Old 06-21-2002, 01:06 AM   #1
mrtrex
Member#: 12223
2005 WRX
Default My 1/4 mile time
My times werent bad I think they could be better but it is good for know. trap speed seems a bit low. I am making 250 whp at 17lbs tapering off to 15.5 at redline (I like to be safe) my time slip tonight was;
Rt .792
60 1.831
330 5.58
1/8 8.696
mph 79.87
1000 11.392
1/4 13.5
mph 98.74
mrtrex is offline   Reply With Quote
Old 06-21-2002, 01:20 AM   #2
SubyRex
Member#: 10794
2002 Impreza WRX
13.47 @ 98.98MPH
sorry if you've posted this somewhere, but I'm somewhat new here, what mods do you have again?
SubyRex is offline   Reply With Quote
Old 06-21-2002, 01:59 AM   #3
mrtrex
Member#: 12223
2005 WRX
vf-30
upipe
t back exhaust
injecters
pump
intake
unichip custom tuned
trap speed is a little low for my liking I was hoping for 103 but its fast enough for me I not trying to set a new record just want to have fun.
Old 06-21-2002, 02:02 AM   #4
apwrx
Member#: 13957
02 Wrx sold
mbp
nice time what elevation are you at?
apwrx is offline   Reply With Quote
Old 06-21-2002, 02:10 AM   #5
mrtrex
Member#: 12223
2005 WRX
someware around 800-1000 feet above stock rexs are running 14.5 to14.6 at best but a stock type r with sticky tires ran a 14.8
Old 06-21-2002, 02:30 AM   #6
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
Yeah mister speedy was only 4 sec faster than my rs tonight (his secret was the chicken nuggets )
His times would be even faster if he wasn't talking to his gf on his cell while he was going down the track
Brian
b_tapper is offline   Reply With Quote
Old 06-21-2002, 10:03 AM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Default Re: My 1/4 mile time
Rt .792
60 1.831
330 5.58
1/8 8.696
mph 79.87
1000 11.392
1/4 13.5
mph 98.74
something isn't right at all. Those are my identical times for my first stage (catless t-back, unichip, stock turbo) and I was making 230awhp and 235awhp tq. That was at 700ft in 85 deg weather too.
I'd get back on the dyno and/or check your datalogging that is a really slow time for that you have. you should be close to a second faster.
TypeC is offline   Reply With Quote
Old 06-21-2002, 10:14 AM   #8
mrtrex
Member#: 12223
2005 WRX
Thats about right I am not running a boost controler and I have my boost tapering off pretty good.
Old 06-21-2002, 10:51 AM   #9
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
ok, how is adding MORE mods and a bigger turbo and getting the same time right? Explain that to me. I'm just trying to help you. 13.5 is pathetic for a turbo upgrade. Just to put in perspective, with turboback and a VF23 at 15psi a certain individual ran a [email protected] with a 1.83 60'. Yes, 13.5 is off indeed.
Old 06-21-2002, 11:04 AM   #10
Member#: 17625
02 WRX
Maybe its an Automatic
STR8OUT@WORK is offline   Reply With Quote
Old 06-21-2002, 11:05 AM   #11
mrtrex
Member#: 12223
2005 WRX
Its not an auto
Old 06-21-2002, 11:10 AM   #12
b_tapper
Member#: 5291
'08 Scion xB
Keystone Raceway seems to be the slowest dragstrip in the country for some reason. It's freshly paved and has about as much grip as ice does. Even my slow RS has traction problems on that track.
Old 06-21-2002, 11:41 AM   #13
mrtrex
Member#: 12223
2005 WRX
Well back to turbo xs on thursday car is pulling timming after 5000 rpm. Delta
dash rules
Old 06-21-2002, 12:55 PM   #14
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
You should be able to run those times without the VF30, Injectors, fuel pump, etc.
I ran consistant mid 13s with Turboxs stage 2 setup. 13.3 @101 being my fastest.
The last time I went to the track with my stage 4 setup I ran a best time of 8.18 @ 84 mph in the 1/8 mile so you can see you times are way off the mark.
You mentioned stock WRX's running mid 14s. Thats very normal. At our track they run mid 14s and up.
SGOSWRX is offline   Reply With Quote
Old 06-21-2002, 01:21 PM   #15
mrtrex
Member#: 12223
2005 WRX
Mark is taking my car in on thursday to see what is up? Free of charge. Turbo xs rules thanks type c for making me think somthing was up and there was.
Old 06-21-2002, 02:43 PM   #16
SythLordRex
Member#: 18556
Were you dropping the clutch at 4-5k or slipping it?
SythLordRex is offline   Reply With Quote
Old 06-21-2002, 02:48 PM   #17
jmott
Member#: 6713
2007 Prius
brown
I have a similar setup as you. 250WHP, FP turbo, turboback, bla bla bla. unichip tuned, boost ALSO tapering like yours is
with a 1.9 60ft time I ran a 13.3
with a 1.7 60ft time I ran a 12.9
your mph is a bit low, something may be wrong, either with car or track.
jmott is offline   Reply With Quote
Old 06-21-2002, 06:39 PM   #18
Subi-fied
Member#: 13483
You should be running high 12s with that setup.
Hmmm....
Subi-fied is offline   Reply With Quote
Old 06-22-2002, 06:10 PM   #19
SleeperWRX
Member#: 8179
In the heat last night I trapped at 96mph a couple times with:
homemade mbc, k&n drop in, silencer hack...you beat my speed by 2mph with several thousand dollars in mods...I'd say something is very wrong with the car. My 60' was worse than yours too... 1.87 for me.
SleeperWRX is offline   Reply With Quote
Old 06-25-2002, 03:52 PM   #20
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
I have just Vishnu Stage 0 and ran 13.097 @ 103 w/muffler removed, at 320 feet. The time is not bad... but the trap speed is pathetic, no offense, for what you have done. With just an EBC I was running 13.7s @ 98 mph w/1.9XX sixties...
def
dug-e-fresh is offline   Reply With Quote
My 1/4 mile times at 5000 ft. above sea level. davidm_sh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-22-2001 04:09 PM
My 1/4 mile times WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-22-2001 03:48 AM
My 1/4 mile time IMPBOY Bay Area Impreza Club Forum -- BAIC 0 11-19-2000 07:21 PM
whats with my 1/4 mile time scootr Newbies & FAQs 15 10-19-2000 10:09 PM
My 1/4 mile times and question Keiho Technical Forum Archive 23 08-08-2000 02:52 AM
