Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Old 06-21-2002, 12:27 PM   #1
redrex3
Member#: 8742
red
Default Does the '02 WRX wagon and sedan....
.....share the same struts?
redrex3 is offline   Reply With Quote
Old 08-22-2002, 12:00 AM   #2
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
bump??? I've searched around and from what I can tell it appears as if the rear struts are different but can anyone give me a definitive yes/no answer?
Thanks, Joe
veloLexus is offline   Reply With Quote
Old 08-22-2002, 12:18 AM   #3
blkwgnboba
Member#: 18725
2002 WRX Wgn
Blk
Default No.
The sedan has a wider track. The struts have a slightly different hole placement on the bottom of the strut. You could technically bolt up a sedan strut on a wagon but the camber would be off by as much as 2 degrees. You could also remedy this by use of camber plates at the top of the struts, and camber bolts in the rear. But in the end, that doesn't change that sedan struts are "different" than wagon struts.
blkwgnboba
blkwgnboba is offline   Reply With Quote
Old 08-22-2002, 01:33 AM   #4
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
Thanks, that's what I was after. Joe
Old 08-22-2002, 01:10 PM   #5
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
just to add, i had a similar question a while back, and someone was nice enough to post the actual differing part numbers in order to help illustrate that the struts were different. Here are the part numbers if you are curious or need them in any way:
20310fe040 wagon front rh
20310fe050 wagon front lh
20310fe140 sedan front rh
20310fe150 sedan front lh
20360fe040 wagon rear rh
20360fe050 wagon rear lh
20360fe140 sedan rear rh
20360fe150 sedan rear lh
Cosworth is offline   Reply With Quote
Old 08-22-2002, 01:17 PM   #6
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
Thanks, FWIW a set of new struts would cost about $365 from Subaruparts.com.
Cheers, Joe
'02 WRX wagon and '04 WRX wagon exhaust interchangeable? nysnowthrowin Newbies & FAQs 6 01-22-2007 12:57 PM
FS STI replica Rear Strut Tower Brace 02+ WRX wagon and sedan manchild83 New England Impreza Club Forum -- NESIC 0 01-22-2005 04:01 PM
differences between WRX wagon and sedan - other than the obvious ufoguy Newbies & FAQs 44 10-31-2003 10:19 PM
Are wagon and sedan bumpers the same? Rally1 Newbies & FAQs 11 04-21-2003 04:50 PM
wrx wagon and sedan the same???? haulin-wrx Newbies & FAQs 5 02-04-2002 08:42 PM
