Old 07-11-2011, 03:29 PM   #576
vision.dynamix
Member#: 139955
# OneBoston
No idea. I just saw them on a mod list when I was looking at the car show sheets.
Old 07-11-2011, 09:25 PM   #577
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I have a set! They are Ok the spring rates are way 2 soft! But if ur into LOW and cheap do em up! I'll sell u my old ones! They only have about 500 miles on em
07wrx84 is offline   Reply With Quote
Old 07-12-2011, 05:30 AM   #578
ShredNW
Member#: 273912
07 wrx
can you get rear camber plates for racelands?
ShredNW is offline   Reply With Quote
Old 07-12-2011, 11:13 AM   #579
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I don't think so! But worse case maybe have a machine shop mill slots or other brand plates could work?
Old 07-12-2011, 07:46 PM   #580
druwski
Member#: 275923
How much? Can I use my stock top hat on these to make them fit my 95?
druwski is offline   Reply With Quote
Old 07-12-2011, 09:18 PM   #581
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I'd take $300 but just shoot me an offer! And for that I'm not sure??
Old 07-13-2011, 03:51 AM   #582
ShredNW
Member#: 273912
07 wrx
Default Coilover Help
Hey guys, so i am thinking about getting raceland coilovers for my wrx and i had a couple questions.
1.) how low can these really go? with or without removing helper springs.
2.) will camber bolts fit on these? and is there any universal camber plates that will fit for the rear? if so how much?
Old 07-13-2011, 03:52 AM   #583
ShredNW
Member#: 273912
07 wrx
pics??
Old 07-13-2011, 11:25 AM   #584
JMS Landshark
Member#: 48773
2004 TiC WRX
also '99 BMW M Roadster
Originally Posted by ShredNW View Post
^what did his car look like?
and im not going to be tracking my car its just a dd and i dont take corners fast but i wonder if i can find rear camber plates for these?
I've never really understood the "its only a DD" thing when saying the suspension doesn't need to be good. For me, my DD needs to have a suspension thats easy to live with and relatively comfy. Do you only drive on very smooth roads? I'm not trying to flame, I just don't understand.
Full Disclosure: I have coilovers on my DD, but they aren't low and stiff. They are actually reasonably comfy, but even then it gets a bit much sometimes.
JMS Landshark is offline   Reply With Quote
Old 07-13-2011, 01:24 PM   #585
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
pics??
It be easier for me 2 text them 2 u
Old 07-14-2011, 01:06 AM   #586
druwski
Member#: 275923
thanks, really want them but I dont think they will work on my 95
Old 07-14-2011, 01:29 AM   #587
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I don't think they will either
Old 07-14-2011, 11:24 PM   #588
ZDalton
Member#: 276448
2002 wrx
was playing with my camera today and took a few pics.... this is all the way up (without moving the whole strut assembly up)... So if you buy them and put them straight on your car and adjust the lower perch and spring up until it makes contact with the upper perch, this is the height you will be at.
ZDalton is offline   Reply With Quote
Old 07-15-2011, 01:44 AM   #589
blakkboxer
Member#: 167244
2k3 WRX MBP
black & gold is pimpin'
that still sits pretty ****ing low
blakkboxer is offline   Reply With Quote
Old 07-17-2011, 12:59 PM   #590
thejapino
Member#: 51668
Racelands on my gf
thejapino is offline   Reply With Quote
Old 07-17-2011, 01:15 PM   #591
blakkboxer
Member#: 167244
2k3 WRX MBP
please post your review here(good or bad):
http://forums.nasioc.com/forums/show....php?t=2074644
Old 08-29-2011, 12:24 AM   #592
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
I'm having some problems with mine. I just got mine on a few days ago. I set them up they worked awesome for a day, Then I realized that the rears were a little bit too low. So I adjusted them up about an inch. Now they make the most horrible SLAMMING noise when I hit certain sharp bumps. Everything is tight. It is almost like the strut is either getting stuck, or rebounding extremely hard
mr.nicknasty8 is offline   Reply With Quote
Old 08-29-2011, 12:49 AM   #593
blakkboxer
Member#: 167244
2k3 WRX MBP
did you preload the springs?
Old 08-29-2011, 09:35 AM   #594
Bio248
Member#: 223032
2006 Impreza 2.5i
CGM
sounds exactly like what he did. it does it over sudden dips in the road i bet. done that to my fronts trying to get lower, but it didn't work out and i ended up smashing the valve against the seals over medium to heavy dips on the road. took out the preload and put it back and now im better.
either way these things suck balls and im ready to move onto another set that is built a little (read: a lot) better. stance, here i come.
Bio248 is offline   Reply With Quote
Old 08-29-2011, 10:58 AM   #595
blakkboxer
Member#: 167244
2k3 WRX MBP
try some MDU's
my buddy has been on 'em for a year with no problem.. and he beats the crap outta his car
auto-x, off-roading, drag strip
Old 08-29-2011, 01:24 PM   #596
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
All I did was it was too low in the rear for me, So I just turned the lower spring perch up to lift it. Is that not the correct way to do so? Because as soon as I did that, It started making the slamming noise....?
Old 08-29-2011, 01:54 PM   #597
Bio248
Member#: 223032
2006 Impreza 2.5i
CGM
no, if you moved the shock body up with the use of the lower perch then you did it correctly. if you moved the upper spring perches up and put more load on the spring then you would have done it wrong.
are all the locking rings right how they should be? is the main strut shaft nut tight? something is probably loose right now. i know the bearings used in these mounts suck, but they shouldn't be making really loud slamming noises.
Old 09-14-2011, 05:45 PM   #598
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
So I have a new issue.... When I turn hard right, I get an insane vibration like my right front wheel is loose. I don't feel it in the steering wheel. And it's only on right turns, not left. I changed a bad wheel bearing on that side and I thought that it would fix it, but it didn't.... Any ideas?
Old 09-14-2011, 09:24 PM   #599
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
ball joint? axle?
lil'redwagon is online now   Reply With Quote
Old 09-14-2011, 11:03 PM   #600
xaaronex
Member#: 220822
2004 WRX STi
probably a bad axle.
xaaronex is offline   Reply With Quote
FS : Tein Coilovers melvijo05 NWIC Private Classifieds 8 09-12-2010 11:46 PM
ISC coilover install. wrxtuner13 Mid Atlantic Impreza Club -- MAIC 9 08-22-2010 01:32 PM
WTB : Coilovers for 06 WRX iRjOhn TXIC Private Classifieds 0 08-21-2010 04:41 PM
Message Board Statistics All times are GMT -4. The time now is 01:05 PM.
