Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 08-28-2010, 05:47 PM   #1
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Default hesitation at 3000-4000 rpm under WOT on hot days
Thought I'd check if anyone experienced it with NAs - basically a very tangible hestitation upon WOT acceleration at 3-4k rpm.
It occurs once in a blue moon, and seems to appear during intense heatsoak - I was just at an auto-x, and noticed it twice (almost a stumble once) at WOT after a sharp curve. To be anally specific, it only happened when the car was floored after braking (so a quick jump from max vacuum to full open throttle.) IATs at this point were exceeding 50C (125 F). Oil and coolant temp were ~ 200F.
Mods are headers and catback, along with a catch can. No tune. No CELs were triggered. Plugs in good condition. It also occured a few times on a red light-to-freeway accelearion on very hot days.
Opinions?
Old 08-31-2010, 10:56 AM   #2
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
1)During auto-x's, if I dont have at least 1/2 tank, my fuel will cut-out going through right-handers. Stupid pick-up placement! Its pretty dramatic though, definitely a complete loss of power.
2)I also had a similar condition, just as you described, right before my knock sensor gave up the ghost. It was a slight hesitation at tip-in.
Hopefully this helps!
-adam
snoopyone8 is offline   Reply With Quote
Old 08-31-2010, 12:16 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
My tank was half-full. Thanks for the info, I wanted to go near empty next time, didn't know cornering would affect fuel supply.
Knock sensor, eh? Does it trigger a CEL, or what are the symptoms when it's gone?
Old 08-31-2010, 01:49 PM   #4
snoopyone8
Member#: 42970
Yeah, fuel pump pick up is on driver's right hand side of the tank...you can make (or buy) an anti-slosh box for it. I think scoobymods or ravensblade might have a DIY writeup on it.
The knock sensor does give a code when it finally gives up, but it seems like just before it goes (1-2 weeks of daily driving) it sends funny signals to the ECU without triggering a light and the engine just feels rough and DOP (possibly too far out of time?)
Good luck!,
-adam
Old 08-31-2010, 03:17 PM   #5
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
-adam
I'm not sure this problem is as apparent on newer imprezas.
Recently a service bulletin was sent out for most GD imprezas where the fuel reserve one-way check valve would prevent fuel from feeding into the pump on hard right handers.
The service bulletin tells you to go remove this valve.
formula91 is offline   Reply With Quote
Perrin 3" TBE sound clip 3000-4000 RPM stiIV Member's Car Gallery 11 12-04-2005 07:15 PM
Small blip of hesitation at 3000 rpms? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-01-2005 06:13 PM
hesitation at around 4000 rpm's? OCD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-04-2003 02:48 AM
chugging at 4000 rpm under full boost sewercleaner Newbies & FAQs 2 05-09-2003 11:17 PM
Rough idling, hesitation at about 4000 rpm MadManMike General Community 3 07-04-2002 01:47 PM
