Old 08-31-2010, 06:17 AM   #1
grex07
Member#: 167116
2013 STi 5Dr
Default gear in trunk
spilled some diff fluid in the trunk. any ideas how to get it out? tried cat litter but its still there.
grex07 is offline   Reply With Quote
Old 08-31-2010, 10:05 AM   #2
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Is it just an the trunk mat? Take it to one of those self serve car washes, put it on the wash setting, and use the power washer to spray it down real good. (Take it out of the trunk of course.) Clean up the rest on the wood and anywhere else it spilled. Dousing the trunk with Febreeze may be needed as well because that stuff smells wretched. My best advice/cheapest option.
ThreeEleven is offline   Reply With Quote
Old 08-31-2010, 10:26 AM   #3
vms150
Member#: 172917
2004 WRX
I would just replace the carpet. Gear oil will never come all the way out.
vms150 is offline   Reply With Quote
Old 08-31-2010, 05:39 PM   #4
Subi_Boy06
Member#: 208979
2006 STI
You can use a hot water extractor for that, but it may not come out 100%.
Subi_Boy06 is offline   Reply With Quote
Old 08-31-2010, 05:42 PM   #5
AutoAesthetica
Member#: 246785
I would try to soak up as much as possible with towels or rags first.
Then(and don't forget to spot test) you will need a pretty decent degreaser that you can allow to dwell on the oil in the carpet for a few minutes to allow it to work. Then I would continue you on trying to soak and sop up that degreaser/gear oil mixture before even thinking about adding water and trying to extract(make it so you have as little as possible that will make it much easier). Try that a couple times before you think about scrubbing and adding even more moisture.
Priority would be getting a chemical that can safely(for your carpets sake) breakdown and begin to emulsify the oil so you can pull it out without having it run further.
AutoAesthetica is offline   Reply With Quote
possible to mix STI RA gears and stock gears in a wrx? vhalin Transmission (AT/MT) & Driveline 2 04-04-2008 02:12 PM
Broke 4th gear in JDM STi 6 speed (07 sti gear ?'s) dan avoN7 Transmission (AT/MT) & Driveline 7 11-20-2007 02:05 AM
yay, top gear! booo, top gear in the US martel Off-Topic 10 06-29-2005 11:24 PM
Anyone change econo gear and move to a higher gear in their FWD 1.8L? Max Umbarger Transmission (AT/MT) & Driveline 2 03-17-2002 02:53 AM
Pic's of broken first gear and new dog gears in case gary501 Transmission (AT/MT) & Driveline 18 11-29-2001 10:55 AM
