Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 08-21-2010, 01:05 PM   #1
pwilk
Member Sales Rating: (2)
Member#: 95133
2004 WRX Wagon
Default CT: Stock Midpipe (section with rear cat)
Looking to by a stock used midpipe. I need the section with the rear cat. A dealer gave me this PN, 44101FE040, but I'm not 100% sure its right.
pwilk is offline   Reply With Quote
Old 08-21-2010, 01:22 PM   #2
remotehuman
Member Sales Rating: (24)
Member#: 201995
2000 Forester
that's not the mid pipe thats just the back cat section. your best bet is buying a complete cat downpipe off of someone for around $100 on here.
the part number you have is for the bottom pipe in this picture
remotehuman is offline   Reply With Quote
Old 08-21-2010, 01:50 PM   #3
remotehuman
Member#: 201995
2000 Forester
Old 08-22-2010, 09:30 AM   #4
pwilk
Member#: 95133
2004 WRX Wagon
I guess I'm confused. Last week I started noticing an exhaust leak. So I put the car up on jackstands and started it up so I could crawl under and hear where it was. The leak seems to be coming from the part in the bottom of the photo. There is an O2 sensor in it.
Looking at the figure in this post I assumed it was the midpipe.
So your saying it'll be easier finding a downpipe+back cat combo? That would be the bottom and top components from your image. The one on the left is the uppipe, right?
Old 08-22-2010, 09:34 AM   #5
biebs96
Member#: 238035
in the picture above i have the pipe that is on the left. if thats what you need pm me, it will go for cheap too
biebs96 is offline   Reply With Quote
Old 08-22-2010, 09:44 PM   #6
remotehuman
Member#: 201995
2000 Forester
most people will consider those two cat pipes after the turbo the down pipe. On almost every instance that is the part that is taken off to replace with aftermarket catless or high flow cat pipes. It's easy to find the stock pipes together for cheap. The list price on that last pipe is $360 dollars, and I'm sure the dealer told you that, so you're best bet is to buy a used downpipe.
That being said, are you sure you don't just need a new gasket?
this is all the pieces of the exhaust:
and this is how you will normally find the two pieces after the turbo if buying on the forums:
hope that helps
Old 08-23-2010, 10:15 PM   #7
pwilk
Member#: 95133
2004 WRX Wagon
Yes indeed it does. I took the heat shields off this evening and found my problem. Not a hole in the cat but the weld just behind it. The weld is broken all the way around. The weld is to go from the body of the cat to a short (~3-4 inches) of straight pipe before going into the flange joint with the midpipe (section just after you circled).
At least I know what the problem is. Now to decide what to get to fix it...
FS: Downpipe Rear Section with High Flow Cat and OEM Rear Aeroguards PSM R3DR3X Engine/Power/Exhaust 14 08-14-2010 08:48 AM
CT: Stock 05 WRX downpipe, midpipe, and intercooler for sale ismegamanthere Engine/Power/Exhaust 3 03-17-2009 03:00 PM
I'm finally done: stock-location AWIC with rear coolant reservoir scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 5 10-12-2008 09:24 AM
Will SPT Cat-back's muffler section fit to a stock midpipe with resonator? kg555 Newbies & FAQs 15 06-15-2006 01:54 AM
WTB: Stock Midpipe Rear section bcristea Mid West Subaru Owners Club Forum -- MWSOC 7 09-14-2005 06:39 PM
