Old 08-30-2010, 03:57 PM   #1
ezil71
Member#: 207118
2003 Wrx Wagon
Default regulator/alternator issue and grounding mod?
So my bugeye is having a charging issue, either the voltage regulator or the alternator (battery was tested bad too and replaced, 5 months out of a full 3 year replacement of course!).
My question is, does having an amp/multiple amps cause any issues if I am still using the stock grounding setup?
I'm going to have the regulator/alternator tested tonight, just want to make sure there isn't anything else I should do to prevent another failure.
I'm assuming 6+ years is a reasonable time to fail on these, but thought I'd ask those with more subaru electrical knowledge
Thanks...
ezil71 is offline   Reply With Quote
Old 08-31-2010, 11:11 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If you are using equipment that requires a lot of current you should think about installing a alternator that has a higher current output. Six years service for an alternator is pretty good.
Grounding Mod - Alternator Wine TheRedWRX Car Audio, Video & Security 5 11-26-2006 07:04 PM
alternator has signal and ground but will not switch on azn2nr Subaru Conversions 12 08-16-2006 03:15 AM
alternator ground - issues and my solution Craigs Service & Maintenance 2 04-20-2006 03:25 PM
Single-point ground mod vs. Multi-point ground mods DrBoy01 Normally Aspirated Powertrain 5 12-05-2003 04:21 PM
alternative to grounding mod newbie sewbie Electrical & Lighting 2 01-30-2003 09:53 AM
