Old 08-01-2011, 12:13 PM   #101
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I think he's asking you what you do about fuel and oil starvation?
BeBop86 is offline   Reply With Quote
Old 08-01-2011, 04:31 PM   #102
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
i don't really ever run into any problems with fuel and oil starvation. I empty the oil catch can back into my oil filler pipe whenever it gets full and check the oil all the time.
Edit: With regards to fuel surge, I never experienced a problem, even when the car was below 1/4 full. I looked into building a surge tank for the car but decided not to as i feel the stock fuel tank is designed very well so it is hard to get fuel starvation in the system. Once i'm running the new setup more I'll consider it but i think the stock design is good.
djelly84 is offline   Reply With Quote
Old 08-21-2011, 01:33 AM   #103
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
so prolly should be worried about the whole engine dying issue, but i've wanted to build a crash bar for awhile and also want to start learning how to fab stuff with tubing. Well, since i'm low on cash I thought what better way to get my hands dirty learning how to bend tubing and MIG than by building my own crash bar/ splitter support.
Borrowed a friends tube bender and my buddy Dustin's 120 MIG, got some tips and advice, and went at it.
it was a pain but here are the results so far. I think it turned out well. I'm just glad it works with both bumpers I have...even though I will be rocking it bumper-less a lot. That't the point right.
Old 08-30-2011, 12:37 PM   #104
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
footage from this past weekend, with my buddy Dustin romping around in the suby:
Old 09-03-2011, 12:36 AM   #105
tunermt
Member#: 158767
Damn fine work my friend and great to see the subi making it out to every track event! Alex will be down to your location shortly with the 240
tunermt is offline   Reply With Quote
Old 09-21-2011, 12:02 PM   #106
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
new edit from this past weekend...Snookie looks a bit different...
Old 09-21-2011, 12:21 PM   #107
PERRIN_Chris
Member#: 186665
2014 BRZ
Wow, that track looks awesome, tons of runoff, and it's nice and wide. Wish we had something like that in Portland!
PERRIN_Chris is offline   Reply With Quote
Old 09-23-2011, 06:41 AM   #108
tunermt
Member#: 158767
Lookin like fun out there brother wish i was sliding with ya!
Old 11-27-2011, 11:22 PM   #109
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Default The real build begins...
So been awhile since I updated my build thread.
So the September Firebird Raceway drift event was insane. They ran main track in the XDC layout, which involves a 70+mph entry, long right, into a long horse shoe double left. I ended up spinning at the end of the horseshoe on one attempt and nailed the drivers side rear corner into the wall. Luckily I had removed my rear bumper beam (for weight reasons haha) or the frame would probably be toast. With the frame off the rear corner basically just crumpled in.
All the damage was behind the rear sway bar mounts, which didn't move, the drivers side rear frame creased about 3 inches behind the rear sway bar mounts. There was no damage that affected how the car drove, so I kept drifting! Fukitdude!
My friend Dylan from Eleven's let me borrow his Porto Power body jack, which did miracles on the damage.
Had to get creative to do some of the bending, but worked out (my house didn't crumple!) and i feel it looks ok for the time being.
I'm cutting out the rear corner from a local guy that totaled his 04 WRX from a front collision but i'm prolly going to wait and weld that in at a later time. Got creative and I kind of think it adds character!
Here's a pic from the November 11th event, which was the last time it has been driven (see next post)...
Old 11-27-2011, 11:53 PM   #110
CWLTT
Member#: 239283
2016 CWP STI
VF 2002 WRX (old)
i like it with the bruise... adds some real character.
CWLTT is offline   Reply With Quote
Old 11-28-2011, 12:20 AM   #111
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Default Engine Bay madness
So yeah, November 11th event...car was barely alive. I had repaired the rear corner enough to drift, but the engine and steering were a totally different story.
Engine...no power. I have been having a ton of oil blow by and suspected low compression for awhile, but hadn't actually done a test. At the event the car felt like total crap. Literally had to start 10 ft back behind the start line, get into third and then throw it hard and clutch kick to get the rear to kick out. I'm guessing I might have had maybe 160hp if I was lucky. It was insane.
Steering. Just felt weird. To describe it, it felt like bushing slop/play. Or kind of like if your camber bolts and top hats were not tight at all. The steering felt all loose and sloshy, really crappy and kind of scary. But i couldn't figure it out, everything checked out fine and I eventually just relied on throttle steering everything (with what little power I had).
I still haven't rebuilt the rack but this is what I suspect: I swapped in a old impreza L FWD rack because it actually allows for roughly 10 degrees more angle (but is a slower ratio...not that big of a deal for drifting). So basically doing this mod is like adding rack spacers to allow the rack to travel more and give you more angle. However when I did this, I noticed the rack had a different output shaft coming from the rack gear (the part that interlocks with your steering column. Therefore I used the wrx gear and output shaft in the GC rack. I feel this either loosened over time or something so that the gears aren't mating correctly. I'll be looking into it and will let you know.
SO, after the event did a compression check: 135-120-125-50. Like so many other subaru owners, I am victim to the poor design of the boxer: running lean and oil starvation in cylinder #4. I suspect the ring seized as i ran the motor for a while after it starting having blow by, but yeah it got worse over time.
Oh well, time to pull the motor and get serious!
Funny timing but my roommate Alex has a older Legacy Wagon and guess what...cylinder 4 just crapped out! His showed 0 compression (turned out one of the intake valves has a big ol piece cracked off it)!
Pulling Suby engines...a nice Wednesday night household activity.
So yeah, I'm now building my EJ22t with built v7 ej207 heads. Stock crank, stock rods, custom pistons to match the 2.0l heads with oversized valves and 272 kelford cams. I'm working on removing everything unnecessary, tucking all things necessary, and going all AN out all over the place! In terms of the exhaust manifold and turbo, I was initially thinking on getting the new legacy GT manifold and modifying it for A Garrett twinscroll flange, the manifold is a totally different equal length and twinscroll design with the turbo up front and low. Awesome for reducing the amount of tubing needed for a front mount and exhaust setup right out the front bumper. I'm now leaning towards holding off on this plan and going with a conventional header design...maybe twin scroll if i can get hooked up somehow...we'll see. Turbo is almost certainly going to be a GTX3071R.
In terms of the engine bay, i'm tubbing the fenders, notching areas for more steering angle, and making a v-mount setup.
The start.
Where the wheel is rubbing (17x9 +17 on 245r40s... -2.75 camber, modified GC knuckles, Impreza L FWD rack):
The wheel rubs the frame rail in the front right where the cross member bolts up...thus you can't notch in too far unless you change how the cross member attaches. I'm already running +17 offset and sometime I run spacers up front, but I still wanted to do everything I can to give me more clearance. Whoever says suby's can't get angle...that's a lot of rubbage...or should i say tubbage...
Old 11-28-2011, 12:21 AM   #112
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Default Tubbage!
Here's what I did about it:
More to come.
Old 11-28-2011, 12:38 AM   #113
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Default Steering wheel!
Forgot to add this, wrapped some OG steering wheel my buddy Dylan gave me with road bike handle bar tape! I have to give credit to my buddy Dustin for the idea. I like the look and thought this was an awesome, cheap and easy way to make a unique steering wheel!
Old 11-28-2011, 01:32 AM   #114
tunermt
Member#: 158767
bald to the nate
Old 11-28-2011, 02:01 AM   #115
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Love the car. The steering wheel reminds me of a diaper though.
100_Percent_Juice is offline   Reply With Quote
Old 11-28-2011, 08:44 AM   #116
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
^haha i can see that. The white gets dirty easy too, I've gotta wear little white gloves like Morgan Freeman in Driving Miss Daisy haha.
Old 11-28-2011, 11:16 AM   #117
imaiami
Member#: 151287
dude, tubs came out verry nice
imaiami is offline   Reply With Quote
Old 11-28-2011, 02:15 PM   #118
Eww Evo
Member#: 299687
TT3
06' Wrx Project
Damn. Nice stuff!!
Eww Evo is online now   Reply With Quote
Old 01-12-2012, 11:31 AM   #119
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Default V-mount
Here are pics of the v-mount setup I fabbed over the Holidays.
It is a pretty simple design. The bottom of the radiator mount is built off the stock bumper beam using .75", ~1.2 thick square tubing (got it from the scrap area . I cut the stock bumper beam around the mounting area so it fit behind my crash bar which I had previously built. The bottom of the radiator sits roughly an inch behind and 1.5" above the bottom of lower bar of the crash bar, which sits flush with the bottom of my front bumper.
For the main mounts for the radiator & intercooler, I had 4 tabs welded onto the rad/ IC to connect the two at exactly a 90 degree angle. I built triangle bars in towards the engine on each side from the stock bumper beam which mount to these tabs. My ducting also bolts to the inside of the tabs. The intercooler is held at a 90 by another tab in the back to the top of the radiator.
In order to get the placement of the setup where I wanted, I completely cut out the core support of the car. I actually like this as I can easily remove the front of the car and have easy access to the engine. Right now there is no lower core support, which is normally the bottom mount for the radiator, and which the front of my RPM subframe/ and the stock subframe also, is normally connected to by two bolts. I am planning on builting a new lower core support that will clear the radiator fans for the v-mount and where the subframe will mount to. In the pictures below the middle bar of my crash bar is cut out, I am planning on welding in another bar here, and bending it up so it is hidden from view by the middle of the bumper.
Cost: square tubing - $5, aluminum plating and tabs - $6, wire, gas, electricity ~ $15, couple cut off wheels ~ $4, having tabs TIG welded by a local shop- $40 TOTAL = $70.
Time: I estimate the entire thing took me roughly 8 hours spanned over two weekends. I work pretty slow haha.
As I am an auditor at a public accounting firm, this is the busiest time of the year for me. This weekend will probably be my last free weekend where I'm not working weekends for a couple months. I'm planning to do a complete cage build within two days using a propane torch to heat the metal and a 120v MIG. Right now all I have done is removed the top dash and interior and bought the supplies. And I plan to party Friday night...this will be a ghetto rigging miracle if completed.
Old 01-12-2012, 07:10 PM   #120
nick516
Member#: 178134
2004 jbp wrx wagon
java black
Sickiesss. Cant wait to see that cage and some more vids. Nice to see other fellow rollers here.
nick516 is offline   Reply With Quote
Old 01-13-2012, 01:23 AM   #121
tunermt
Member#: 158767
EPIC, great work my friend!
Old 01-13-2012, 02:02 AM   #122
Go350zGo
Member#: 197154
your tub fab work is too on point
Go350zGo is offline   Reply With Quote
Old 01-13-2012, 11:48 AM   #123
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
^ lol can't tell if you are serious. If you are, thanks a lot! Yeah, all in all, its nothing professional, but I felt so far everything has come out pretty good for being done by an accountant in his garage!
Eric, thanks bud! It definetly helped having the Brewed 240 (below) sitting 10 feet away for reference!!! Alex is taking really good care of her don't worry!
Return my email punk!
Thanks everyone for the kind words! Also wanted to spill a little secret that recently made some awesome advancements with working with my friend on getting a dual rear caliper brake mount that works for Suby's...so i'll soon be testing that out!
Old 01-14-2012, 03:28 AM   #124
tunermt
Member#: 158767
dont remember how the rad hoses are set up on your whip but remember you can always do a dual pass rad set up if you want the inlet and outlet on the same end tank
Works like a charm!
Old 01-14-2012, 11:03 AM   #125
just Touge
Member#: 220530
2006 Impreza WRX
Crystal Grey Metallic
This rocks, DIY, car that gets used and it looks pretty cool.
just Touge is offline   Reply With Quote
