Old 08-22-2010, 12:48 PM   #1
slaytalera
Member#: 163816
1999 Legacy Outback
Default Phase 2 2.5 in a phase 1 car?
I just spun a bearing on my 98 outback, and i was wondering if it was possible to use a phase 2 block with phase 1 heads...im just trying to get this thing up and running ASAP
slaytalera is offline   Reply With Quote
Old 08-22-2010, 07:32 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Yes you can.
~Josh~
Old 08-22-2010, 08:53 PM   #3
slaytalera
Member#: 163816
1999 Legacy Outback
Nvm45
Last edited by slaytalera; 08-22-2010 at 09:10 PM. Reason: answered my own question
Old 08-22-2010, 11:44 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Absolutely. Legos, man!!!
You may need to change the timing belt tensioner bracket if the new block doesn't come with one. I've put together DOHC motors with the newer style tensioner too, so I guess you can use whichever one you have, as long as the bracket is the right one for it.
Jay
Old 08-23-2010, 02:36 AM   #5
slaytalera
Member#: 163816
1999 Legacy Outback
any problem with the different oil pans? Should i swap them over? The motor is from an 06-7 RS and its going into a 98 Legacy Outback
2 teens killed in accident with cop car Max713 Off-Topic 360 11-22-2009 10:31 PM
Interesting car - Factory phase two 2.5 with DOHC heads and phase 2 4eat SUS! ciper Normally Aspirated Powertrain 13 11-17-2009 08:22 PM
Phase II 2.5 block with Phase I 2.2 heads gloyale Built Motor Discussion 4 01-19-2008 05:18 PM
I've had 2 whiskey sours in the last 1/2 hour. I'm 155 lbs... Stroke Off-Topic 13 01-17-2004 02:26 AM
Subaru 1, 2, 4, 5 in the top 10 at Baie suber General Forum Archive 1 07-09-2000 06:57 PM
