Old 08-26-2010, 10:58 PM   #1
ZenBoy
Member#: 12524
2004 STi
WRB/Gold
Default '00 2.5RS - Odd sunroof behavior after electrical fix
This past spring, my sunroof "died". I did the standard diagnoses...pulled the sunroof motor, which worked fine, and checked all of the voltages into and out of the relay. Everything seemed fine, but it still didn't work.
The dealer found that problem - the relay was heating up with use, resistance went up, and voltages went down. Brilliant. Problem solved, right?
Not completely. Now its behavior isn't quite right.
Normal behavior:
- Press OPEN button - Sunroof tips up and stops.
- Press OPEN button again - Sunroof opens all the way.
- Press CLOSE button - Sunroof closes halfway.
- Press CLOSE button again - Sunroof closes completely.
My sunroof's behavior:
- Press OPEN button - Sunroof opens all the way.
Occasionally, the first press of the OPEN button does nothing, but then the second press opens it all the way.
Suggestions, anyone? The ONLY thing I can think of is that the motor is what stops the sunroof after tipping up on the first OPEN button press, and that the motor and sunroof linkage have somehow gotten out of sync....
ZenBoy is offline   Reply With Quote
FS: Complete swap from '00 2.5rs and '00 white coupe trunk with wing Cyclops NWIC Private Classifieds 65 02-11-2010 10:34 AM
Yakima rack on 01 2.5RS and sunroof issues yeos Interior & Exterior Modification 0 09-11-2008 07:02 PM
Engine swap, '06 2.5i into '00 2.5RS--Direct swap? singincanary Subaru Conversions 13 10-01-2007 09:47 PM
'02 2.5RS TRANNY into '00 2.5RS?????? 4WDRFT 74 Transmission (AT/MT) & Driveline 1 09-26-2004 11:25 PM
'00 2.5RS 4-dr vs. '00 Integra GS-R 4-dr--What to buy??? jmcn General Forum Archive 23 05-31-2000 12:37 AM
