Vancouver Impreza Club
Old 08-31-2010, 12:24 PM   #1
asherbo
Member#: 113143
6/15 wrx/sti
world rally brown
Default engine trouble?
Did some searching but wanted to post up here anyway. My car during hard acceleration has some weird rpm readings. Like when i accelerate, my rpms would read like 3.5k then i would hear the engine power drop a tad bit as does my rpm readings. Almost as if the engine is confused at what rpm/speed it should be. But after the quick drop in speed/power it goes back to normal. Any ideas? I also have an ots cobb map but am going for a tune soon. Just wondering if this is a issue can be solved with a tune or if i should get it checked out.
Let me know! Thanks!
asherbo is offline   Reply With Quote
Old 08-31-2010, 01:55 PM   #2
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
you has hesitation......could be a few things...
is there a CEL?
Jeff54 is offline   Reply With Quote
Old 08-31-2010, 02:57 PM   #3
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
COBB AP stage 2 map?
Linkseal is offline   Reply With Quote
Old 08-31-2010, 04:27 PM   #4
asherbo
Member#: 113143
6/15 wrx/sti
world rally brown
nah no cel. everything runs fine. no just running a the stg 1 map. its almost as if my engine runs faster than my turbo, if that makes sense. like the thrust i get when i hammer it goes faster than what my engine thinks, then when my turbo kicks in it drops like 500rpm then goes normal. but if i ease in the power and the turbo kicks in its all good, only happens if i accelerate hard.
Old 08-31-2010, 05:30 PM   #5
iiclips
Member#: 255585
2009 GE6 5MT
My MK.III Supra had this problem...
On full acceleration, it would rev up smoothly, but as pressure builds up around 3~4k rpm, it would hesitate with a slight rpm drop then accelerate to 6k rpm normally.
Mine only happened on 1st gear though... or I was too dumb to notice it on other gears...
I'm still not sure if it's boost drop or whatever, but it sure felt weird.
Anyway, it turned out I had a leak somewhere critical and had to get my engine serviced and eventually replaced...
Hope yours isn't something like this.
iiclips is offline   Reply With Quote
Old 08-31-2010, 06:06 PM   #6
ShadowDancer
Member#: 57441
07 STI
CGM
Perhaps your maf is dirty, or a leak somewhere. I had something similar when my intercooler to throttle body hose was loose.
ShadowDancer is offline   Reply With Quote
Old 08-31-2010, 07:28 PM   #7
asherbo
Member#: 113143
6/15 wrx/sti
world rally brown
the funny thing is that before the cobb i was running all good. but once i loaded the map it went like that so im thinking i need a custom tune? would that help solve the problem?
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 10:04 PM
1.8l engine troubles... wingedcow North West Impreza Club Forum -- NWIC 4 01-14-2003 07:40 PM
engine trouble yukon General Community 1 10-17-2002 08:19 PM
WRX Engine troubles subarugt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-19-2002 11:38 AM
'00 Legacy GT engine trouble... Kostamojen Legacy Forum 1 09-13-2002 04:05 AM
