Old 08-27-2010, 07:54 AM   #1
highti_ed
Member#: 190385
2008 Impreza
Question Trailer wiring 08 Impreza 5-door?
Has anyone found a way to do this yet?
When I researched this car, I checked that I could put on a hitch, but didn't check that wiring kits were available.
The hitch install went smoothly, and I've spent several hours pulling out carpet and trim, looking for a convenient place to tap into the existing harness to add the trailer wiring, but still haven't been able to figure out where to attach.
Someone a little more enterprising than I must have done this by now....
Anyone?
Thanks,
Dave
highti_ed is offline   Reply With Quote
Old 08-27-2010, 09:36 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
hmm, i thought yours came with a plug hidden in the light area. if not, just tap the wires behind the light
PARANOID56 is offline   Reply With Quote
Old 09-23-2010, 07:28 AM   #3
highti_ed
Member#: 190385
2008 Impreza
If there's a plug, it's very well hidden. I've done this before on an '01 Forester, a '98 Legacy, and an '05 Legacy Outback and they've been easy to find.
On the Impreza, the lights are mounted outside of the wall of the trunk area and I haven't been able to track where they come back to hit the main harness.
I've seen a harness diagram that names a couple of connection points that should be easy to tap into, but I haven't been able to locate them physically within the vehicle.
Any help greatly appreciated.
Dave
Old 10-04-2010, 08:02 AM   #4
highti_ed
Member#: 190385
2008 Impreza
Default mission accomplished
I installed a wiring harness this weekend. Pulled out the taillight assemblies and loosened or removed enough plastic trim in the cargo area to get at the wires I needed to attach to.
Had to use a splice-in harness, as there was no trailer-ready plug to tee from.
I could have made all the connections behind the plastic panels, but that would have required removing them entirely. Instead, I pushed wires through the grommets and made connections near the connectors at the light assemblies. Tapped into the cargo area light's harness for power for the converter module.
Took about 90 minutes.
I still don't understand why the coupe models are towing-ready, but the 5-door is not supposed to tow at all.
DIY: Painting tail lights Impreza 08-09 5 door Mr.Durden Interior & Exterior Modification 57 11-17-2012 08:33 PM
FS: (Nor-Cal) curt hitch receiver for 08-10 impreza 5 door/hatch rox Exterior/Styling 8 09-23-2010 02:38 PM
17x8.5 wheel. What tire for 08 Impreza 5 door? thermobox Tire & Wheel 12 06-19-2010 09:33 AM
Factory 08 OBS / Impreza 5-door cat-back exhaust pointjg Engine/Power/Exhaust 0 05-03-2010 08:17 PM
08 Impreza 5-Doors... protect your antenna! sanders Impreza Forum 19 07-28-2008 12:51 AM
