Old 06-21-2002, 05:30 PM   #1
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Smile Track Alignment?
I am wondering what you track junkies run for alignment on the track. I have my first track day next Thursday. I have a 98 wagon with the stock OBS suspension, 18-22mm bar, and soon-to-be Azenis. I know that I should make the toe 0 front and rear, and max out the front camber. But what about the rear? I don't think it is adjustable is it? I know that 0 is good for auto-x, but I want the back end planted on the track. Should I put the rear bar back to 18mm?
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 06-21-2002, 07:23 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Seth - Rear camber and caster are not adjustable, so you're stuck with whatever the factory gave you. I would suggest going to 18mm on the swaybar just to be on the safe side for your first event. Then again, I've never driven The Egg so I don't know how tail-happy it is with whatever setting you're on now. If you decide that 18mm isn't enough it's not hard at all to change the setting at the track - hell, Ray and I did it on the Legacy at Las Vegas Motor Speedway, and that was with the car riding 1" lower than stock (so probably 2"+ lower than your OBS).
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 06-22-2002, 01:02 PM   #3
HoRo1
Member#: 15618
Post
I made the tragic error of running at Streets Of Willow Springs in SoCal (very tight and twisty) with -1.75 camber at the rear (rear camber IS adjustable - just get a very big hammer ) and only -1 at the front and had a VERY unhappy time. Run with as much negative camber as you can ge at the front (you may eventually want to install camber plates) and as little as you can tolerate at the back. Running with less than -1 at the back can begin to induce oversteer (some like it). I will run something like -2.5 at the front on the track and -1 - -1.25 at the rear.
HoRo1 is offline   Reply With Quote
Old 06-22-2002, 01:06 PM   #4
HoRo1
Member#: 15618
Sorry Seth
I only just realised that you don't drive a WRX. I don't know what settings will work on your wagon.
Old 06-22-2002, 11:08 PM   #5
jamz
Member#: 8725
2013 Black Company
Annalist
You could ask/PM sean- he used to drive a 98 OBS at various tracks/rallies/rally-x's a lot. I don't know if he ever fooled around with alignmnt or not, though.
jamz is offline   Reply With Quote
6/4 atco track rental 03 RS Tri-State Area Forum 3 06-03-2010 03:23 PM
street and track alignment? elirentz Brakes, Steering & Suspension 8 10-11-2006 04:22 PM
WRX Track Alignment LoveRoadRacing Brakes, Steering & Suspension 7 11-07-2005 05:41 PM
Quick Track alignment question.... TubeDriver Brakes, Steering & Suspension 3 07-26-2005 03:12 PM
autox alignment vs track alignment BIGSKYWRX Brakes, Steering & Suspension 2 06-23-2002 08:27 PM
