Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-21-2002, 05:12 AM   #1
WRXTACY
Member#: 15339
2015 WRX
CWP
Default Will the WRX ever get cams? cam gears...shafts...?
I always hear my friends talking about engine build up, they have like Si's and GSR's and because I have a WRX I wonder if there will be cams for our car? Is it because boxer engines are different? Or are they still in development? I hope we can squeeze more power out of our engine alone. thanks
WRXTACY is online now   Reply With Quote
Old 06-21-2002, 08:50 AM   #2
mayhem
Member#: 19985
2003 Evo 8
yes, if aftermarktet performance cams were created power gain could be obtained, but not without a big price tag. the power you get is not worth the $$ when compared to turbo mods. labor for replacing cams(something i wouldn't do without an experienced mechanic) would probably cost 2-3 times the amount of the cams. but if you have an n/a vehicle and plan on staying n/a that's another story.
chris
mayhem is offline   Reply With Quote
Old 06-21-2002, 11:39 AM   #3
Drover
Guest
Member#:
Default Re: Will the WRX ever get cams? cam gears...shafts...?
I suspect the biggest factor is simply quantity. For every Impreza out there in the world, there's about 815 billion Hondas/Acuras. There's simply a much bigger market for the Honda parts, and economies of scale makes it cheaper per unit to build parts for those cars.
Also, don't forget that Subarus have 2 cylinder banks whereas the Si's and GS-R's only have one. Twice the parts, twice the labor... do the math.
Old 06-21-2002, 10:13 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The WRX cams are tuned for pretty high RPMs as is for a single lobe (i.e. not vtec) camshaft. People are making peak power around 62000 RPM or so on modified engines. The TGVs partially compensate for the lower RPM cleanliness/stability, but people already complain about the rough idle, which is at least somewhat due to the cam profile.
Also, due to the rest of the valvetrain, higher lift camshafts often are not just drop in items, meaning you have to replace more than just the camshafts. The fact that it's a split motor means there are four camshafts also, not just two, increasing the price.
With cams costing several hundred, and valve springs, etc... costing a thousand or more, and installation another several hundred, for relatively small gains (for the money spent), there just isn't much of a market for them right now.
Cobb has a cam profiles for different levels of performance though, if you really want to do cams, but there's a whole lot more bang for the buck before you get there.
Concillian is offline   Reply With Quote
Will The Slickster Ever Get To Go Home? BSLICKOH Off-Topic 12 01-02-2007 03:49 PM
Will the French ever admit that the Allies saved their asses? Layman Off-Topic 30 08-26-2004 03:36 PM
Will the STi ever be on the Subaru.ca site ??? Extraze Canada Region Forum 0 07-05-2003 04:02 PM
Will the US ever see the B4? RocketJohn News & Rumors 24 10-19-2001 05:44 PM
