Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 08-30-2010, 07:39 PM   #1
RR
Member#: 48191
2012 WRX
Ducati Monster
Default Lining up engine with transmission spline
Engine is out of the car for delta cams, new clutch and related maintenance items. I spent about 4hrs yesterday trying to get the engine lined up with the transmission which is still installed in the car with no success at all.
Most every clutch install guide I read says to pull the tranny not the engine, I'm wondering, should I just pull the tranny and either mate them outside the car and install as one unit OR pull tranny reinstall engine then tranny.
I'm open to any tips and tricks for getting engine to line up as is, otherwise looking for suggestions for easiest resolution.
RR is offline   Reply With Quote
Old 08-30-2010, 07:55 PM   #2
damonmlime
Member#: 54525
2000 00rs 2x91ss 95l
blue ridge pearl
Spinning the crankshaft pulley has worked for me in the past. The only other advice I have is be patient. Sometimes it helps to jack the transmission up an inch or so and that can help it slide together.
damonmlime is offline   Reply With Quote
Old 08-30-2010, 08:33 PM   #3
phate1229
Member#: 173615
2015 WRX Limited
are you doing this yourself? I've always spun the driveshaft with it in gear to get it to spline
phate1229 is offline   Reply With Quote
Old 08-30-2010, 08:34 PM   #4
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
It is a little harder to line it up with the motor swinging. As long as you have the disc aligned in the center, it will just take a little patience.
swede978 is offline   Reply With Quote
Old 08-30-2010, 08:47 PM   #5
omegax
Member#: 65347
all about the angle... make sure the dogbone is off and jack up the trans as high as you can so the engine mounts clear. Then hang the engine on the sling in the same angle. And finally as already mentioned you can spin the crank to help it mesh. If everything is on point it will come right together.
omegax is offline   Reply With Quote
Old 08-31-2010, 10:12 AM   #6
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Please, by no means take this as an insult...But did you use an alignment tool when you installed the clutch? Did you replace the pilot bearing and is it seated properly?
If so, sorry for stating the obvious. Crazier things have happened...
-adam
snoopyone8 is offline   Reply With Quote
Old 08-31-2010, 10:34 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Agreed with all the earlier comments. The few times I've done this I had the front of the car up on low jackstands, then used a floor jack to jack up the front of the tranny (basically until it hit the top of the tranny tunnel), and had the engine on an angle (rear of the engine lower) so that it would line up. A breaker bar on the crank bolt will let you jiggle the crank a bit - shouldn't take much.
Pat Olsen
Old 08-31-2010, 03:19 PM   #8
RR
Member#: 48191
2012 WRX
Ducati Monster
-adam
No insult taken, i've been hoping i overlooked something but yes I used the alignment tool. I've taken the engine out of the bay and double checked alignment a good four times by now.
Pat Olsen
The car currently sits on jack stands at close to their highest point, i was thinking that being so high made it tough to get proper leverage, lowering it to their lowest setting will be part of my next round of battle.
Old 08-31-2010, 03:40 PM   #9
renob123
Member#: 41986
'06 STI/'85 Brat
I bolt the clutch disc in the pressure plate but leave the bolts just hand-tight so the disc wiggles around a bit. Then I push the tranny onto the engine and tighten the bolts through the starter hole once everything is lined up. No alignment tool necessary.
Disclaimer: I'm not sure if that's an acceptable/safe/smart way of doing it, but that's how I've done it. I'm not an expert, and my posts don't replace thinking
Jacob
renob123 is offline   Reply With Quote
Old 08-31-2010, 06:14 PM   #10
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I pulled the engine on mine, i think it's easier to install the cams with it out and i also did the Exedy LW flywheel and clutch while it was out. Cams and flywheel made it real fun. Is it getting close enough the pins are hitting? also it does make it a ton easier if the trans is jacked up and angled toward the engine a bit.
aclver1 is offline   Reply With Quote
Old 08-31-2010, 07:55 PM   #11
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
I put a little bit of grease on the splines and make sure theres no rust on the input shaft. keep it in gear, raise the trans, put a wrench of the crank pulley bolt and move it around and it usually slides in. Its not easy if you're doing this by yourself...sounds like you are. keep the faith, it'll go.
SBW is offline   Reply With Quote
Old 09-05-2010, 08:56 AM   #12
RR
Member#: 48191
2012 WRX
Ducati Monster
Update: I lowered the car from the jackstands 2nd highest position to their lowest position and was able to get the engine/tranny to mate within 10 minutes.
Transmission splined shaft alignment pkejsn Transmission (AT/MT) & Driveline 0 03-12-2010 06:00 PM
2003 engine line-up Drummer Normally Aspirated Powertrain 1 01-19-2009 12:00 PM
remove wrx 04 transmission splines Crazy650 Transmission (AT/MT) & Driveline 0 10-15-2007 11:57 PM
2.0 EJ20 Engine With Transmission Only 25,000 miles on both Ravenous Private 'For Sale' Classifieds 9 06-01-2004 05:37 PM
ARGH! Up Pipe about an inch off line up with manifold Altered BeasT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-29-2001 10:03 AM
