Old 08-24-2010, 08:43 PM   #1
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
Default Oops they rub..what now?
So I just bought a set of tires and wheels from The Tire Rack for my MY99 2.5RS. Everything was green no fitment issues. I get the goods, install, check for rubbing and all is good. Take a road trip on the highway, and I get rubbing on the sidewall (not a good place for it IMO). I was thinking some stiffer springs might help (Tire Rack won't take em back because they have already been installed). What would my options be? The Wheels are 16x7.5 +48ET with 205 55 16 tires.
JerryDodrill is offline   Reply With Quote
Old 08-24-2010, 08:45 PM   #2
cazwrx187
Member#: 176592
2002 WRX-Sold
1998/04 Unicorn RSTi
Where and what are they rubbing on?
cazwrx187 is offline   Reply With Quote
Old 08-24-2010, 08:50 PM   #3
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
It looks like some molding on the inside of the fenders. I'm a bit reluctant to remove it because of salt during the winter (rust), but I guess a little bit of plastic isn't keeping out salt water .
Old 08-24-2010, 08:52 PM   #4
cazwrx187
Member#: 176592
2002 WRX-Sold
Little black rubber molding on inside of rear fenders? Yank it off. I live in NY and did this last year when I rolled my fenders. Don't worry about rust.
If it still rubs on the metal, have your fenders rolled.
Old 08-24-2010, 10:06 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
yer too low
Old 08-25-2010, 10:23 AM   #6
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
I am looking at EXACTLY what you ordered and it should not rub ... is your car modified at all? Is it rubbing on both side or just one? Is it only thast plastic trim piece on the rear fender liner? camber settings?
Old 08-25-2010, 10:15 PM   #7
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
Its bone stock, no mods at all. Rubbing on the outer tire sidewall right across the Kumho logo. The molding is worn from the rubbing but no other signs of wear. I haven't taken the molding off yet because it looks like I'll only get 3-4mm out of it, may be enough but there is a nice sharp blade edge underneath it that I really wouldn't want playing with the sidewalls. Could this be a worn spring or shock issue? I'll get some photos up tomorrow.
Old 08-25-2010, 10:48 PM   #8
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
You have a bunch of sand bags in your trunk?
Krang is offline   Reply With Quote
Old 08-25-2010, 11:08 PM   #9
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
LOL no sandbags. Trunk is empty aside from the spare.
Old 08-26-2010, 09:28 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Something is broken if your car is riding low enough to scrape the sidewalls on the inside of the fender. Do you have any pictures of your car, like a good profile shot?
Here's what appears to be a stock 2.5RS:
You'd have to compress the suspension about 4" to get the sidewalls to rub anything inside the wheel wells.
Pat Olsen
Old 08-27-2010, 08:48 AM   #11
Saj5DJ
Member#: 209669
1997 Miata
More likely that the plastic molding isn't sitting right. Check if there are any clips missing, debris building up behind it, etc.
Happened on my '09 with the stock wheels and tires, I broke a clip and the molding was sitting an inch or so too far outboard.
Saj5DJ is offline   Reply With Quote
Old 08-28-2010, 12:12 AM   #12
dangerousatom
Visiting NASIOC Timeout
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
You most likely have a saggy butt AKA old tired springs
rolling the fenders would probably fix the issue...like $75-100 to get the rears done
dangerousatom is offline   Reply With Quote
Old 08-28-2010, 01:39 AM   #13
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
Trying to figure out how to load up the photos to show how the car sits. After comparing to the blue photo I am sitting 2-3 inches lower.
Old 08-28-2010, 11:05 AM   #14
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
Crossing my fingers that this works
Old 08-28-2010, 11:08 AM   #15
JerryDodrill
Member#: 23235
1999 Impreza 2.5RS
Excellent looks like it worked. So it sounds like I can either A-get new springs, or B-roll the fenders to fix the rubbing? I don't think there is anything wrong with the plastic molding but I'll check into that too, since its the weekend.
Old 08-28-2010, 11:30 AM   #16
Boxologist
Member#: 21118
if u have tired springs on a 10 year old car and have never replaced the struts, those are on the way out too.
Boxologist is offline   Reply With Quote
Old 08-28-2010, 01:09 PM   #17
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
roll them, my old rs had 17x7s and the spt springs and it rubbed like nobodys buisness. The fender lip is huge on an rs and the rubber peice is even worse
feint05 is offline   Reply With Quote
Old 08-29-2010, 10:09 PM   #18
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
beet your offset isnt what you think it is on those wheels
Old 08-29-2010, 10:32 PM   #19
dangerousatom
Member#: 70710
I have 17x225x45 on my 97 OBS wagon with only rolled fenders up front and its lowered. Im seriously thinking you have issues that need fixing before rolling fenders.........your offset maybe way off Suby standards
Old 08-29-2010, 10:37 PM   #20
subaru3169
Member#: 55252
* pullup bar *
imo rolling is only covering up the symptoms and not solving the real issue
since your struts/springs are completely stock, are they the originals that came on your car brand new?? if so, then it is most definitely time to replace both and get aligned
check the wheels as well like scotty said, those size tires should NOT be rubbing at all
subaru3169 is offline   Reply With Quote
225/45R16 Tires.... anyone run them? Do they rub? Texas25RS Brakes, Steering & Suspension 4 06-06-2011 10:29 AM
235/40/18 will they rub? revelation Tire & Wheel 3 06-10-2003 03:17 AM
225 50 16 on RS rims, will they rub with eibach springs and kyb? WRxednEffect Brakes, Steering & Suspension 2 04-13-2002 05:16 PM
got my 18x7.5 and they rub slightly (and a few pics) scootr Brakes, Steering & Suspension 5 05-25-2001 12:38 AM
prodrive wr suspension and 215/45ZR17....will they RUB? spt_impreza Brakes, Steering & Suspension 11 12-16-2000 10:49 AM
Message Board Statistics All times are GMT -4. The time now is 10:00 PM.
