Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-29-2010, 12:31 PM   #1
ChronicSphinx
Member#: 122795
2003 WRX
Default AC blowing hot air help
My AC is blowing hot air. I think it may have a leak. Is there anyone that could take a look at it? Thanks
ChronicSphinx is offline   Reply With Quote
Old 08-29-2010, 02:24 PM   #2
howitz
Member#: 212096
2005 Hella
stock
Windows down ftw.
howitz is offline   Reply With Quote
Old 08-29-2010, 02:33 PM   #3
xblackdeathx
Member#: 72357
06 fxt,11 outback
,96 land cruiser
go to harbor freight and buy there recharger kit for $25 bucks, then recharge your ac, to start with.
xblackdeathx is offline   Reply With Quote
Old 08-29-2010, 02:36 PM   #4
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
did you change ur coolant recently and what are your engine water temps high or normal. and yes a/c may need to be recharged or worse your have a leak and recharging wont help
krambte79 is offline   Reply With Quote
Old 08-29-2010, 02:47 PM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Go somewhere that does AC recharging and see if they can put a dye in your system to see if you have leaks.
bhhamblin is offline   Reply With Quote
Old 08-29-2010, 03:54 PM   #6
ChronicSphinx
Member#: 122795
2003 WRX
I did put some more coolant in a couple of weeks ago. What would that do with the AC? I did just get it recharged as well. How much does it cost to have someone try and find the leak?
Old 08-29-2010, 05:26 PM   #7
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
call and ask them i have no idea.
Old 08-29-2010, 07:31 PM   #8
Touge86
Member#: 166498
2013 M3
Mint Green
just put the system underwater. Its the same as checking a bike tire for leaks.
Touge86 is offline   Reply With Quote
Old 08-29-2010, 11:43 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
low coolant will make your ac run warm.
medamullet is offline   Reply With Quote
Old 08-30-2010, 01:21 AM   #10
cappa
Member#: 201987
Just tear it out get a fmic and go reverse manifold.
cappa is offline   Reply With Quote
Old 08-30-2010, 01:24 AM   #11
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
^^ Best idea in the whole thread!
On a side note. If there is a leak in one of the lines, I have some A/C lines from a GC in good condition. I'm not sure if they are the same, but we can check.
EsubaruJ is offline   Reply With Quote
Old 08-30-2010, 02:08 AM   #12
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Low coolent....? really?
Check your fan. If it turns on then thats not it. Other than the obvious. does it turn on, same with the ac compressor is it cycling?
Those are about the only things to check before you need to check the line pressures. and you need some gauges for that.
Bones702 is offline   Reply With Quote
Old 08-30-2010, 10:49 AM   #13
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
no brett, I got it wrong. Low coolant makes the heater blow cold air
Old 08-30-2010, 11:08 AM   #14
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
I thought something was aloof in that post, good catch
06HAWKMAN is offline   Reply With Quote
Old 08-30-2010, 11:12 AM   #15
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
lol
AC not blowing cold air [email protected] Service & Maintenance 7 07-21-2016 10:40 AM
hot air blowing from floor vents hopgal General Community 40 06-30-2014 10:04 PM
AC filled w/ freon...blows hot, refilled...blows cold What gives? dingo dave Service & Maintenance 3 04-26-2009 08:06 PM
This passenger's just blowing a lot of hot air! wcbjr Texas Impreza Club Forum -- TXIC 10 03-10-2004 01:11 AM
a/c blowing hot air after coolant flush mofoporn Service & Maintenance 31 08-12-2002 07:47 PM
