Old 05-01-2011, 11:25 PM   #51
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
Originally Posted by grkimpreza
just wondering how much for those hybrid races
Pm him and he'll tell you! Just ordered mine and are supposed to ship out tomorrow!!
143subaru is offline   Reply With Quote
Old 05-01-2011, 11:48 PM   #52
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
+1 The only reason I haven't ordered mine already is because at this point I still dont know if need them. PM is the way to go.
Joelo_00 is offline   Reply With Quote
Old 05-01-2011, 11:53 PM   #53
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
What year is your car and what year is your 6 speed from? I have an 02 wrx and 04 STI 6mt... So my STI axles work in the front hubs... But no go on The rear... I'm getting 07 STI rear axles... I have my 02 axles already (for the cup) and inner racers are on the way!!
Old 05-02-2011, 12:31 AM   #54
Joelo_00
Member#: 175095
2000 RS
My situation is that I've yet to get my hands on a 6spd, I'm waiting on what deal do I end up getting. But the thing is that I already PM'ed about them and he gave me the information I needed right away. Good luck and I hope you can enjoy your car again really soon!
Old 05-02-2011, 02:51 AM   #55
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
I'm sure you know this but....
Try and get same model years... I got EVERYTHING needed to do the swap but only NEED Tranny, driveshaft, rear diff, and a pair of these wonderful hybrid axles!!! If you get different versions than yours you run into needing hubs, brakes, rotors etc... just more money and more work...
Old 05-02-2011, 08:03 AM   #56
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
You put 04 sti front axles into 02 WRX front hubs??
NitroTrike is offline   Reply With Quote
Old 05-02-2011, 08:31 AM   #57
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
Big positive ghost rider! Ask mowgli29.... he was there ;-)
Although I did end up switch hubs... Not cause its axle related....
My ball joint kept spinning when I went to put castle nut on... What's that about??
Old 05-02-2011, 10:09 PM   #58
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
Got my racers today!!!!!!!!!!! Came in TWO DAYS!! And instructions and packing grease and everything!!! Thanks again suberdave you supergenius!!! As mowgli29 does ill keep everyone updated! Except mine isn't my dd so when I drive it I DRIVE IT!!!
Old 05-10-2011, 09:54 PM   #59
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
There is something everybody should know about suberdaves races.
They lasted through the Olympus Rally attached to my insta-torque EG33 and even posted a #9th fastest on the toughest stage.
biggreen96 is offline   Reply With Quote
Old 05-19-2011, 11:16 PM   #60
mark72
Member#: 283296
Originally Posted by suberdave View Post
The Missing Link to the R180 install with R160 hubs...
So I needed to install an R180 diff with my 6 speed swap, but did not want to install the rear R180 rear hubs.
So I did some research and found that the inner cup of the R180 axle shaft could be joined to an R160 axle shaft with the aid of a custom CV race.
I did much research online and made many long distance phone calls and found a CV company that could make me the custom race that I needed.
Problem was that like many things in manufacturing, they would not make me just 2, I had to have 10 min made.
So if anyone else wants to do this same thing... PM me I have extras to sale...
left is 2005+ STI inner race center is custom STI / WRX Race Right is 2002 WRX inner race
This is how it works.
You must use 05+ STI inner shafts with 8 balls on the race and cage. the 04 and earlier have 6 balls and will not work with this custom race.
First take apart both shafts.
Remove the CV boot clamps. if you do this right you can reuse them.
Next remove the retaining ring holding the inner joint together.
Next the Snap ring at the end of the shaft.
and it is now apart...
Now put it back together using the WRX shaft, the custom race, and the STI inner joint.
And now you have a custom shaft to install your R180 diff in your Subaru using your stock hubs...
-=Suberdave=-
www.suberdave.com
Hi Dave,
Just wondering if you still have any inner race center custom left.
If so how much are they and postage to Australia!
I have a 99 WRX with R160 rear and want to put a R180 and will this work with my axels.
If it's ok could you please give me your contact details so I can phone you as it's easier than sending messages back and forth
Thanks Mark
mark72 is offline   Reply With Quote
Old 07-03-2011, 11:33 PM   #61
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Bump. I'm a little confused on what I need.
I have a Type-RA drivetrain and if I install the rear differential, would I need the 6 pointed ball to install the rear axles to my current hubs?
Or if I upgrade to stock WRX rear brakes, would I not need these "hybrid" axles?
Smoke is offline   Reply With Quote
Old 07-04-2011, 04:01 AM   #62
biggreen96
Member#: 12535
vf39 06 5MT XT
These are for people using R180's with non-STi rear hubs.
So if you upgrade to stock WRX brakes, and are using the STi R180, you need these hybrid axle parts.
Old 07-05-2011, 11:05 AM   #63
Tsiguy91
Member#: 287499
Default Pm sent
Pm sent, I need these ASAP , I have a car in pieces on a lift
Tsiguy91 is offline   Reply With Quote
Old 07-06-2011, 12:24 PM   #64
Tsiguy91
Member#: 287499
Can anyone shed some light on how fast they heard from Dave for these axles, I've pm'ed and sent an email?
Old 07-06-2011, 01:25 PM   #65
Tsiguy91
Member#: 287499
Spoke with him
Old 08-31-2011, 10:10 PM   #66
Bigrederic
Member#: 208971
2003 WRX sedan
PM sent ....
Bigrederic is offline   Reply With Quote
Old 09-01-2011, 02:28 AM   #67
matthew0029
Member#: 238794
I want a set of 2005 hybrid axles for my swap
matthew0029 is offline   Reply With Quote
Old 10-15-2011, 12:29 AM   #68
1thumper
Member#: 248584
2002 wrx
excellent just what im looking for...you dont still have some do ya? how much shipped to canada.
pm if you have some.
1thumper is offline   Reply With Quote
Old 10-15-2011, 04:16 PM   #69
Hobz
Member#: 153246
'00 2.5RS
Originally Posted by biggreen96 View Post
Good to hear.
I used axles from the 90's in my race conversion, and had to remove a bit of material in order to get the new inner race on far enough to get the snap ring on. 10 mins w/ a dremel.
Thank you Dave for saving us 100s of dollars!
I got some '03 WRX axles and after sliding the hybrid inner race onto them it looks like I will have to remove some material from the shaft after the spline as well since the snap-ring groove is still hidden. I'm guessing I'll have to remove 1/16".
Hobz is offline   Reply With Quote
Old 10-15-2011, 04:26 PM   #70
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
^If that's the case. Can you measure before and after shaving?
Old 10-16-2011, 01:02 PM   #71
Hobz
Member#: 153246
'00 2.5RS
That's tricky to do. There is a chamfer that acts as the stop, and what you are essentially try to do is move that chamfer down the shaft a little. I measured to the OD of that chamfer with a pair of calipers and when I was done trimming the end of the chamfer was moved approximately .071". It is essentially trial and error though. My races also had a chamfered side and a counterbored side. I put them on with the chamfered side towards the snap-ring groove.
I used a die grinder and the laid the shaft on a table, splines hanging off the end. I rolled the shaft along the table while grinding to get as even a cut as possible. You want to make sure you blend the cuts in and don't have any hard edges steps in there that will act as stress concentrators and could lead to axle failure.
Old 11-17-2011, 07:22 PM   #72
toflaherty
Member#: 212765
2003 WRX
I'm having the same problem. With the races on, the snap ring groove is covered up. Since the axle has a chamfer as a stop, I assumed that the race would go on with the chamfer on the side of the chamfer on the axle, and the counterbore side pointing towards the end of the axle where the snap ring goes. Either way it doesn't fit.. =(
toflaherty is offline   Reply With Quote
Old 11-29-2011, 06:35 PM   #73
chrisagu28
Member#: 263220
2005 Wrx / Sti conv.
2014 XV Crosstrek
Man I hope these work for my 2005 wrx axles and i am also hoping he has some left.
chrisagu28 is offline   Reply With Quote
Old 11-29-2011, 07:26 PM   #74
biggreen96
Member#: 12535
vf39 06 5MT XT
Bust out the dremel. It's quick work.
Old 12-01-2011, 06:50 PM   #75
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Awesome!
I've been running DSS conversions for a few years, gonna have to pick some of these up and convert the other axles I have for spares.
Merp is offline   Reply With Quote
Hybrid axles Jpizzzle Transmission (AT/MT) & Driveline 7 02-22-2010 01:55 PM
"The Missing Link" Discovered in Germany? Jard Off-Topic 55 05-21-2009 04:21 AM
How did I miss "The Wire" for so long? Rice & Gravy Off-Topic 19 01-05-2007 06:56 PM
WTB:SOCAL: Hybrid Axles xplane Private 'Wanted' Classifieds 0 05-23-2006 12:25 PM
Do you miss "the monkey?" obyone General Community 6 11-15-2002 06:01 PM
