Old 08-21-2010, 09:45 AM   #1
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
Default Head Swaps
I was curious if anyone out there has swapped there 2.2 heads for ones off an EJ205.I hear they flow quite a bit better and complement the EJ22 block.Also,what other work would be involved in doing this swap other than just swapping heads? Thanks for any info
subaru_kid is offline   Reply With Quote
Old 08-21-2010, 02:44 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Wrx intake manifold, swap out wrx injectors, swap in sohc EJ25 injectors, remove your engine harness, install onto wrx intake manifold. And you might have to block off some vacuum ports. Cant remember if the wrx throttle body is compatible with your car's wiring.
Hold on a second, in your signature it says you have a 2000 BRP, would this be the EJ22 engine you are taking about swapping a set of EJ205 heads onto?
~Josh~
Old 08-21-2010, 08:02 PM   #3
subaru_kid
Member#: 207888
2003 Impreza 25RS
Platinum Silver
Ya,its the phaseII EJ22.I read in a book that the EJ205 heads were good to use with this block.The EJ207 I believe has the AVCS which the 205 doesn't making an easier swap.
2.5 DOHC heads to 2.2 SOHC heads swap questions. sick1.8t Subaru Conversions 10 05-02-2006 03:45 AM
lets talk head swapping. jasona Normally Aspirated Powertrain 2 08-31-2002 12:42 AM
STi cylinder head swap. KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-14-2002 12:06 PM
head swapping Tensecgn Normally Aspirated Powertrain 4 12-01-2000 07:02 PM
Legacy Turbo head swap to a N/A 2.2L (idea's)? MPREZYA Technical Forum Archive 6 05-19-2000 06:22 AM
