Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
Old 08-30-2010, 06:12 PM   #1
JasonLI25T
Member#: 184357
2006 Forester XT
Default please help with ej257 swap in forester XT
First question is about the EGR system. my old motor (ej255) has an egr system but im not sure if the ej257 does...my friend is doing the swap and is a bit confused about how/if to swap over the EGR system to the new motor.
i have some more questions but this one is most important right now. thanks in advance.
JasonLI25T is offline   Reply With Quote
Old 08-30-2010, 10:39 PM   #2
JasonLI25T
Member#: 184357
2006 Forester XT
does anyone have any info?
Old 08-30-2010, 11:03 PM   #3
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
There should be an EGR system on there, all 1995 and newer Subies have EGR systems. Look around for the valve, they all look the same it shouldn't be hard to find.
Jessekrs123 is offline   Reply With Quote
Old 08-31-2010, 12:20 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Your old motor; '06 FXT is the same as the '06 WRX motor, and comes with that air pump stuff. Just have it unplugged and have the code turned off.
The EJ257 motor is going to run a lesser compression ratio. 8.2:1 vs your 8.4:1.
FuJi K is offline   Reply With Quote
Old 08-31-2010, 12:40 AM   #5
JasonLI25T
Member#: 184357
2006 Forester XT
thanks...i will do that. however the compression ratio will actually be a bit higher (8.5:1) as this is a rebuilt block and that is the new comp ratio with the CP pistons.
need help with ej20 swap in my 99 2.5 rs jonnyquest Newbies & FAQs 12 05-28-2008 02:00 PM
Need advice/help with ej257 swap RR02wrx Factory 2.5L Turbo Powertrain 1 04-26-2006 06:42 AM
Swapped JDM Forester XT 2.5 Engine in WRX :) Gruppe-S Factory 2.5L Turbo Powertrain 12 02-04-2005 11:31 AM
Help!!! Internal Coolant Leak on Forester XT in Raleigh UGoWeGo South East Region Forum 19 12-21-2004 02:14 PM
Please Help with STUPID ticket in NY area DieselClown Tri-State Area Forum 29 07-05-2004 11:28 PM
