Welcome to the North American Subaru Impreza Owners Club Tuesday September 2, 2014
Old 08-28-2010, 10:53 AM   #1
jakvett
Member#: 218841
06 2.5i
Default What is this, and can I rotate it?
I have tucked a couple wires that ran on top of the intake manifold to run under the torque box for a cleaner look. All of the wires reach, but I had to rotate the sensor circled in the pictures 90* towards the passenger side (originally the plug was facing towards the front of the car).
My questions are, first, what is this sensor? It resembles a thermostat with the spring underneath, but I know it's not. Second, is it okay to rotate it as I have? I haven't started the car yet, and wanted to check before I did.
http://www.flickr.com/photos/53421369@N07/4934378849/
jakvett is offline   Reply With Quote
Old 08-28-2010, 11:38 AM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
motec system exhaust-RIP
First of all, you should fill out your info so we know what car you have. Second of all, I have no idea Trying to be more helpful to those who would know.
chazly413 is offline   Reply With Quote
Old 08-28-2010, 03:35 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Looks to be an EGR valve.
Old 08-28-2010, 03:43 PM   #4
jakvett
Member#: 218841
06 2.5i
Okay, after some researching, I agree. That's definitely what it is. I assume there is no harm in rotating it then?
Old 08-28-2010, 04:57 PM   #5
jakvett
Member#: 218841
06 2.5i
I tried starting my car, and it runs fine. No CEL, no noticeable difference in performance. I'm calling it good.
Old 08-30-2010, 12:26 AM   #6
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
definately an EGR valve.
PhilSine is offline   Reply With Quote
Old 09-02-2010, 10:28 PM   #7
S10Crazzy
Member#: 255507
2009 Impreza
So Dirty I dont Know
Any issues since you rotated the top to the EGR?
S10Crazzy is offline   Reply With Quote
Old 09-02-2010, 11:02 PM   #8
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
It is the EGR valve
It will be quite a pain if you can rotate it ( if the square bolt pattern is actually "square" ) due to the exhaust is pumped into it from the bottom via a steel tube.
You can either leave it unplugged and then plug it back in for inspection-emissions. Or, totally pull it off with the header tube and make a block off plate for the intake manifold and a steel ( i think its 3/8 npt ) plug for the exhaust header, or cap the upper tube fitting with the correct threaded plug......the lower header option is way easier.
Doing any of the above options will be an automatic fail of emissions unless you dont have any in your state.....witch we would know if you fill out your profile!! You also may have some wondering idle upon cold start-up, like a TGV deleted turbo Suby gets without a tune. It is not an issue and will go away after the motor is warmed up.
dangerousatom is offline   Reply With Quote
What is this? and is it needed? INFMIS Electrical & Lighting 1 05-19-2009 08:22 AM
what is this and where exactly does it go alfmoney Newbies & FAQs 13 10-27-2006 02:23 PM
What is this and can it be cut? nhmtns General Community 4 09-26-2006 01:22 PM
what is this and what does it do? Russ77 Factory 2.0L Turbo Powertrain 5 09-22-2005 01:00 AM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 09:53 AM
