Old 05-07-2001, 02:15 PM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Post Wheel bearing trashed!
rear passenger wheel bearing is shot...going to dealer to get replaced tommorow 270 bones
on the bright side....they have 7 wrx's in stock that Greg is going to atempt to test drive " not all 7" any words of advice in talkin to the dealer to let me drive it!!!
also saw a white wrx wagon and a red wrc sedan at wilmington nc... sat the red sedan looked a little strange the guy driving the wagon had a big kyak on the roof any way im out...
late
Greg www.jdmracing.com
GregBolby is offline   Reply With Quote
Old 05-07-2001, 03:04 PM   #2
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Thumbs up
Greg, If you've got a bench press and large set of sockets, you can change it out yourself. Its very easy, I pressed out the old bearing, cleaned everything up, pressed in the new bearing and seals on my lunch hour. It only took about 45min to get the whole assemble off the car. The parts will cost you around $85 and you could put that other $185 into some cool, go fast stuff.
Regards,
Chris
FletchMY98 is offline   Reply With Quote
Wheel Bearing or Diff Carrier Bearing? flyingtaco Transmission (AT/MT) & Driveline 12 08-30-2009 01:49 PM
Wheel bearing removal: disintegrated wheel bearing eurojax Brakes, Steering & Suspension 4 06-23-2009 10:28 AM
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease Gro Harlem Suspension/Brakes/Handling 9 03-04-2009 10:35 AM
Wheel bearing vs wheel bearing assembly? Trin_Starr Legacy Forum 2 10-19-2006 08:42 AM
are front wheel bearing on Impreza'a press in bearings? Homemade WRX Transmission (AT/MT) & Driveline 7 10-22-2004 09:33 AM
