Old 09-14-2010, 02:45 PM   #101
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Why not just use electric push fans for the intercooler? That's an aero mess and limits rear visibility which will be at a premium anyway.
silver arrow is offline   Reply With Quote
Old 09-14-2010, 02:57 PM   #102
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
Fans don't move enough air, simple as that. Show me one manufacture that uses electronic fans to cool an intercooler. Even if it did move enough air, I would still need a source for the air to begin with. As far as it being an aero mess, I don't think so. Look at cars like the Exige S and the Porsche GT1. Both use aggressive roof scoops to direct air to intercoolers. As long as the air is managed properly as it exits the intercooler's path, there is no negative effect. As far as rear visibility, if you read the post that has the pictures, you will see I already have a solution for that in mind.
kcpaz is offline   Reply With Quote
Old 09-14-2010, 05:38 PM   #103
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I don't know how much room there is up front but a well designed water to air could present some other packaging ideas...
Old 09-14-2010, 05:47 PM   #104
kcpaz
Member#: 194611
1998 Legacy GT
I plan on using an air-water for the "street version" but not for the race version.
Old 09-14-2010, 06:16 PM   #105
White out
Member#: 46277
** LP640
Viper GTS
That scoop is crazy!
What does the passenger side vent lead to?
Nick
White out is offline   Reply With Quote
Old 09-14-2010, 08:52 PM   #106
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Why not have dual scoops on each side right behind the window? That way you can keep the rear window functional and could have less material and a little more options in design.
Obviously you don't need our help and I assume you thought of that option but it was what popped into my head. Either way sweet work!
Ben
Old 09-15-2010, 02:23 PM   #107
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Since you're talking about racing this, you will want to consider gearbox cooling. The race teams we work with initially went with a fender mounted external cooler. That still wasn't enough and the gearboxes were still burning up. They then went to a front mounted cooler and everything was perfect.
However, given the turbo exhaust plumbing you may not have the same issues that the stock vehicles do. With the stock engine, the headers run right next to the gearbox (and the CV axles) and it basically serves as a heat sink for the exhaust heat. Your revised plumbing may not pose the same issues, but it's definitely something to consider before you get too far commited to any one configuration.
Regards,
Matt
Old 09-15-2010, 02:59 PM   #108
kcpaz
Member#: 194611
1998 Legacy GT
Regards,
Matt
The plan is to take the gearbox apart and install an LSD. While it's apart, I plan on welding some bungs into the case directly above the gears. Those bungs will supply cool oil from an oil cooler that will be mounted in one of the side quarter panel vents.
Old 09-15-2010, 03:31 PM   #109
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
oh man.. i just wanna hear this bitch run!
i have an ear for the unequal length header boxer engine.. but to turn my head and see a Porsche roll by = **** in underwear
/excite
Flyin_Hayn is offline   Reply With Quote
Old 09-17-2010, 06:21 PM   #110
scottjua
Member#: 2937
2013 BMW 335i
2006 STi Aspen White
as much as I love this project, that roof scoop is horrid... sorry. Purely from a personal aesthetic point of view... please find a new way to do what you need. That looks as bad a Sam Hubinette's terrible viper scoop.
Everything else is AWESOME!!!
scottjua is offline   Reply With Quote
Old 09-17-2010, 06:49 PM   #111
kcpaz
Member#: 194611
1998 Legacy GT
I'm open to suggestions, but it has to fit the following criteria in exactly this order...
1. It MUST supply a trunk mounted intercooler with a lot of clean, cool, fresh air.
2. It MUST be easily removable to allow for serviceability and removal of the hard top.
3. It MUST be light weight
4. It MUST be simple to recreate so that it can be produced and sold at a reasonable price (less than $700)
5. It MUST be "aesthetically pleasing"
Old 09-17-2010, 07:27 PM   #112
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
have you seen the older mr2 snorkel style intake? a larger version of that on both sides would fit your description.
AWDshenanigans is offline   Reply With Quote
Old 09-18-2010, 10:19 AM   #113
brianglawson
Member#: 229468
2004 Impreza WRX STI
awesome, this is a cooler swap even than an LSx Rx7 (which are F A S T)
look foward to seeing a street version, that's where your fabskills will really be put to work
the scoop admittedly isn't the most beautiful thing from the side profile, but nonetheless I think it's a nice execution for what you need. The Mr2 snorkels are a cool idea, also what about checking in to what Acura NSX's use. I seem to recall seeing some of those with some very good looking scoops as well. Granted Mr2's and Acuras are Targa's instead of roadsters, but they may still give you some ideas. Then maybe you can have a "street" version of your cooling scoops too!
brianglawson is offline   Reply With Quote
Old 09-18-2010, 10:11 PM   #114
redWRXrocket
Member#: 253637
I love what you are doing with this project it will be amazing.
As far as your scoop, I think side scoops would be much better looking although may require a little more work.....however maybe something like this could work as well.
it could require you to fab some internal ducting to direct the air. It could definately provide you with a smoother body line...something like an Honda s2000 hardtop. I imagine the intakes attached to the hardtop and sealed to the decklid area via a rubber seal.
Anyhow just an idea.
you have an amazing car and I can appreciate the extremely high quality of work you have done.
redWRXrocket is offline   Reply With Quote
Old 09-18-2010, 10:30 PM   #115
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I think we've given enough opinions. Let's just enjoy the build and see how it turns out. The scoop is just for the race car.
Old 09-18-2010, 10:39 PM   #116
kcpaz
Member#: 194611
1998 Legacy GT
If you saw the layout of the car, you would understand why that wouldn't work.
Old 09-18-2010, 10:39 PM   #117
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Default awsome
Should be fun watching this car develope, subscribing.
D-Rodman is offline   Reply With Quote
Old 09-18-2010, 11:14 PM   #118
kcpaz
Member#: 194611
1998 Legacy GT
To give you a better idea why the scoop is the way it is. Here are some more detailed pictures that show how the Boxsters are WAY different from the MR2's and NSX's. The engine bay is accessed 100% from the interior. There is no separate external access to the engine. If I did two side scoops, they would have to extend all the way to the back of the car where the intercooler will be. This is the main reason why this will be considered a "race set-up" because I assume most street cars will want to retain the use of the rear trunk.
Old 09-19-2010, 12:52 AM   #119
Homemade WRX
Member#: 33782
96 bastard child
I still say water to air for fitment, placement and lack of a need for aero ducting.
Old 09-19-2010, 01:13 AM   #120
kcpaz
Member#: 194611
1998 Legacy GT
The car will be a purpose built roar racing car. What's next, a debate between which is better air-to-air vs. air-to-water? For drag racing, autocross or street use, I could see your point, but not for this car.
Old 09-19-2010, 01:20 AM   #121
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
have you considered using the setup of the 993 911 turbo setup?
using a louvered whale tale that directs air into the intercooler. then for your application, add some fans in the trunk (or some vents) to vent away the hot air to the outside.
http://www.europeancarweb.com/tuned/.../photo_13.html
don't forget , you always have the option for meth/alky injection
paulmofyourhand is offline   Reply With Quote
Old 09-19-2010, 01:28 AM   #122
Homemade WRX
Member#: 33782
96 bastard child
I was thinking 911 type louvers too.
Fair enough...I'm just saying it has it's perks too and anyone who says a water heat exchanger has no place on a road course might want to do some research...common misnomer.
I like the project, not meaning to sound negative at all...although it does seem like the vultures are out. Just ignore them and keep plugging away
Old 09-19-2010, 01:39 AM   #123
kcpaz
Member#: 194611
1998 Legacy GT
Show me a professional level road race or rally car that uses an air-water intercooler set-up, and I will show you 100 more that don't. I don't follow the logic that it is a misnomer to assume that an air-to-air style intercooler works better in high speed, endurance applications.
I don't mind the vultures bustin' my balls , but they need to do realize that this isn't my first rodeo and there's usually a reason things are done the way they are done.
Oh, and as far as the "whale tail" idea. Porsche people are usually the first to mention this, and it doesn't work for a few reasons. The most important one being that the Boxsters don't have the same gradual sloping rear section that the 911's have. The abrupt drop off at the rear window on the factory Boxster hard top causes some turbulence right before the rear deck-lid which would be less than ideal for a louvered whale tail. Also, as hideous as some people think the roof scoop is, imagine how ugly a whale tail would be Maybe on a Cayman, but not for a Boxster... and yes, I know about the Zeintop and I'm not about to consider that as an option.
Old 09-19-2010, 03:04 AM   #124
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I was thinking more this:
Or the 914 radiator setup up front:
Old 09-19-2010, 10:29 AM   #125
Homemade WRX
Member#: 33782
96 bastard child
I was simply referring to the use of a water to air heat exchanger. I've seen so many Cup cars and DP cars that use w/a instead of air to air because of the consistent temps that could had, that isn't with the air/air. I will however agree that using water to air for IC purposes would be quite heavy in order to be effective. At least it's weight can be placed throughout the chassis, strategically.
If you've already looked into it and the numbers don't stack up, cool.
Now not knowing the boxster very intimately, how much room is there with the side ducts? what do they feed, if anything? I just saw them in the pics of the engine bay and they seem to go to nothing.
Video: Porsche Boxster RS60 Spyder vs Porsche Cayenne GTS AVANTI R5 Non-Subaru News & Rumors 0 04-30-2008 02:19 PM
gauge cluster swap - wrx -> 2001 porsche boxster - possible? maaw Interior & Exterior Modification 1 02-21-2004 03:01 PM
Porsche Boxsters Recon Off-Topic 35 09-23-2003 09:21 PM
Porsche Boxster S FlowerWRX Texas Impreza Club Forum -- TXIC 23 06-21-2002 11:00 AM
I invade the Porsche Boxster Fun run (pics) SFsube Bay Area Impreza Club Forum -- BAIC 3 01-11-2001 06:29 PM
