Old 08-29-2010, 12:29 AM   #1
GT11
Member#: 128002
0000 four door sedan
Poop color
Default Oil light blinking
Is it normal for the oil light to blink when the engine tries to crank over? I checked the oil and it's full.
This only happens when I start the car and once the engine is running, the light never turns on.
Oil sending unit, oil pump on it's way?
GT11 is offline   Reply With Quote
Old 08-29-2010, 06:51 AM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I flickering oil light at startup can be the first sign of oil pickup failure. SEE PICS HERE
KillerBMotorsport is offline   Reply With Quote
Old 08-29-2010, 07:10 AM   #3
GT11
Member#: 128002
Poop color
Sometimes it blinks and sometimes it just stays lit until the engine is running.
How hard is it to replace the oil pickup?
Old 08-29-2010, 11:22 AM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Also check the electrical connector to make sure it's clean. I've heard stories about dirty connections that caused something like that.
Old 08-29-2010, 02:58 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Bad connection will typically give a dim light, not a flicker. Never hurts to check though.
Old 08-29-2010, 04:21 PM   #6
cessna152
Member#: 7523
1999 Impreza 2.5 RS
Do your pans fit the N/A blocks? And what years.
cessna152 is offline   Reply With Quote
Old 08-29-2010, 09:27 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, they fit any EJ motor.
"at oil temp" light blinks 16 times, but... mattmer Transmission (AT/MT) & Driveline 7 07-18-2006 05:54 PM
2000 auto L wagon. at oil temp light blinking furiously azn2nr Transmission (AT/MT) & Driveline 4 05-17-2006 11:43 AM
Oil light is blinking WRX_Mike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-08-2006 05:11 PM
AT oil Temp light blinks leep133 Transmission (AT/MT) & Driveline 2 08-28-2005 11:14 AM
AT oil temp light blinking campbellbrett Transmission (AT/MT) & Driveline 3 07-14-2004 07:49 PM
