Old 08-28-2010, 11:04 AM   #1
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Default Removing AVCS on high HP ej series/avoiding gead valve drop
I have seen many valve dropping on cosworth heads running avcs on 500 plus engines, now they are rebuilding them using a more aggressive cam profile from GSC, stage III, we are advised not to run more than 10 deg advance on this setups, but we are afraid of a not good performing avcs setup with aem with this huge cams and resulting in a another valve drop on cosworth cams
So, what do you think about removing the avcs pulleys, tapping down the cams lubrication oil gallery at the pulley and putting wrx non avcs sprockets???
Last edited by DJIMPREZA; 08-28-2010 at 11:04 AM. Reason: head vale drop, stupid typo.
DJIMPREZA is offline   Reply With Quote
Old 08-28-2010, 12:25 PM   #2
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i cant see why pulling avcs cams and the avcs cam gears, and replacing them with non avcs cams and non avcs cam gears would be an issue. you just lose the benefit of avcs. for somebody like me with a non avcs ecu and harness thats the route i would take.
avcs is such a benefit though , if you can run it.
i have heard, but not sure how true it is, that running avcs cams plugged/capped or whatever in a non avcs application will cause the cam to operate in a retarded fashion.
confirmation, denial?
maxpowr is offline   Reply With Quote
Old 08-29-2010, 07:49 PM   #3
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Yes.. I heard that too if you leave the avcs cam sprocket in place, but when locked with non avcs sprockets it shouldnt be retarded...
any confirmation from anyone here??
Old 08-29-2010, 07:56 PM   #4
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i heard that if you use a plugged avcs sti cam with a wrx cam gear it will be retarted from the start in proper timing. as much as 20* retarted. even with the timing advanced the avcs sti cam will not get far into the positive side of timing.
i have no proof of this and am wondering if it is true myself.
why not use non avcs cam and wrx cam gear and be good? aside from having to spend a grand on cams?
i have never heard of a plugged cam coming "unplugged" but that would make me nervous.
avcs is such an advantage i really wish i had the ecu and harness to run it...
dual avcs = NICE! someday i hope to be able to afford a 2011+ sti!
Old 08-29-2010, 07:57 PM   #5
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Yep, just use a non AVCS gear.. Honestly tune the AVCS and you wont have an issue. Plus you will still have the low end advantages of AVCS
Jr
Junior2JZ is offline   Reply With Quote
Old 08-29-2010, 07:59 PM   #6
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i'm confused...
Old 08-30-2010, 12:11 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
clay degree it and youll know how much to run
FuJi K is offline   Reply With Quote
Old 08-30-2010, 12:34 AM   #8
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Ding Ding Ding, we have a winner!
Old 08-30-2010, 09:00 PM   #9
wittmer25
Member#: 102970
2004 STi gt30r
^^ this is very easy to do. If I remember right, you can simulate 7.5° of avcs advance by advancing the cam by 1 tooth. 30° would be simulated by advancing the cam 4 teeth.
wittmer25 is offline   Reply With Quote
Old 08-30-2010, 09:07 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
shhhhHHH..... I know nothing...
Old 08-30-2010, 10:07 PM   #11
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
How do you degree the cams by claying them?
Adjust the gear in a clockwise direction ?
sense of nature is offline   Reply With Quote
Old 08-30-2010, 10:21 PM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Old 08-30-2010, 11:01 PM   #13
sense of nature
Member#: 112759
SexyRP
^ Thank you
Old 08-30-2010, 11:15 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by sense of nature View Post
^ Thank you
it's something close to that, except that your piston is at TDC. You rotate your camshaft until it touches the piston. You record how much degrees it took and that's how much AVCS you can run.
Old 08-30-2010, 11:31 PM   #15
sense of nature
Member#: 112759
SexyRP
Got it ,I was actually gonna degree AVCS cams w/ out using the AVCS.. I.E I have a 2.5 L.B in a 04 wrx set up Just to see if there would be a diff.in power
Old 10-01-2010, 02:41 AM   #16
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
so im looking at running 08sti cosworth heads with 02 wrx wiring, how can i run wrx non avcs cams and gears, will there be oiling issues?? i hear you can run the avcs cams and gears without hooking it up but non avcs gears are much lighter.
thanks
Alaskan EJ20 is offline   Reply With Quote
Old 10-01-2010, 09:46 AM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
thanks
run non-avcs cam, run non-avcs cam gear, install non-avcs intake cam seal.. that's all you need. simple. Keep AVCS oil line plugged because that lubes the cam journal right behind the cam gear.
Old 10-01-2010, 12:04 PM   #18
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
winner^^^
02WRX2.5 is offline   Reply With Quote
Old 10-01-2010, 01:51 PM   #19
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
sweet, awesome thanks, so in the case of these heads i would plug intake and exhaust avcs oil feeds. one more question. are 08sti head valve covers year specific or with any 2.5 sti valve cover fit.
Old 10-02-2010, 09:43 PM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You may want to put on the intake only AVCS valve covers. If you already have the '08 DUAL AVCS valve cover, just find a way to plug the sensor holes that are not used such as the upper/lower cam sensor.
What all do you have with the '08 head?
Old 10-02-2010, 09:57 PM   #21
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
just the heads and cam caps. no cams, buckets, gears or covers. so valve covers for 04-07 sti then.
Old 10-02-2010, 10:55 PM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I just looked at the heads again. You can run '04+ AVCS head valve covers, intake only or dual AVCS.
Old 10-06-2010, 07:03 AM   #23
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Fuji, can you explain what you mean by keeping the oil line plugged? On the exhaust side? You use non avcs cams and solid cam gears, but I get confused by how the oil is routed though the head, especially on the exhaust avcs side. So would it be better to keep all sensors and solenoids in place or make some kind of blockoff plate for the exhaust avcs solenoid. Just want to make sure the exhaust cam will get oil if not running the exhaust avcs
Bad Noodle is offline   Reply With Quote
Old 10-06-2010, 10:09 AM   #24
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
What he means is some people "THINK" that no AVCS means that no oil line is needed to the AVCS solenoids anymore. This is a BIG mistake as it will stop lubrication to the area of the cam right behind the cam pulley where the large cap mounts. This will make the cam seize up. Keep all oil lines as they were. Just use Non AVCS cam pulleys and oil seals, etc. You can tap thread in the oil galleries inside the camshaft which normally guides the oil towards the AVCS cam pulleys. There are 4 holes that look like oil galleries. 2 should be tapped and sealed off to prevent oil getting out between the camshaft and the pulley. I hope this is clear enough.
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 10-06-2010, 10:13 AM   #25
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Hmmm....sorry I believe ALL 4 holes need to be blocked off now thinking of it.
Cheers,
Jasper.
High HP high reving subarus, what oil pump & thoughts on aftermaket oil pan & baffle? D Money Built Motor Discussion 66 05-17-2009 12:13 PM
Exhaust ideas on high HP setup DemiSlayer Built Motor Discussion 8 08-12-2008 08:23 AM
Need pictures (of FWD EJ-series motors/gearboxes) Kha0S Subaru Conversions 3 10-24-2003 04:46 PM
What's the combustion sequence of the ej series engines? The Enemy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 03-13-2003 07:07 PM
q's on a high hp turbo buildup smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-23-2001 11:26 PM
