Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 09-06-2010, 02:05 AM   #76
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
First rule of owning even a cheap Porsche. Nothing is cheap
Are you parting out any of the stock parts? I need a few things.
silver arrow is offline   Reply With Quote
Old 09-06-2010, 02:14 AM   #77
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
I call it the "Porsche Tax"
What are you looking for parts wise?
kcpaz is offline   Reply With Quote
Old 09-06-2010, 02:18 AM   #78
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Do you know how many miles were on your AOS? Mine is at 74k miles and smoking a little. I need some Savanah Beige seats, mine are shot. And a non Lithtronic R side head little with amber turn signal. HVAC controls too.
Old 09-06-2010, 02:25 AM   #79
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
BTW, 996 GT3 RS brake ducts fit and are only 40-50 bucks.
Old 09-06-2010, 02:41 AM   #80
kcpaz
Member#: 194611
1998 Legacy GT
Yup, learned that from building Boxster Spec cars.
As for the other parts, I don't have an AOS that I would trust sending to someone, just a spare that I keep around incase of emergency. The headlights were toasted from the AZ sun on the test car so I tossed them. I do have an HVAC controler that might still have a good display still.
Old 09-06-2010, 02:45 AM   #81
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
PM me what you want for it, mine is a giant orange blob. It still works, but I can't read anything on it.
And thanks for sharing your cool project with us.
Sean
Old 09-06-2010, 11:12 AM   #82
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
this might be just the ticket for what you have there EM wise
http://forums.nasioc.com/forums/show....php?t=1694627
although there seems it might be vaporware
Old 09-08-2010, 10:24 PM   #83
charliew
Member#: 125304
My son uses speed density on his modded 04 sti with the factory ecu and he seems to get by fine.
charliew is offline   Reply With Quote
Old 09-09-2010, 05:53 PM   #84
wrknhard
Member#: 146602
That exhaust is amazing. Very clean.
wrknhard is offline   Reply With Quote
Old 09-09-2010, 07:33 PM   #85
kcpaz
Member#: 194611
1998 Legacy GT
The wiring harness has been reduced to only what is needed to make the engine run.... hopefully.
And here's what wasn't used...
Old 09-09-2010, 11:13 PM   #86
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Hats off to you, that's a lot of work.
Old 09-10-2010, 12:40 AM   #87
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
holy crap!!! thats insane! good work
subydude02 is offline   Reply With Quote
Old 09-10-2010, 03:45 AM   #88
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
The wastegate dumps were done like that because I didn't want to just dump them straight down under the car in front of the rear bumper. I want all of the exhaust gasses to exit behind the car not under it. If I decide to go with a flat bottom and rear defuser, I don't want to have to go back and fix this later. As far is it being a Euro thing... I don't know about that because I'm not into Euro cars really. I just thought it would look cool, and so far, you are the first person who hasn't cared for the look. (which is fine)
As far as the headers being "long"... While it's true that they are longer than the aftermarket EL Subie headers, they aren't a whole lot longer in reality once you factor in the up-pipe. Also, I did a lot of test fitting, and analyzing before I settled on this turbo location, and truth is, there is really nowhere else in the chassis for it to go. You have to remember, in these pictures, there are a lot of suspension pieces and other parts missing that restrict turbo placement, especially with such a relatively large turbo.
Like I said before, I really wasn't trying to sound very judgmental and I can tell you are a very experienced fabricator. I was just curious if you had any room for a different placement of the turbo, but like you said there is no where else for it to go! I really respect your work, and from what I can see your welds are nice and clean!
domestic_abuser is offline   Reply With Quote
Old 09-10-2010, 01:06 PM   #89
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
With the room behind the crank pulley, there is plenty of room to do an H6 swap. That would be another alternative for some.
blkscooby is offline   Reply With Quote
Old 09-10-2010, 01:25 PM   #90
White out
Member#: 46277
** LP640
996TT
Great idea. EJ swap after IMS failure.
Are you concerned with the rear bumper melting with the turbo so close?
Plans for heat containment?
Is there a reason why the turbo was placed on the left side of the car vs. right?
For an idea with the above mentioned 'rear impact' post, you could make an angle brace that runs the rear quarter of the car, next to the turbo, to add as a level of protection from a light hit. I doubt it would weigh much as well.
Please shoot me a PM whenever you get a kit together for engine mounting/wiring/etc for a swap. This is a very cool & financially reasonable move to have a high powered Boxster. Even the 986 is a great chassis, although many think that it's more of a girly car than a dirty girl in the right hands.
Nick
White out is offline   Reply With Quote
Old 09-10-2010, 03:24 PM   #91
kcpaz
Member#: 194611
1998 Legacy GT
Yes, plenty of room. I bet the EG33 would even fit.
Old 09-10-2010, 03:29 PM   #92
kcpaz
Member#: 194611
1998 Legacy GT
Nick
Yes, on the Boxsters, the cables for the shifter run along the right side of the transaxle and I don't want to have to worry about heating the cables with the heat from the turbo and exhaust. With the way everything is routed right now, the only parts that are exposed to close contact heat are steel or aluminum. The left side CV joint will see some heat (there's no way around that) and the rear bumper might get a little warm, but everything will be shielded and wrapped so I don't foresee any issues.
Old 09-10-2010, 03:54 PM   #93
White out
Member#: 46277
** LP640
996TT
That is a good idea keeping the heat way from those cables. I wasn't sure of the schematics of it being on the left (thinking weight distribution).
Nick
Old 09-10-2010, 04:18 PM   #94
kcpaz
Member#: 194611
1998 Legacy GT
Nick
Weight distribution was a concern of mine as well, but shifter cable reliability is more important IMO. Also, there is a local track that is talking about imposing a strict sound limit, so having the turbo on the left side means I will have plenty of room for a muffler on the right side.
Old 09-13-2010, 11:36 AM   #95
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Question, I understand the adapter to bolt up the engine to the belhousing of the the trans.
but how do you make the clutch system work? is there somekind of adapter you made? Input shaft > clutch adapter? How is clutch depressed, etc?
If so do you have pictures of that I am really interested.
NITROS is offline   Reply With Quote
Old 09-13-2010, 02:52 PM   #96
kcpaz
Member#: 194611
1998 Legacy GT
It uses a custom flywheel, a Porsche style clutch kit and all of the stock Porsche clutch slave/master cylinder system. I'm not going to be sharing any pictures that relate to the adapter kit beyond what I have already posted. I have to keep some things a secret while I still can.
Old 09-13-2010, 06:57 PM   #97
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep,
You've got to be very careful with your distribution when you release this. If you don't it will end up in Kennedy's hands really quickly and suddenly all of your hard work goes out the window as someone else takes it mass market. Talking to a patent lawyer wouldn't be a bad idea...
Old 09-14-2010, 12:27 AM   #98
NITROS
Member#: 41561
04 GT3076 2.1
I thought you were just making a one off didnt know you were going to mass produce. I was just curious as i have an appreciation for custom work. Anyway im following this thread and cant wait see the completed project.
Old 09-14-2010, 01:05 AM   #99
06Limited
Member#: 118112
2006 WRX Limited
Subscribed...
06Limited is offline   Reply With Quote
Old 09-14-2010, 04:28 AM   #100
kcpaz
Member#: 194611
1998 Legacy GT
I got the first round of primer sprayed on the prototype fiberglass roof scoop. Once I'm happy with the shape and finish, I'll make a mold off of this part. The plan is to make the scoop removable so I can get to the rear trunk and remove the fiberglass hard top to get to the top of the engine. Also, now that most of the rear window will be blocked, I will probably just fill it in and mount a rear facing camera somewhere and an LCD display where the rear view mirror would go.
I know the shape of the scoop may not be the most attractive, but it will definetly serve it's purpose of getting a lot of cool air to the intercooler which will be in the rear trunk and will vent down over the transaxle and through the license plate area in the rear bumper.
Video: Porsche Boxster RS60 Spyder vs Porsche Cayenne GTS AVANTI R5 Non-Subaru News & Rumors 0 04-30-2008 02:19 PM
gauge cluster swap - wrx -> 2001 porsche boxster - possible? maaw Interior & Exterior Modification 1 02-21-2004 03:01 PM
Porsche Boxsters Recon Off-Topic 35 09-23-2003 09:21 PM
Porsche Boxster S FlowerWRX Texas Impreza Club Forum -- TXIC 23 06-21-2002 11:00 AM
I invade the Porsche Boxster Fun run (pics) SFsube Bay Area Impreza Club Forum -- BAIC 3 01-11-2001 06:29 PM
