Old 08-28-2010, 01:14 PM   #1
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Default JrTuned 2.5RS Built motor.. Pinned mains/sleeves/orings everything!
Pinned Mains and sleeves finally... I'm very lucky to have such a kick ass machinist. [email protected] is the man!!!
I will update this thread as I get stuff done. Its been a slow process.. but its starting to pick up.
Darton Sleeved
Darton Sleeved + Custom TurboTrix Pins
The process
Junior2JZ is offline   Reply With Quote
Old 08-28-2010, 01:15 PM   #2
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Pins
Receivers
Perfection together
Old 08-28-2010, 01:39 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
Looks great Junior. I myself have been kicking around the Idea of pinning the mains. As you know it is a bit trickier on a flat motor.
I am curious how you did it. Did you sweep each main bolt hole and go a known distance down and drill the hole for the pin; and then sweep the other half and lay the same pattern? I would assume you also line bored it afterwards to make sure.
What are your plans turbo/boost/HP wise?
MartinSTi05 is offline   Reply With Quote
Old 08-28-2010, 02:11 PM   #4
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
thanks for sharin uncle june. subscribd for the birth of a beast.
how about running down a build plan...
maxpowr is offline   Reply With Quote
Old 08-28-2010, 02:44 PM   #5
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Very interesting idea...
What kind of crank is going into this thing?
This block going into an older style 2.5rs I hope?
mtcs is offline   Reply With Quote
Old 08-28-2010, 02:47 PM   #6
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
subscribed
codesoccer is offline   Reply With Quote
Old 08-28-2010, 02:47 PM   #7
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Old pic, but you get the idea...
Build plans,
Block :
Darton Sleeved
TurboTrix Machine pinned sleeves
TurboTrix Machine pinned Mains
TurboTrix Machine Oil mods
Cosworth rods with h11 bolts
Cosworth 79mm Billet Crank
Cosworth Bearings
Cosworth Race oil pump
Custom JE 100mm pistons ( coated domes, skirts, rings and anti det rings) or Cosworth standard compression 99.75 coated pistons...
P&L Big Boy Head Studs
Heads
Cosworth CNC Castings stripped of all parts
[email protected] is reworking the Cosworth heads to his liking
TurboTrix Machine O-rings
Cosworth springs/reatines/seats
SuperTech +1mm Inconel exhuast valves
SuperTech +1mm Nitrate intake valves
Ceramic Coated CC chambers
GSC AVCS 282s
Cometic Stock compression Head Gaskets
Car already has a PPG 6spd, exedy triple, id2000s, dss everything etc etc..
Turbo setup is full TurboTrix twin scroll billet42r setup
Old 08-28-2010, 02:49 PM   #8
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Old 08-28-2010, 02:49 PM   #9
richy_21
Member#: 58670
2005 got muuuuu?
:yawn:.....
lol looks nice! Good luck in that shootout!
richy_21 is offline   Reply With Quote
Old 08-28-2010, 02:53 PM   #10
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Now that is intense...
Hey Junior2JZ can you shed some light on the idea behind pinned sleeves, pinned Mains
and Oil mods?
I have my block over at Darton right now and am thinking you should sell this service to them... lol
Old 08-28-2010, 03:17 PM   #11
MartinSTi05
Member#: 145145
2006 wrx STi
Nice. Quest for 8's? Best of luck!
Old 08-28-2010, 03:52 PM   #12
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
ill cams and turbo setup for a lightweight car. go big or go home huh?
this is the car nasioc would have built.
good luck to yuor build junior.
Old 08-28-2010, 04:18 PM   #13
MartinSTi05
Member#: 145145
2006 wrx STi
Lol, I think it will be the car junior built. I didn't hear him asking a bunch of peoples opinions;-)
Old 08-28-2010, 04:27 PM   #14
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
if nasioc could have built a car he would have hired junior as a consultant.
Old 08-28-2010, 08:17 PM   #15
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
40-50psi with a 4202 billet. I don't have an HP goal, I would be fine in the 800-900 range.
and Oil mods?
Should have just sent me the block down at TurboTrix in NJ
Pinned sleeves are to help keep them from shifting/moving/distorting when the boost goes high. Oil mods are simple, deburring of passages, opening up a few choice areas and smoothing out some rough transitions.
Pinned mains are to keep the block halves together and happy under big HP use.
I plan of running the mile events, so I intend full on holding out the high gears running 50psi.
That would be cool, but honestly a fun street/strip car is all I am building. I would be happy running low 9s with it and getting over 200 in the mile.
good luck to your build junior.
Thanks dude!
Damn straight its the car Jr built..
Just taking all my experience and finally building myself something I have always wanted.. an EVO beater
Old 08-28-2010, 10:22 PM   #16
reid-o
Member#: 103631
2004 STI
Do the darton sleeves have the hole for the piston pin?
I just noticed that it looks as though theyre missing
reid-o is offline   Reply With Quote
Old 08-28-2010, 11:22 PM   #17
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
No holes, they have to be made.
Old 08-29-2010, 01:07 AM   #18
cpturbo
Member#: 49175
2004 STI
What front crossmember are you using? That looks like a lot of space up front. Clean set-up. Thanks in advance.
cpturbo is offline   Reply With Quote
Old 08-29-2010, 02:20 AM   #19
indywagon
Member#: 215814
2010 Tundra
Red
Originally Posted by Junior2JZ View Post
Pinned sleeves are to help keep them from shifting/moving/distorting when the boost goes high. Pinned mains are to keep the block halves together and happy under big HP use.
As he said, it helps keep the block from twistng and the mains become distorted in that regards. It does not help keep the halves from pulling apart but helps keep them from twisting.
It thus keep the main bearings happy and helps keep the rod bearing oiling consistent.
-Micah
'Homemade WRX'
P.S. lots of builders do this, not just turbotrix
P.P.S. you sleeving jobs looks a little loose or the block was warm when they cut it by the corners where the sleeves meet. Might just be the picture though.
indywagon is offline   Reply With Quote
Old 08-29-2010, 08:58 PM   #20
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Are you running the AEM that i sold you?
I guess your going to run 15" to get the power down?
What's the rev limit?
waynoSTI is offline   Reply With Quote
Old 08-29-2010, 11:31 PM   #21
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Its an 07 STI member, it actually has another 1-2 now with the new radiator an mount setup.
-Micah
'Homemade WRX'
Yea that is what I meant.. lol It keeps the block halves from twisting.
I know a few engine builders do this.. but I don't think many have done a Subaru.. Its probably just the pics, they are nice and tight
That AEM has gone 10s a few times already
Yea I have a few sets of wheels, 15s to 17s.. I'm not looking to rev much past 8500
Old 08-30-2010, 12:59 AM   #22
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Are the pins made out of the same material as the sleeves or the block halves? I have mixed feeling about pinning the engine regarding how different materials expand/contract and how fast/much they do so.
2gnt2wrx is offline   Reply With Quote
Old 08-30-2010, 08:32 AM   #23
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Oh baby, this one's going to be a creeper!
Good luck with the build Junior!
STI_KLR is offline   Reply With Quote
Old 08-30-2010, 10:35 AM   #24
fourmicah
Member#: 128760
2015 STI
Amazing build Junior, I'm interested in seeing how this works out. I've been batting around the idea of doing something like this or a closed deck block with sleeves, I'm just not sure which one is better. If anyone can clue me in I'd appreciate it.
fourmicah is offline   Reply With Quote
Old 08-30-2010, 11:07 AM   #25
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I was talking about Subie builders. I like using larger pins to increase the surface area.
99 Gs-R 2.2L built motor EddyBass NWIC Private Classifieds 10 10-14-2009 12:24 AM
2000 STM 2.5RS Coupe 5800$ obo -Maine- diablo Private Vehicle 'For Sale' Classifieds 17 11-29-2007 02:24 AM
Project Small Hotside, 2.4L Built Motor Kingpin Member's Car Gallery 86 09-22-2006 12:57 AM
