Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 08-27-2010, 03:07 PM   #1
PseudoKirby
Member#: 203835
2000 2.5RS
Default My 1.8 to 2.2 Swap
SWAP TIME
my 1.8 went out and I am going to wait on the 3.3 swap in favor of my MR2 build,
Can I do the swap with just the engine itself, I don't need the 2.2 wire harness or the ECU do I?
95 2 Door GM8 Automatic Transmission
PseudoKirby is offline   Reply With Quote
Old 08-27-2010, 06:26 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
EJ22 is a direct drop in motor for you, just swap your intake manifold over to the new engine and you're good. Don't be surprised to see a knock sensor on the block, and no wire to plug it into. The EJ18 doesn't have a knock sensor.
~Josh~
Old 08-28-2010, 10:01 PM   #3
PseudoKirby
Member#: 203835
2000 2.5RS
why does the intake manifold have to be swapped exactly?
Old 08-28-2010, 10:05 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Lots of small things are different. IAC, some sensors, wiring. It's just easier to swap the whole manifold over in one shot than deal with all the little differences.
Old 08-29-2010, 05:31 PM   #5
PseudoKirby
Member#: 203835
2000 2.5RS
ok, there is a nut on the transmission, on the drivers side, its between the transmission and the CV Joint, we need to get it off to pull the engine from the transmission, this is a very difficult nut to get to, does ANYONE have tips on this?
Old 08-29-2010, 06:06 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need a swivel. If you don't have one, pull the axle pin and slide the axle out of the way.
Old 09-05-2010, 04:30 PM   #7
PseudoKirby
Member#: 203835
2000 2.5RS
ok I can tell by the gaskets that the bolt holes do not match up, is this possible?
Old 09-05-2010, 05:19 PM   #8
JoshP
Member#: 94350
yes if you have a phase 2 2.2 they would be different, which really sucks for you.
JoshP is offline   Reply With Quote
Old 09-05-2010, 07:58 PM   #9
PseudoKirby
Member#: 203835
2000 2.5RS
yea its a 99, why does it suck?
Old 09-06-2010, 07:44 PM   #10
PseudoKirby
Member#: 203835
2000 2.5RS
Ok we were able to get everything off.... Cept for the motor mounts, ipulled off the nut on the drivers side but I stripped the passenger side.....
Is there any way to unbt the mount from the engine and leave the mount on the crossmember? I keep looking for a way to get that other bolt
Otherwise is there anyone who has some good advice on getting that nut off?
Becides cutting the mount cause I currently don't have the tools for this
And what difficulties are there in putting this phase 2 in my 95?
Old 09-07-2010, 07:52 PM   #11
kisner410
Member#: 255661
1995 Impreza
Red
Question
so whats the differences on an phase 1 2.2 and an phase 2 2.2? id like to do an 2.2 swap into my 95L 1.8 soon..
kisner410 is offline   Reply With Quote
Old 09-10-2010, 07:02 PM   #12
PseudoKirby
Member#: 203835
2000 2.5RS
is there any one whom can help me?
Old 09-11-2010, 12:07 AM   #13
g-rider
Member#: 181037
1997 BrightonRS
Red
Hey, check out rs25(dot)com... It is a more "old school" friendly site with tons of good info on 93-01 imprezas.
Interesting that your car is a GM8... I thought GM8 = 2 door with an ej20g... My car is a '97 Brighton witch is a 2 door 1.8l, but my code is GM2... trip out lol.
g-rider is offline   Reply With Quote
Old 09-11-2010, 09:32 AM   #14
JoshP
Member#: 94350
for the motor mount nut take a 13mm 12 point socket and hammer it on to the nut. Hammer it very hard for a long time, like 5 minutes, and that will work. As far as phase 2 a lot of wiring and sensors are different, im not totally sure but there is a lot more to the swap. Just do some searching its been done before.
Old 09-11-2010, 09:19 PM   #15
PseudoKirby
Member#: 203835
2000 2.5RS
ok we cant get the engine to slide in, the bolts are into the transmission and the torque converter is onto the transmission, but it just wont get on, what am I doing wrong?
1.8 to a 2.2 swap? notasubyguy Normally Aspirated Powertrain 26 01-31-2009 11:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
1.8 to a 2.2 NA ej25turbo Subaru Conversions 19 08-11-2005 09:27 AM
1.8 to rebuilt 2.2 drewdogg Subaru Conversions 34 07-11-2005 10:41 PM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
