Old 06-14-2014, 03:53 PM   #1
Tombo
Member#: 148200
04 STI
JBP
Default Power Steering unrepsonsive !!
2004 STI, new pump at 80,000. Car currently at 112,000. I just finished replacing the hardline banjo bolt crushwasher, o-ring, and reservoir lines. I manually bled the system by turning the wheels side to side until there was no bubbles left. Adjusted the belt to spec and topped off with ATF fluid.
BUT now when I start my car the power steering is stiff and won't even kick in? Could there be more air trapped in the pump? Would over tightening the crush washer be a cause to this? Is my pump screwed?
Tombo is offline   Reply With Quote
Old 06-15-2014, 08:41 PM   #2
Tombo
Member#: 148200
04 STI
JBP
anyone?
Old 06-15-2014, 08:44 PM   #3
Tombo
Member#: 148200
04 STI
JBP
I have attempted to bleed the system multiple times with no luck. When I turn the car on the pump is completely silent and I have no assist at all. The pump was working fine (other than a small air leak) prior to all the replacement parts I installed* Also the rack and pinon has about 30k on it.
*Other parts I installed at the same time, but not directly relating to the pump: mishimoto ancillary hose kit, mishimoto turbo inlet hose, mishimoto intercooler hoses, new oem turbo, and new evap hoses.
Old 06-15-2014, 10:41 PM   #4
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
did ya put the wrong hose on the wrong place???
is the fluid in the reservoir foamy??
Old 06-16-2014, 12:18 AM   #5
Tombo
Member#: 148200
04 STI
JBP
All hoses are in the correct place. The reservoir has maybe one or two tiny bubbles, but nothing like a foam.
Could it be possible that there is some stubborn air stuck in the pump? How many times should I manually go lock to lock?
Old 06-16-2014, 01:20 AM   #6
Uncle Scotty
OK buy Nates beans
well...ya screwed the p000ch somewhere....it worked before....its not now
what did you do to make it NOT work??
Old 06-16-2014, 01:22 AM   #7
Uncle Scotty
OK buy Nates beans
if you held the steering at full lock for any period of time you may have killed the pump doing that
Old 06-17-2014, 12:07 AM   #8
Tombo
Member#: 148200
04 STI
JBP
Sh**, I don't know what happened. I'm going to remove the reservoir and look for any potential blockage and completely flush the system. If that doesn't help anything I'll have to buy a new pump.
One noticeable difference is that I replaced one of the reservoir lines with silicone line from mishimoto. Not sure if that would screw with anything.
Old 06-17-2014, 01:33 AM   #9
Uncle Scotty
OK buy Nates beans
is that line plugged or sucking closed???? first thing id replace with what is supposed to be there
Old 06-17-2014, 03:51 PM   #10
Tombo
Member#: 148200
04 STI
JBP
Definitely what I was pondering. I've went ahead and ordered the oem part. Here's hoping it's part of the solution.
Old 06-17-2014, 08:26 PM   #11
Uncle Scotty
OK buy Nates beans
make sure to update this when you figure it out....
Old 06-18-2014, 11:54 AM   #12
Tombo
Member#: 148200
04 STI
JBP
Well, after removing the suction hose between the pump and reservoir, I realized I had made a (potentially dire) sloppy mistake. I had been using a vacuum plugs to keep fluid in and crud out while I worked on my vehicle. Seems that I had missed one. I am totally kicking my ass for this, as I am usually insanely meticulous.
I removed the plug, put the hose back on, manually bled the system, and started the car (with the wheels up). Pump doesn't seem to be making any weird noises or leaking, but it is being a pain to get all the air fully out. I have yet to know if I've bitten the bullet, but everything seems okay for now.
Thank you for all your help and troubleshooting. I really appreciate it.
Old 06-19-2014, 04:13 AM   #13
Uncle Scotty
OK buy Nates beans
oopsie....
oh well...if that's the worst thing ya **** up and forget
worse things have been forgot
