Old 08-24-2010, 12:09 AM   #1
d0ugch0i
Member#: 198861
2004 WRX
Default 02'-05' Side Skirt Rubber Trim
ok so the rubber trimming on my sideskirt is starting to fall off. i cant seem to keep it in place. i tried superglue but that isnt really helping at all. any help?
d0ugch0i is offline   Reply With Quote
Old 08-24-2010, 12:50 AM   #2
subaru3169
Member#: 55252
* pullup bar *
have you tried taking the entire thing off and then reapplying the strip??
subaru3169 is offline   Reply With Quote
Old 08-24-2010, 01:02 AM   #3
d0ugch0i
Member#: 198861
2004 WRX
yea they entire thing fell off. im asking how should i reapply it because you obviously cant just put it back on. there used to be some type of adhesive on there from the factory.
Old 08-24-2010, 01:03 PM   #4
d0ugch0i
Member#: 198861
2004 WRX
anybody help?
Old 08-25-2010, 10:39 AM   #5
d0ugch0i
Member#: 198861
2004 WRX
hellpp...
Old 08-25-2010, 11:04 AM   #6
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
You can just eliminate it as well.
coolblue05 is offline   Reply With Quote
Old 08-25-2010, 02:09 PM   #7
d0ugch0i
Member#: 198861
2004 WRX
ehh..i think the skirt without the rubber trimming looks a little awkward.
Old 08-25-2010, 03:29 PM   #8
subaru3169
Member#: 55252
* pullup bar *
just try the superglue again.. just make sure where you're applying is absolutely clean.. then dab some glue spot by spot, slowly.. it should be ok
Old 08-25-2010, 03:32 PM   #9
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
It looks just as good if not better. I have done it before with good success...
Old 08-25-2010, 03:49 PM   #10
blue-sun
Member#: 15934
blue-sun is offline   Reply With Quote
Old 08-26-2010, 12:17 PM   #11
bpcrally
Member#: 208408
2004 WRX Wagon
mines not glued. and wasnt from factory..
i took mine off when i painted my side skirts.. and then put it back on when i was done, no issues.. i dont see why you'd need glue when it doesnt even come that way from factory?
bpcrally is offline   Reply With Quote
Old 08-26-2010, 04:56 PM   #12
subaru3169
Member#: 55252
* pullup bar *
they did come that way from the factory.. not glue though but the stuff on the sticky side of tape is.. it's just not noticeable coz it's not that sticky loses adhesiveness really quickly once it's taken off
Old 08-27-2010, 02:17 AM   #13
d0ugch0i
Member#: 198861
2004 WRX
yea i tried sticking it back on but it doesnt hold in place. if you swing the sideskirt it just falls right out. also if you nudge it a bit it tends to move out of place.
Old 08-27-2010, 02:50 AM   #14
pnutbutta
Member#: 192572
2007 Impreza
CGM
what about a hot glue gun?
pnutbutta is offline   Reply With Quote
Old 08-27-2010, 11:14 AM   #15
CpnNeeda
Member#: 20060
02 WRX
Midnight Black Pearl
How about Epoxy or JB Weld, if you're really serious about it not coming off.
CpnNeeda is offline   Reply With Quote
Old 08-28-2010, 05:30 PM   #16
d0ugch0i
Member#: 198861
2004 WRX
havent tried the hot glue gun nor the epoxy/jb weld. ill try it out this week.
Old 08-28-2010, 07:00 PM   #17
EROC263
Member#: 96887
I just had some collision work done and the rubber piece on the front splitters (STi) was pulled off by the body shop. I was able to clean the area really well and apply a small bead of weatherstrip adhesive to the inside. This seems to have worked well. I just wiped any excess off of the visible areas and it turned out great. Also not to be OT but I found rubbing alcohol and a scotch brite no-scrub scrubbing pad/sponge (blue ones) seemed to get the rubber clean fairly easy.
EROC263 is offline   Reply With Quote
Old 08-29-2010, 12:36 PM   #18
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
are you sure were all talking about the same piece on his car? lol
Kupkake is offline   Reply With Quote
Old 08-29-2010, 06:43 PM   #19
EROC263
Member#: 96887
I think so. Pics would clear it up for me.
Old 08-29-2010, 06:44 PM   #20
subaru3169
Member#: 55252
* pullup bar *
i never really thought it'd really fall off after putting it back on=/
i've taken mine off and put 'em on another set of sideskirts and they held up fine.. just maee sure it's completely on straight before putting the clips back on the bottom
Side skirt rubber seal question. Benjer Car Care & Detailing 9 06-02-2010 06:43 AM
WTB WRX side skirt rubber trim scoobynoobEMT Private 'Wanted' Classifieds 0 03-17-2009 11:35 AM
FS: 02-04 OEM wrx side skirt bubber trim (black) nelli-son Exterior/Styling 13 02-03-2009 11:24 PM
Side Skirt rubber trim? Slowsoul Interior & Exterior Modification 4 07-27-2008 08:06 AM
FS: Brand New Side Skirt Rubber Molding Killian Maynard Private 'For Sale' Classifieds 1 01-13-2005 09:58 PM
