Old 06-21-2002, 12:56 AM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default Putt, Putt, Stumble, Putt, Putt...then dies?
Hi again, I guess 175,000 miles is starting to show...
I have another problem. Here are the symptoms.
I have a 93 Impreza L 1.8L. Sometimes when I'm driving, the RPM's bog down or stay the same, then the engine gives out a sound like a dead growl, and with accelerator pushed in more the RPM'S go nowhere. Sometimes when this is happening if I let off the accelerator or move it around, it will catch up and be fine. This time I was driving it began happening and then I pulled over to the side of the road and it did the deep growl and the car stumbled like Peaty's for about 15-20 feet then died. I then restarted it, it stumbled then died. Did it again, nothing. About 2 minutes later I tried it again, revved it up to about 4,000, stayed for a second, then completely shut off from 4K. That don't seem right. Then I went to smell the engine bay it smelled like the mixture was not burning quite right, BUT it did not smell like FUEL. Also it did smell abnormally hot, like the smell of hot metal. Though the coolant temp was fine. Spark plugs/wires have 3,000 miles on them. Fuel Filter has 3,000 miles. One other symptom I might be able to add is that this has happened to me three times now whenever I come home to Illinois from North Carolina where it has never happened before there??*** I know the alt. is 3,000 ish feet in Illinois and 0 feet on the North Cakalaky Seaboard. I'm thinking maybe Throttle Pos. Sensor, fuel pump,??? I am not getting a Check Engine Light. I am not sure if fuel pumps slowly show signs of failure but this all happened within 5 minutes of the first stumble. Gas was just filled before this happend also. I had approx. 4.5 Gal of fuel in tank, I put in 2 16 oz. bottles of alcohol to help clean injectors and 6 Gallons of fuel. I always get Hi-Grade fuel too. ***?? Also last December when I was last in Illinois, this begun happening. The car never died on me though it seems as if it would of if I didn't revv it up. I though it was the fuel filter, then I changed it and it still did it then a week later it went away. ***??
I appreciate you enduring the length of this message. I wanted to give as much info as possible.
Thanks, Max
P.S. any reply is highly appreciated
Max Umbarger is offline   Reply With Quote
Old 06-21-2002, 10:32 AM   #2
newbie sewbie
Member#: 10615
well, lack of, or insufficient fuel and/or sparks is the cause of most drivability problem.....you mentioned you've changed the plug wires, but what about the plugs, cap, and rotor?
i would inspect your plugs, it'll tell you alot about what is going on in the combustion chamber....look for any unusual color, and give it a sniff to see if there's any traces of unburnt fuel
i would also inspect the fuel pressure, if you have access to a pressure gauge
these are just things to start off first, simple things need to be eliminated.....oh, one more thing, pull a check engine code
newbie sewbie is offline   Reply With Quote
Old 06-22-2002, 03:33 AM   #3
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default Bud Light!!
Hi! I did the D-Check: no lights, nothing. as a matter of fact the car ran okay. Then of course I ran it again. Picky-picky :: again it didn't die but it seemed to be close to dying again. ***??
Maximus
Old 06-22-2002, 05:51 PM   #4
Max Umbarger
Member#: 1112
2006 FXT
RBP
Mechanic started looking at my car said so far it seems the engine isn't getting fuel. My fuel pressure guage shows there is fuel though?
Maximus
Old 06-24-2002, 12:27 AM   #5
newbie sewbie
Member#: 10615
well, having fuel in the tank and having suffient amount of fuel(pressure) are two totally different things. it could be a bad pump, bad filter, clogged line, bad fpr, etc. etc. etc.......be interesting to see what the problem is.......keep up posted
runs then dies marc l Normally Aspirated Powertrain 10 05-24-2005 09:05 PM
my car starts and then dies somtimes, what could cause this? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2005 06:30 PM
Swap Done, Started then DIED.. HELP! Z0rr0 Subaru Conversions 2 12-21-2004 03:32 PM
Anyone's car stalling and then dies after hard corner Andre Vandenberg Normally Aspirated Powertrain 10 02-09-2001 09:27 AM
