Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 08-31-2010, 01:52 PM   #1
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
Default Sub 3000 rpm stutter/hesitation.
2000 2.5rs sedan. 258k
About 2 years ago, I had similar symptoms, and was cured by cleaning out the throttle body, and changing the fuel filter. In the process, changed the coil.
Car was fine until this summer.
Similar symptoms. Car will stutter like crazy, but if you can get it above 3k, it seems to pull as hard as ever. It coincides with my fuel level gauge starting to crap out. I didn't think the two were linked until this weekend. The stuttering is intermittant. Usually the car gets warm and it goes away.
Drove the car for about an hour, and the stuttering becomes very consistant. It starts to get bad enough, I worry if I'll get home. As I approach a rotary, I lose 80% of my power, abs light comes on, speedo and tach indicate zero, even though I'm going about 25 mph. After a few seconds, I wonder to myself if maybe the alternator has crapped out or something at the tach indicates zero.
I realize my head light and fog lights are on, so I turn them off, the dash goes to normal and cars power goes to normal. Turn the lights back on, and the abs light comes on and tach and speedo go to zero. Turn the lights off again, and all seems normal.
I continue on with lights off. I have 30 minutes left of my drive home. I realize that my gas level gauge is now back to normal, and is no longer malfuctioning. I have no stutter, and the drive home the car acts perfectly.
I get within a mile of my house, and decide it would be good to test the lights again.....cause I could walk home at this point. Turn on the lights, and everything is still fine.
Had a new gas tank installed this spring.
Certainly a wierd one.
sachilles is offline   Reply With Quote
Old 08-31-2010, 01:57 PM   #2
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
My only thought is a wacky voltage regulator
Old 08-31-2010, 02:07 PM   #3
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
or bad batt/alt?
snoopyone8 is offline   Reply With Quote
Hesitation/Surging 2400 to 3000 RPM and 15-30% throttle stlb5 Open Source Reflashes 49 05-06-2015 11:24 AM
bad hesitation before 3000 RPMs fnshmetal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-09-2012 11:11 PM
06 WRX Hesitation between 3000 RPM - 5000 RPM dao Newbies & FAQs 11 01-19-2012 11:56 AM
Hesitation under light throttle 2400-3000 rpms RunForest Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-02-2005 10:24 PM
Small blip of hesitation at 3000 rpms? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-01-2005 06:13 PM
