Old 08-28-2010, 10:29 PM   #1
sport'nwagon
Member#: 137372
2004 wrx wagon
wrb
Default No illumination after Omori boost gauge install
I searched around here, and think that I might have wired it wrong, but I need help with the wire colors. I installed the electronic boost gauge and wired it to the clock harness. I tested the illumination of the gauge before I hooked up the clock and it was working. I finished installing everything, and now the dash or gauge will light up. The clock and the gauge are working, but they are not lightening up and neither is the dash. I checked the illumination fuse and it is good. Here is how it is connected:
Blue/pink strip(clock)- Green (battery +) to the gauge
Pink/blue strip(clock)- white (12V dash lighting) to the gauge
Yellow/blue strip(clock)- Red (12V ignition switch) to the gauge
Black/black (clock)- Black (ground) to the gauge
Thanks in advance.
sport'nwagon is offline   Reply With Quote
Old 08-29-2010, 10:35 PM   #2
choleaoum
Member#: 255484
2010 EVO
I'm having a similiar issue to regarding the illumination, I checked it was a blown fuse, but I replaced it still no illumation. Let me know if you figured it out!
choleaoum is offline   Reply With Quote
Old 08-29-2010, 11:38 PM   #3
sport'nwagon
Member#: 137372
2004 wrx wagon
wrb
Update: I double checked everything, I even disconnected the gauge and wired the clock back up by itself, and still nothing. Long story short, I ended up "jiggling" the illumination fuse and the dash lights flickered. For whatever reason the fuse was not making a good contact in the fuse slot. I bent the fuse ends a little and put the fuse back in, and now it is working.
New Omori boost gauge install pics STiMUL8 Interior & Exterior Modification 2 08-28-2005 02:45 AM
Omori boost gauge install options - anything steering wheel housing based? STiMUL8 Electrical & Lighting 1 06-11-2005 10:28 PM
omori boost gauge install heavyDOODIE Electrical & Lighting 25 08-11-2004 12:28 AM
Omori Boost Gauge Install Pic BrysImpreza Forester Forum 13 09-11-2003 08:59 PM
Omori Boost Gauge Install volley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-22-2002 09:36 AM
