Old 08-27-2010, 05:27 PM   #1
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
Default 2010 wrx GH rim options.
stock now... car is about to be sitting .75" lower.. trying to fit a bit wider and larger rim under unpulled fenders.
been looking around at formulas, previous post... other sites... etc... just would like your .02 if you don't mind
knowing that i'll have to adjust the camber a little bit. what size can i put on without jeopordizing the performance of the vehicle.
maybe 18x8.5's? what offset? 38? i think... but i'm not sure.... stock is 17x 7 +55 225/45
so again, looking for a bit larger contact patch... i dont want to stretch tires... so what tires should i look for to fit specified, to be found, rims?
personal experience? yes, i know going from 17's to 18's adds some mass.... thanks..
A Fatal Ode is offline   Reply With Quote
Old 08-27-2010, 07:15 PM   #2
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Originally Posted by A Fatal Ode View Post
stock is 17x 7.5 upper 40's offset 225/45.
I suggest you go look at your car again. 17x7 +55.
Byzantium is offline   Reply With Quote
Old 08-27-2010, 08:09 PM   #3
A Fatal Ode
Member#: 243616
2010 WRX 336/384
i read that somewhere else.. not off the car itself... so... my bad.
Help on downpipe on a 2010 wrx.... Heat wrap it or not? mike bodame Newbies & FAQs 16 08-28-2010 12:25 PM
Help with install with invidia downpipe on 2010 wrx mike bodame Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-27-2010 04:16 PM
OTS Tune options for 2010 WRX 2010 WRX Limited Open Source Reflashes 2 04-14-2010 12:51 PM
Stock 2010 WRX rim options 2010 WRX Limited Tire & Wheel 4 03-15-2010 01:30 PM
2008 - 2010 WRX lip options 04ts Interior & Exterior Modification 2 10-19-2009 12:46 AM
