Old 08-30-2010, 09:57 AM   #1
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Default EJ25D rebuilding Q's...
I have been rebuilding my EJ25D for my 98 RS and have had some issues. I bought the standard ACL bearings for the rods but have lots of play in the in and out movement of the rod. The side to side is at its max tolerance but the in and out, or back and forth movement, has a lot of play?
What say ye? Do you think that I had been sent the wrong bearings in the correct box? Is it safe to remove the rod cap while it is attached to the crank after it has already been torqued down to determine if the bearing is wrong?
I inspected the original bearings that were in the block and they were OEM and had a .25MM stamped on the backside with some other letters.
I am at my whits end with this engine.
If anyone has any advice plz chime in.
Gr3en is offline   Reply With Quote
New WRX owner: break in Q's , turbo Q, warm up q's, oil q SubieScottWRX Newbies & FAQs 11 09-01-2011 07:19 PM
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels Engine/Power/Exhaust 24 07-22-2010 09:23 AM
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels NWIC Private Classifieds 23 07-22-2010 09:22 AM
some seat q's and reupholstery q's mystilexzero Interior & Exterior Modification 1 09-09-2009 03:36 PM
STi 04 Q's and Insurance Q's markuswarren Canada Region Forum 6 02-27-2003 05:57 PM
