Old 08-22-2010, 08:39 PM   #1
myklwrx
Member#: 150791
2012 wrx sedan
Default hella supertones help
so ive had my supertones for years, they werent looking so good so decided since they needed some sprucing up i would match them to my wheels. have worked great since installed, painted, put back on and now all i get is a subtle clunk from each. any ideas?
also i have always had them hooked up to factory wiring, never used the relay that was provided. also took them back apart to see if maybe too tight/loose and connections seem to be good.
any input would be apprecitaed, thanks in advance!
myklwrx is offline   Reply With Quote
Old 08-23-2010, 12:19 PM   #2
myklwrx
Member#: 150791
2012 wrx sedan
any ideas guys?
Old 08-24-2010, 10:10 AM   #3
xTourniquet
Member#: 177477
2006 WRX Limited
Why aren't you using the provided relay? Seems like that would be pretty important IMO. Other than that...check voltages at each horn?
xTourniquet is offline   Reply With Quote
Old 08-24-2010, 10:12 AM   #4
Rhymesayer
Member#: 181389
13 Sti WRB
93 K20 Hatch
Could be anything. I get incredible wind noise from mine. I would have used the relay though.
Rhymesayer is offline   Reply With Quote
Old 08-24-2010, 10:26 AM   #5
xTourniquet
Member#: 177477
2006 WRX Limited
I would def try to re-install them with the relay. You could also try sanding the contacts and putting some dielectric grease on them.
Old 08-24-2010, 10:48 AM   #6
myklwrx
Member#: 150791
2012 wrx sedan
i have always just hooked them up to stock wiring, had a set on my old car set up the same way with no issuse so did the same on this one. im gonna give it a shot though, ill just start from scratch. re-do all wiring, sand contacts, and i know i have the relay somewhere. thanks for the input!
Old 08-24-2010, 03:35 PM   #7
Haelan
Member#: 151045
2013 Subaru STI
CBP
I have mine going through the stock relay as well--no problems.
The bare metal of the horn needs to be connected to the engine chassis for grounding purposes. If you painted over all the surfaces you're going to have a very high resistance circuit and the horn will not work. Clean off the paint where the bracket connects to the frame and try again.
Haelan is offline   Reply With Quote
FS : Hella Supertones Horns $45 shipped BRAND NEW! wrxslim Exterior/Styling 6 08-24-2010 03:25 PM
hella supertone help!? smithrcing17 Electrical & Lighting 8 04-07-2009 04:48 PM
Hella Supertones help. Jcrite8987 Newbies & FAQs 23 07-29-2008 02:29 AM
hella supertone help cleofis Bay Area Impreza Club Forum -- BAIC 2 06-19-2004 08:46 PM
Hella Supertones help! orndog Electrical & Lighting 20 08-02-2003 02:05 AM
