen acthd clutch 370 whp 330 wtq airboy (400whp and 370wtq on the shops dyno dynamics)
Broke third gear while cruising on the highway. Clutch was ruined as well after 20k.
amp0412 is offline   Reply With Quote
Old 05-15-2012, 04:29 PM   #109
chitownwagon
Member#: 279668
2007 WRX Limited Wag
Dark Silver
08 WRX
69000 miles
JG
This sounds exactly like what just happened to me on my stock 07 transmission and it was the shifter fork it took a few months before it completely broke. It's only a $20 part from subaru but you do have to pull the transmission basically the same work as replacing the clutch
chitownwagon is offline   Reply With Quote
Old 05-15-2012, 05:51 PM   #110
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
09' 2.5i hatch. Throw-out bearing "exploded" at 70k. Clutch itself was fine but had already ordered an Exedy Stage One clutch kit so had that put in.
Imprezzedwitsubies is offline   Reply With Quote
Old 05-15-2012, 11:58 PM   #111
MJBenz
Member#: 58853
2009 WRX
You must be talking about my 09 WRX. I got tuned on E85 2 years ago with just 5k miles. I now have 38k miles with no issues with the transmission except for the clutch. The stock one lasted about 10k miles after switching over to E85. Then I had an ACT HD clutch installed and that lasted about 20k miles. I now have a Southbend stage 3 endurance clutch which feels really solid. BTW I'm making 350whp/410tq on a low reading dyno.
Matt
MJBenz is offline   Reply With Quote
Old 05-16-2012, 06:39 PM   #112
w.l2.x
Member#: 293875
2008 Impreza WRX
08 wrx 52,000 miles. 10k stage 2. Trans running the same as when I bought the car. Blouch 20G xt-r in near future with other supporting mods. We will see how the stock trans holds up.
w.l2.x is offline   Reply With Quote
Old 05-17-2012, 11:23 AM   #113
nc08wrx
Member#: 289428
2008 WRX sedan
08 wrx, I’ve owned it for 1 year, so I’m not sure about previous mods. I’ve done my fair share of (10 or so) launches using the quick slip method before going stage 1 in January (65k). And prior to that in November the car did just fine for an HPDE weekend at NCCAR (63k). In February my probably not so perfect launches chewed up the clutch lining. After pulling everything apart, I saw it was the original clutch and replaced it with an exedy stage 1 (70k). Went stage 2 early April and I only smell the clutch a little after a couple launches in a row (4 launches so far). So long story short…no issues with the trans (75k).
BTW, I poured in Lubrication Engineers gear oil after the track weekend if anyone can pm me any experience with this stuff I’d like to hear it.
nc08wrx is offline   Reply With Quote
Old 05-17-2012, 02:01 PM   #114
P-Train
Member#: 279233
2008 WRX
08' WRX 57k miles on it. Daily driver. Not beat on short of some snow donuts. Transmission growls and has been growling for the last 12k or so. Been to two different subaru dealerships countless times to have the noise remedied only to come out with additional damage/noises and the original problem not fixed. Noise started while stock, I have a CBE and poly shifter bushings on right now (have other mods but those are only the relevant ones)
P-Train is offline   Reply With Quote
Old 05-17-2012, 08:29 PM   #115
Garufi518
Member#: 284277
09 wrx clutch went about 20k after my pro tune making 340/340 tranny seems pretty solid still ....anyone using flat foot shifting on their new gen?
Garufi518 is offline   Reply With Quote
Old 05-18-2012, 03:34 AM   #116
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
2010 WRX
stock motor/trans/clutch, SPT catback, KB SS + bushings
63k+ miles.
no problems
installing WL subframe and rear diff bushings soon. and after that probably jump to stage 2 with a cobb DP, spearco tmic, and AP tune.
gsrcrxsi is offline   Reply With Quote
Old 05-31-2012, 11:41 AM   #117
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
2011 WRX 29,xxx miles
Kartboy Holy Shift kit
Invidia N1 TBE
Agency Power ELH
IPR TMIC
Five-O Motorsports Denso 1400cc Injectors
Aeromotive 340
AEM Intake
E85
380whp/417tq
The trans is holding up fine but the clutch is slipping and is being replaced. Imagine that.
everdying55 is offline   Reply With Quote
Old 06-04-2012, 12:48 PM   #118
PraetorianGuard
Member#: 230273
2009 WRX Hatch
OBP Tq'd Stage 1
Originally Posted by PraetorianGuard View Post
2009 WRX w/14,000 miles. Shifts well, with the exception of an occasional unpleasant rubbing feeling when going into 3rd, like the side of the shifter is hitting something. Having that checked out by dealer soon, will replace oil w/Extra S at the same time.
Edit to say that I am fully stock, with the factory short shifter.
Update: Now with 37k miles on the clock. Recently replaced tranny fluid with Extra S, added TiC Holy Shift kit and Group N tranny mounts. Shifting is much more smooth, and no more unpleasantness going into third gear!
PraetorianGuard is offline   Reply With Quote
Old 06-29-2012, 09:47 AM   #119
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
2011 2.5i
Rallisport headers
CAI
tsudo cat back
Slight tune from Mikey at the shop ct
38490 on the clock
Clutch feels like jello compared to every other car I drive. Totally different from 10k miles ago. It doesn't feel like it grabs from 1st to 2nd and 2nd to 3rd.
ozunadel is offline   Reply With Quote
Old 06-29-2012, 12:11 PM   #120
johnnyb
Member#: 57593
2015 Crosstrek XV
2008 WRX hatch
73k miles - 2nd owner and I have put on 20k miles
Stage 1
Factory short throw shifter
No issues besides the usual shifing into 1st from reverse and vice versa. Something I hadn't noticed on my bugeye is having to double clutch when downshifting from 5th into 4th. Other than that, no major problems but thinking about getting the "cocktail" to see if it improves anything.
johnnyb is online now   Reply With Quote
Old 07-02-2012, 06:30 AM   #121
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
2010 WRX fully bolted tuned on E85 @ 390whp/398wtq
30,000mls
Popped mine about a month ago at a langley speedway. I was in the final race for "top dog" and did a massive launch. 1st was there 2nd was there...I went to shift into third and my stick did a circle. Put it in 4th and nothing. So as of right now all i have is 1st,2nd and 5th. I drove home (40mls) like that. It didnt make a sound at all. PPG straight cut dog box is planned in oct. Now note that i was not nice to this trans. I drove it hard. Syncros started to grind a few months earlier. I race it regularly. Over all these trans are solid but like everything else, if you abuse it they will break.
wrxtuner13 is offline   Reply With Quote
Old 07-03-2012, 10:21 PM   #122
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
BLOWN!
2011 Subaru WRX
20G XTR - E85 - 27psi
462WHP / 492WTQ
Third Gear
The car had the 20G XTR (and 400WHP+) for over 10k (daily driven) miles. Lost 3rd gear at the track when I applied power. I was not shifting at the time. I was not shifting hard at the track (road course) that day, but I have shifted it hard (flat foot shifting) many times in the past.
xluben is offline   Reply With Quote
Old 07-03-2012, 10:47 PM   #123
danbolsom
Member#: 256898
2011 WRX Limited 6MT
World Rally Blue
Originally Posted by xluben
BLOWN!
2011 Subaru WRX
462WHP / 492WTQ
Third Gear
Video Link: http://www.youtube.com/watch?v=n4-s0KlOStg
What are you doing with your trans beause if ur just throwing another stock unit in i will hook you up with a fresh rebuild unit with zero miles on the rebuild and it has ppg tail housig gears basically the output shaft
danbolsom is offline   Reply With Quote
Old 06-26-2013, 11:16 PM   #124
jeerick354
Member#: 344379
2011 WRX Cobb Stage2
Obsidian Black
Originally Posted by VT_Hatch View Post
Throw out bearing had to be replaced at about 18,000 miles and now at 26,000 miles it has to be replaced again, or its the fork this time. Either way, I'm not pleased with this transmission. It's loud, sloppy, and seems to fall apart often.
Stock car for first 20k miles, now at stage 1.
it seems as if you do not drive your car correctly nor take care of it the proper way. i have 90 k miles on mine with cobb stage 2 sf. no problems yet. working on convincing my father to get staged for his 2011 he is just worried about the trans. the parts and tune we will be putting on will roughly give him 330 hp but he is worried about trans. i told him to grow a pair and just do it lol. if trans goes i will rebuild an sti trans to make it handle more power.
jeerick354 is offline   Reply With Quote
Old 06-27-2013, 01:48 AM   #125
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Be more concerned about an engine failure than a transmission failure.
SlimJim8804 is offline   Reply With Quote
Black center counsel cover impreza 08-09-10 Dereksti Interior/Dressup/Audio & Security 31 01-25-2010 07:18 PM
FS:(Irvine) Invidia Catted Downpipe 08/09/10 WRX/STI's and 05-09 Legecy GT's ntbass SCIC Private Classifieds 0 11-05-2009 01:40 PM
08 09 10 WRX: Cusco Zero 2e blackmist27 Suspension/Brakes/Handling 7 10-15-2009 12:26 PM
08 09 10 STi stock handling characteristics chimchimm5 Brakes, Steering & Suspension 7 09-27-2009 09:30 AM
FS: 08/09/10 WRX (LGT and 09+FXT) Perrin Recirc (BOV) Black, $100 shipped method Engine/Power/Exhaust 4 09-18-2009 10:50 AM
