Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 08-27-2010, 04:41 PM   #1
vica153
Member Sales Rating: (14)
Member#: 76586
2006 9-2x Aero
Default FS: R160 3.90 Mechanical, Plate type LSD
SOLD.
I have the rear diff out of my squashed coupe. It's the friction, spring disc type of limited slip design like in the STI. Out of some old subaru, the guy I got it from didn't know.
It's inside an early 90s legacy differential housing. Axle Stubs, female axles. The axles are in good condition.
The bearing caps (bolt on) are corroded in spots and a few chunks fell off around the outside of a few of the bolt holes. I just put big washers on the bolts and it works fine.
The pinion flange is off a 95 Impreza MT rear diff.
It's not pretty. I cleaned it up a little then primed, painted it black, but after 1 winter in Michigan there is surface rust coming through.
It definitely makes it easy to get sideways on your favorite snow covered corner ....I would imagine....because I would never do such a thing.
I can take pictures of it if anyone wants, but you can just imagine any old r160 housing with axle stubs.....except this one has a surprise inside.
Heres a photo of the diff:
I took it apart and everything looked fine, then i put it back together and replaced the ridiculous phillips head bolts (really subaru? phillips head? ) with hex drive flat socket head cap screws.
Ran fine the whole 6 months I had it in. Early January untill June, only 4-5k at most.
It would come with new axle seals, but someone stole my toolbox last week and the seals were in it.
$500 OBO
vica153 is offline   Reply With Quote
Old 08-27-2010, 09:35 PM   #2
mowgli29
Member Sales Rating: (6)
Member#: 203438
So, wait...is this an aftermarket LSD, or an OEM diff from something Subaru?
mowgli29 is offline   Reply With Quote
Old 08-27-2010, 09:37 PM   #3
vica153
Member#: 76586
2006 9-2x Aero
OEM most likely from something early 90s.
Old 09-12-2010, 03:14 PM   #4
vica153
Member#: 76586
2006 9-2x Aero
buy this..........
Old 10-22-2010, 02:02 AM   #5
vica153
Member#: 76586
2006 9-2x Aero
OBO, need to free up some space.
FS : R160 3.90 Mechanical, plate type LSD vica153 NWIC Private Classifieds 0 08-22-2010 01:36 AM
WTB: R160 3.90 rear differential or 3.90 R160 ring and pinion aboothman Private 'Wanted' Classifieds 3 04-18-2010 12:59 AM
FS: R160 3.90 Rear Diff.[Needs Rebuilding] Dena NWIC Private Classifieds 0 08-25-2009 12:04 PM
NJ: WRX R160 3.90 rear viscous LSD Cosworth Private 'For Sale' Classifieds 0 08-10-2005 11:25 PM
R160 3.90 rear diff w/ LSD nicad Private 'Wanted' Classifieds 6 08-10-2005 04:38 PM
